Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
112 registered members (1911CHAMPION, 4WD, 2004tdigls, 55hambone, 94astro, 77Se7en, 10 invisible), 1,788 guests, and 45 spiders.
Topics307,632
Posts5,314,651
Members71,894
Burning oil, City vs Freeway? #5465007 06/28/20 04:12 PM
M
MichaelRS Offline OP
M
Hi guys. Is there anything about the nature of City Driving vs. Freeway driving that would cause a car to burned more or less oil compared to the other?
Meaning, if you drive a thousand miles in the city, with its varying speeds and starting and stopping and you burn 10 oz of oil are you just as likely to burn out same 10 oz on the freeway with a roughly constant speed for a thousand miles?
I think that would have something to do with the oil pressure at varying versus constant speed, but I'm not sure which tends to affect it in which direction the most.
Thanks
2002 Toyota Sienna LE
203,500 as of March, 2020
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465019 06/28/20 04:36 PM
M
Mitch Alsup Offline
M
If you get on the highway, set cruise control to (pick a MPH) and stick with that MPH you are likely to burn less oil. And if that MPH is a sane speed, your engine will run cooler and you will exceed EPA mileage.
If, on the other hand, you get on the highway and treat it like a race track passing everything in site, then you are likely to burn more oil than stop and go light throttle operation in the city, and get lower than EPA mileage, and a few tickets, now and again.
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465039 06/28/20 04:56 PM
dbias Offline
I would think the cause of the oil burning would dictate whether city vs highway would increase oil consumption. Additionally naturally aspirated vs turbo would also. Alot of variables to consider.
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
2019 VW Jetta SE factory fill
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465123 06/28/20 07:33 PM
P
Powerglide Offline
P
Highway oil consumption will usually be higher due to a constant high vacuum condition pulling oil past worn ring packs and valve stem seals on OHV engines. This is especially true of high mileage engines. The dilution/fuel burn off from a vehicle that's been used primarily around down will mimick oil consumption. But after the additional burn off, actual consumption will tend to level off. Occasionally the newfound additional highway usage will benefit the motor and burn off engine waste products. My grandfather (died 1991) owned and operated a Citgo station since the Depression (1930s) used to say "around town exhaust waste winds up in the crankcase, on the highway it goes out the tailpipe".
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465150 06/28/20 08:05 PM
G
gregk24 Offline
G
I know my parents previous vehicle, a 2005 Chevy Uplander (3.5 V6) always burned more on the highway. When we would take a trip up to SC you could count on adding a quart when you got there. They sold it a month or so ago and it's still in the area.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465158 06/28/20 08:10 PM
R
Rand Online Content
Online Content
R
the 2013 outback with all 3 of its oil burning phases.. much higher oil consumption on highway.
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465196 06/28/20 08:59 PM
caprice_2nv Online Content
Online Content
My 76 olds 350 v8 and 83 Chevy Caprice 305 v8 both seem to use the same amount with all highway as with mostly city and short trips. But they turn like 1500-1800rpm on the highway.
A 4 cylinder or a v8 towing or climbing severe mountains probably will use more on the highway.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465207 06/28/20 09:12 PM
R
R1jake Offline
R
Any old car I’ve owned that burned oil always burned more oil on the highway. I’ve had 3 different cars that burned oil and on all 3 this was the case.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465212 06/28/20 09:21 PM
P
Powerglide Offline
P
My 56 Chevy Bel Air 265 with stock rear gearing (3:55) has the engine turning 3200 rpm at 75 mph cruise. Runs all day long at that speed. 3 inch stroke means relatively low piston speeds. However oil consumption is roughly 1300 miles per quart. A 60%/40% mix of suburban/highway/secondary road driving (40-60mph) and consumption drops to almost zero.
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465477 06/29/20 09:05 AM
M
MCompact Offline
M
The S38 in my M6 only used oil at 3500 rpm or higher such as when cruising at 80+ mph or on track days. In contrast, the M42 in my Club Sport will cruise all day at 4000 rpm and not use any oil- although it does consume a little in suburban driving.
I just chalk it up to being the nature of the beast(s) and I don’t lose any sleep over it.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Burning oil, City vs Freeway? [Re: MCompact] #5465518 06/29/20 10:20 AM
dudemancool1904 Offline
In contrast my old m42 318is didn’t burn any oil it just leaked it onto my driveway. My s38 powered e34 m5 Was the same as yours, fine around town but if you romped it on the way to Vegas it would burn some oil. Miss the e30 more sniff sniff.
Re: Burning oil, City vs Freeway? [Re: MCompact] #5465611 06/29/20 12:07 PM
Online Content
Probably rings lose oil at higher RPM and load while valve guide seals lose more in stop and go.
79 Honda CX500
Re: Burning oil, City vs Freeway? [Re: MichaelRS] #5465725 06/29/20 02:55 PM
L
Lubener Offline
L
Every car I had which used some oil always used more on the highway. My guess, higher RPM.
The "thinking" man's friend.
