Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
112 registered members (1911CHAMPION, 4WD, 2004tdigls, 55hambone, 94astro, 77Se7en, 10 invisible), 1,793 guests, and 42 spiders.
Topics307,632
Posts5,314,651
Members71,894
Inverter generators #5465153 06/28/20 08:07 PM
E
Eddie Online Sleepy OP
OP Online Sleepy
E
I would like to hear from those who have some experience with 2000 watt inverter generators. Reliability or other problems with specific manufactures? Ed
2014 CX5 Touring 2.5L :-)
Re: Inverter generators [Re: Eddie] #5465162 06/28/20 08:15 PM
I
IndyIan Offline
I
We've had a Yamaha EF3000ise for 15 years now, works good, all I do change the oil once in a while. One of these years I should check the plug. The 2000W one is a good idea as the 3000W ones are heavy and now with LED work lights, you don't really need two functional circuits very often. When we got it we were running halogen work lights on one circuit and a tool on the other.
06 Focus ZXW, 5spd manual, 220km
18 Outback 2.5 CVT 35km 0W20
Re: Inverter generators [Re: Eddie] #5465169 06/28/20 08:22 PM
ctechbob Offline
Not 2000 watt, but my little Wen 56125i works when I need it to. I bought it for running fans/charging phones at my daughters softball tournaments. Works great for that, and I've used it a handful of times when we've had power outages, although they are usually not long enough that I have to power the fridge or freezer, I know it will run each of them, but not sure if it will do both together. Never taken the time to test it.
Replaced the 'torch' plug with an NGK after breakin just so I'd have a good plug in there. Change the oil every 10 hours or so since it holds so very little. Other than that, its been solid. The 2000 watt one is supposed to be much the same.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Inverter generators [Re: Eddie] #5465176 06/28/20 08:32 PM
skyactiv Offline
These are not the $$$$ Honda generators everyone thinks of. I would go to a Honda Powersports dealer and order one.
https://powerequipment.honda.com/generators/models/eg2800i
https://www.amazon.com/dp/B01M5932HD?tag=dprmdexhgli-20&linkCode=osi&th=1
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Inverter generators [Re: Eddie] #5465181 06/28/20 08:40 PM
skyactiv Offline
Re: Inverter generators [Re: Eddie] #5465184 06/28/20 08:42 PM
wwillson Offline
Administrator
Administrator
I've had a Honda 2200i for about two years. I use the generator to supply AC to our RV when off the grid. The Honda is very quiet and very reliable and it starts on the first pull every time. It will start and run a 15,000 BTU air conditioner with a soft starter like Easy Start. However, it won't run much more than the air conditioner, especially if the air conditioner is cycling on and off. If not running the air conditioner, then you can run the fridge, brew coffee, dry hair, run microwave, etc, but none of those high demand items at the same time. We've run it for 24 hours at a time with an extended run tank. Last week it ran for 20 hours straight, running the air conditioner, and used 4.5 gallons of fuel. If you are careful not to have any demand for power, except the air conditioner, then you can use the eco switch so it idles down at night when the air conditioner turns off. It uses zero oil.
I like the 2200 for its size. It fits under the tonneau cover of the truck and I can lift it in and out of the truck by myself. At this point, I'm glad we didn't opt for a larger generator for our use.
Re: Inverter generators [Re: Eddie] #5465191 06/28/20 08:52 PM
Z
zfasts03 Offline
Z
I have a Honda EU2000i since 2006. Love it. Probably 800 hours on it. Powers the essentials during an outage.
Only issue was the main jet of carb. getting restricted due to old fuel. Switched to a top tier fuel and run Startron fuel stabilizer and now it has been fine.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Inverter generators [Re: Eddie] #5465199 06/28/20 09:02 PM
R
Rand Online Content
Online Content
R
https://www.harborfreight.com/2000-Watt-Super-Quiet-Inverter-Generator-62523.html
There are quite a few no-name ones cheaper. Maybe an extended warranty would be a good buy?
Re: Inverter generators [Re: Eddie] #5465203 06/28/20 09:08 PM
F
fsdork Offline
F
I've had a Champion 2000w inverter generator for about 5 years. It developed a mild surge after a couple of years, and I removed and tried to clean the carb with no change. I called Champion customer service, who were very helpful and friendly. About $60 later for Canadian for a replacement carb out of warranty and my generator runs smoothly again. The only downside in dealing with the carb issue was that Champion doesn't offer any sort of rebuild kit, only replacement. Overall, I am happy with my experience. Who knows what caused the carb issue. It was more likely something in the fuel than a defect, as it ran well when new. I did use marine Sta-Bil with ethanol free fuel.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Inverter generators [Re: Eddie] #5465247 06/28/20 10:06 PM
J
JimPghPA Offline
J
I bought a Generac 2200 Watt Inverter generator online from ElectricGeneratorsDirect several years ago. I can't remember the exact cost but it was about $550.00 There was a design problem with it and many of them failed in a way that they stopped producing power. I do not have many power failures where I live but I ran it once in a while to make sure it still worked. When I finally had a power failure it did not work, and it was out of warranty. I wrote a letter to Generac and explained that I had very low hours on it, and have a background in electronics, and never abused it, and it still failed. By then it was common knowledge that this model of Generac inverter generator had a design problem and it was common for them to fail in a mode where they did not produce power. I was getting ready to buy a Honda inverter, and a new Generac 2200 Watt generator with a new design showed up on my front porch from Generac for free. They had fixed the design problem, and also improved the way it is primed for starting. Even so this new improved version causes the TV to shut off when the load of a compact florescent light is turned on. And now even that new improved model that I now have has been discontinued.
If I had it to do over again I would have bought the Honda inverter generator. Yes the Honda inverter generators are much more expensive, but they are much more reliable, and even in eco mode they handle application of loads much better. And the power they produce is much cleaner.
All of these low Wattage (around 2200 Watts or less) have very small carburetors that have very small passage ways that do not take much to clog them up. Along with using fuel stabilizer such as Sta-Bil you should run the carburetor dry before you put it away for storage. Fuel left in the carb will evaporate and leave a concentrate of gunk that is not good for the carb. Another good thing to do is spray the carburetor with WD-40 before putting it away. BTW WD-40 is combustible, and an engine will run for a short time if you try to start it after you spray the carb with it.
If when you put it away it might be a long time before you use it (more than 6 months) you might want to coat the inside of the cylinder with a spoon full of oil or Sta-Bil foaming oil, and then pull the rope a few times to distribute the oil. The down side to using oil in the cylinder is that after several uses if you do not have long run times to burn off the build-up on the spark-plug it will foul the spark-plug.
Anytime you store a single cylinder engine you should slowly pull the rope and stop when you feel the rope getting harder to pull which means the engine is on the compression part of the cycle, and therefore both the intake and exhaust valves are closed. This is easier on the valve springs, and also with the valves closed atmospheric moisture can not condense out of the air and into the cylinder.
There have been some recent improvements in gas additives the help keep carburetors clean. Maybe others can comment on what additives are now the best the gasoline for small 4 cycle engines?
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Inverter generators [Re: Eddie] #5465407 06/29/20 07:08 AM
T
thastinger Offline
T
Have a couple of Yamaha ones. An EF3000iSEB and an EF2000iS. Never any issues with either one, battery died on the 3K but I expect to replace starter batteries now and then. We use the 3K for the toy hauler and I bought the 2K because the 3K really isn't portable, even though it has wheels.
Re: Inverter generators [Re: Eddie] #5465491 06/29/20 09:28 AM
Schmoe Offline
I have always heard that if your going to store a single piston engine, pull the rope until it's at its easiest...no strain on the crankshaft, bearings or rod. Haven't heard that reasoning before, but it makes sense. May have to start doing that. I have a single piston Chonda 7500W generator that hasn't been used a lot. Stored dry and no fuel in carb or bowl and was stored when the rope was at it's easiest. May have to pull it out and do what Jim said.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Inverter generators [Re: Schmoe] #5465501 06/29/20 09:39 AM
supton Offline
The reason for the hard pull is that it is coming up on the compression stroke. No engine is 100% sealed so if you pull up, wait a few minutes, then pull some more, you should feel it pull easier (at least for part of the pull). The compression will leak off.
If anything I'd think this is where it should be stored. Both valves closed. Depending on the valve closing/opening it'd be great to get it at BDC for least exposure of the cylinder to moisture in the air, but just getting valves closed should really slow down any moisture (or creature) ingress. That might be a bit overkill, lots of engines get stored wherever they last stopped (although come to think about, those would have stopped on a compression stroke) with little issue.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Inverter generators [Re: Eddie] #5465508 06/29/20 10:01 AM
E
EdwardC Offline
E
I purchased a used Honda EU2000i a few years back. I'm pretty sure it was run pretty hard (likely construction) as it was pretty beat up outside. It still started from cold pretty easily. I changed the oil and plug when I bought it, and has been trouble free. It's just for emergency use (haven't needed to use it, knock on wood), and yearly tailgate use.
I put a heavy dose of marine Stabil in all of my gas cans, and I try to run the tank dry when I can (although I didn't last time, and the generator sat with fuel for about 9 months before I started it again with no issue).
For a little more than I spent, I could have bought a new HF or Wen model, but I figured the Honda would be more fun, and likely plenty of life left for my usage.
Re: Inverter generators [Re: Eddie] #5465549 06/29/20 11:01 AM
Dave Sherman Offline
I had a Powerhouse PH2100PRi. That model has been superseded by other models, but I'd steer clear of that brand. The automatic choke was horrible, the battery for the electric start was this ultra-rare weird size that was ridiculously overpriced, and the fuel lines got very brittle after a few years.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
