Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
97 registered members (72te27, 4WD, 55hambone, BeerCan, antonmnster, Avery4, 7 invisible), 1,766 guests, and 20 spiders.
Topics307,463
Posts5,311,644
Members71,852
Ford 4.2 Misfire: Clean EGR Port via Seafoam? #5464919 06/28/20 01:37 PM
N
nobb Offline OP
N
Hi guys,
I'm trying to diagnose a 2006 Ford Freestar with the 4.2 of which the engine runs rough with a P0301 check engine light indicating a misfire on cylinder 1. Apparently this engine is known to have plugged EGR injection ports which require pulling off the intake to mechanically clean. To test if it was an EGR issue causing the misfire, I unplugged the vacuum line going to the EGR valve and miraculously the engine runs smooth.
Before spending the effort pulling the whole intake manifold apart (it's alot of effort), I'm wondering if there would be any value in trying to inject Seafoam down the intake or vacuum line on the EGR valve? Would this knock off any of the carbon? Sorry if this is a noob question as I'm not that familiar with the EGR system. The intake manifold gaskets are also quite expensive, but they look like they should be reusable.
Thanks!
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5465111 06/28/20 07:24 PM
N
nicholas Offline
N
Seafoam cleans nothing. Use CRC intake cleaner.
That stuff really works.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5465142 06/28/20 07:53 PM
B
buddylpal Offline
B
I think member BlueOvalFitter had this issue on his F150 4.2 when it was new back in 2007 or so. IIRC it was some sort of carbon buildup issue.
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5465147 06/28/20 08:00 PM
CR94 Online Content
Online Content
That seems to me unlikely to work, but I could be wrong. Keep us posted on progress.
My Toyota is supposedly susceptible to the same problem--- along with carbon clogging of the EGR cooler (heat exchanger).
2011 Toyota Prius now at 111K
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5465219 06/28/20 09:27 PM
N
nobb Offline OP
N
Well, I decided to not half arse this and do it properly. I saw this video from FordTechMakuloco who suggested all you have to do is take off the upper intake manifold (on the Ford 3.8 and 4.2), then just clean out the EGR injection ports with a coathanger:
https://www.youtube.com/watch?v=08IxhqpuQ3I
I took off my upper intake manifold and to my surprise, there is no individual EGR injection ports as suggested in the video! If I follow the EGR valve, it seems to take the exhaust gas right behind the throttle body.
However, upon further inspection it looks like one of the IMRC bushings for the linkage corresponding to the cylinder 1 bank of valves fell off. Not sure if this got knocked off when I pulled the intake manifold, or if this was the cause of my misfire. I guess I'll have to buy the part, put it all together and find out. It's just strange that the failed IMRC linkage controls the valves on cylinder 1, 2, 3, but my misfire is only on #1.
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5465243 06/28/20 09:59 PM
bdcardinal Offline
Those bushings are common. I force our system to keep a bunch of them in stock since they seem to sell in waves.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: bdcardinal] #5469604 07/04/20 04:30 PM
L
Linctex Offline
L
You are a walking Ford encyclopedia!
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: Linctex] #5469656 07/04/20 05:50 PM
bdcardinal Offline
F5RZ-9F955-AB is your p/n for most of them. The 3V engines use different clips, but for yours that is the number.
Re: Ford 4.2 Misfire: Clean EGR Port via Seafoam? [Re: nobb] #5469723 07/04/20 07:21 PM
M
mattd Offline
M
The EGR system will not cause a single cylinder misfire. Does it miss all the time, under load, is the engine light flashing...?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
