Forums Migration
Please read this thread
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
82 registered members (77Se7en, 86cutlass307, AlienBug, aquariuscsm, Bailes1992, alarmguy, 4 invisible), 1,272 guests, and 42 spiders.
Topics307,630
Posts5,314,544
Members71,888
polyurea grease compatibility #5465105 06/28/20 07:21 PM
N
neo3 Offline OP
N
I got a tube of John Deere polyurea grease, part #TY6341, for greasing control arm ball joints. I used a lithium/moly type grease on them previously. Now I find that there's a difference between "shear stable" polyurea grease and "conventional" polyurea grease, where the shear stable type is compatible with lithium grease and the other type isn't. See:
www.machinerylubrication.com/Read/1865/grease-compatibility
(Found this out from an older posting on here.)
The problem is I can't find any explanation for how to know which type of polyurea grease I have. Anyone know about this? There's no way to clean the old grease out of the control arm joints. I'd like to use the grease I already got if it will work.
Re: polyurea grease compatibility [Re: neo3] #5465314 06/29/20 12:54 AM
N
neo3 Offline OP
N
Update - I couldn't find a real data sheet, but the John Deere product blurb says it's compatible with "most" other greases, so I'll take that to mean it will be OK with lithium type grease.
Re: polyurea grease compatibility [Re: neo3] #5465618 06/29/20 12:18 PM
T
tundraotto Online Content
Online Content
T
Literally a sticky on the top of this very sub-forum....
https://www.bobistheoilguy.com/foru...compatibility-chart-and-info#Post5293259
Re: polyurea grease compatibility [Re: neo3] #5468095 07/02/20 05:33 PM
B
bchannell Offline
B
Yeah, and if you read JD literature, it states that it is shear stable PU grease. If you do a search you'll find the literature.
Re: polyurea grease compatibility [Re: neo3] #5469964 07/05/20 08:16 AM
ABN_CBT_ENGR Offline
You will probably be fine in your application but don't let that word "compatible" scare you or give you a false sense of security- all it means is that the components in question ( not the grease compound as a whole) will not have an immediate adverse reaction.
Compatible does not mean they will maintain the same properties, carry the same loads or wont attack each other and change critical properties across the spectrum. Its always best to clean out and replace as much as possible when switching greases. Even if it means a few extra purge cycles.
PU greases generally perform acceptably for low to medium boundary applications such as yours
Re: polyurea grease compatibility [Re: neo3] #5469999 07/05/20 09:21 AM
E
eyeofthetiger Offline
E
I have found myself using a polyurea grease (Lucas X-tra Heavy Duty) on brake caliper guide pins when I didn't have my preferred silicone grease on hand. It is listed as shear stable, extreme pressure, waterproof, with a 560°F drop point (I realize Lucas puts all kinds of marketing junk on their packaging, but some of it has to be true). I am assuming the polyurea base should be fine with rubber or EPDM parts. The high compatibility means it should be okay with some of the unknown grease residue left in the bore.
I'd like to hear any opinions on using polyurea for this application, because I've never heard of anyone else doing it.
Re: polyurea grease compatibility [Re: eyeofthetiger] #5470011 07/05/20 09:34 AM
First, the base oil (not the PU thickener) and any seal agents in the recipe will determine suitability for rubber/EPDM concerns.
Otherwise, you should be perfectly fine in your application even with some residue.
Re: polyurea grease compatibility [Re: ABN_CBT_ENGR] #5470019 07/05/20 09:43 AM
E
E
Forgive my grease illiteracy. tongue2
It is supposed to be a synthetic grease, but the MSDS doesn't have any information about what is actually in it.
Re: polyurea grease compatibility [Re: eyeofthetiger] #5470027 07/05/20 09:51 AM
Synthetic just means something in it has been modified ( that's a whole different subject for Pandora)
The SDS most likely wont help- you need the product data sheet and specifications.
I would be surprised if a company like Lucas would make and market something that would have adverse affect on an automotive standard polymer but it never hurts to ask.
You will be fine in your application for this, I'm sure
