Forums Migration
Please read this thread
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
92 registered members (28oz, 01rangerxl, 2K2AcuraTL, 2015_PSD, 4WD, 1911CHAMPION, 12 invisible), 2,022 guests, and 42 spiders.
Topics307,633
Posts5,314,702
Members71,894
Check Sunroof Drain Tubes periodically #5464804 06/28/20 10:53 AM
9
97tbird Offline OP
9
This is something anyone who owns a car with a sunroof should do occasionally, esp if you park outside under trees a lot: check to make sure your drain tubes are not obstructed. (slowly pour water down the drain tube openings on either side of sunroof "tray" test, to see if water drains to outside of car, as it is supposed to)
If drain tubes are clogged, water WILL find its way into the headliner, A pillar and if the clog is further down, expect a very wet carpet and floorpan. One may not notice this in time, unless it is after a huge rainstorm where the amount of water is hard to miss inside the car - otherwise it happens SLOWLY overtime, while mold and nasties can be happily growing without you knowing.
- Clean the sunroof "tray" occasionally, make sure it is free of debris.
It seems most people who chase a leak in their cars hardly ever think of this as the cause, and even professionals don't think of it much.
IF drain tubes are clogged, and don't pass the "water test", one can use weed trimmer line, or a speedometer cable (from a kit, with unfinished ends) and as a LAST resort, compressed air.
(I had success with weed trimmer line 0.095 size, and warm water - and luckily I noticed the 1st signs very early on after several days of heavy rains, which show the signs quicker).
READ THIS: (The article contains a video about on how bad this can be)
Damage From Clogged Sunroof Drains
WATCH THIS:
Sufficiently Caffeinated...
Cars: 1997 Thunderbird v8 sports(sold), 2003 Elantra GLS (totaled at 225k), 2005 BMW 330Ci ZHP, 2014 Mazda 6 Touring, 2010 Ford Escape Limited v6 AWD
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5464867 06/28/20 12:42 PM
L
LazyDog Offline
L
You also need to pay attention to the cowl drains that are by the wiper motor. You either have drains on booth sides or the metal slopes to just one side.
In my 98 Volvo, it has a drain in the passenger side that clogs and water enters the car by the air intake above the fan.
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5464921 06/28/20 01:40 PM
B
BHopkins Offline
B
When I bought my wife's Outback, I learned on the SubaruOutback discussion board that this is a common problem. So I adopted a PM procedure of shooting a mixture of hot water and heavy duty cleaner, such as Simple Green or Purple Power, down each of the four sun roof drains. I use a 60 ml veterinary syringe with a short length of 1/8" id x 3/16" od tubing on the end. This tubing fits perfect in the sunroof drains on the Outback.
The rear drains are typically quite hard to reach. So for them, I used a stainless steel stiffener from a used windshield wiper blade, and heat shrink tubing to attach a length of the same tubing. This makes the tubing stiff enough so I can guide it into the rear drain holes.
For cleaning drains that are already plugged, many use string trimmer line to push down the drains. String trimmer line is stiff enough that it can easily be pushed down the drain and push any debris out of the way, but flexible enough to bend with the shape of the drain. I am planning on starting to use the string trimmer line even for my PM. I'll just need to modify my tool to guide the string trimmer line into the rear drain holes.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5464926 06/28/20 01:47 PM
L
Little_Lebowski Offline
L
On my 06 Range Rover Sport i blow out the front drain tubes every month.
If i get lazy I'm soon reminded by the swimming pool on passenger side floor.
These Rovers are notorious for this.
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5464932 06/28/20 01:59 PM
J
JohnG Offline
J
Quote
Not a great idea to use compressed air. You run the risk of blowing the line off of the connection fitting inside the roof, THEN you will have problems!
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5464983 06/28/20 03:29 PM
Bud Offline
Great idea. Thanks for the reminder.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5465054 06/28/20 05:38 PM
Z
Zaedock Offline
Z
My wife had a spider and web in one of the drains in her old Malibu Maxx. I used a syringe and the dude popped out the drain (inside door / fender area).
Didn't expect to see him.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5465088 06/28/20 06:49 PM
9
97tbird Offline OP
9
LAZYDOG:
Thanks for the tip re: cowl drains - I was planning to remove the "cowl" and clean the area underneath- that piece is badly sun-faded and needs detailing, anyway - prob easier to detail out of the car.
Re: Methods: I also used a syringe and tubing when I was "de-clogging it" using the trimmer line. I used hot water in the syringe to "squeeze" into the tubes, at the same time wiggling the trimmer line - worked really well.
I had compressed (not regulated) air ready but will only have used as a last resort - I was also afraid of dislodging the tube inside the A pillar.
Not sure about harsh cleaners like degreaser down the drain tubes - I am afraid they can be bad for the rubber tubes in the long run, I guess you can always flush with plenty of soapy water after using them?
I was able to clean the sunroof "tray" really well (the area between the 2 drain holes). This is where all the pollen/dust/leaves and crud collects which eventually make its way to one or both drain tube openings. Keeping this area clean and waxed is important: it will make it harder for crud to "cling" to that area, and the water will flow easier to the tubes without sitting there.
I am going to make the Trimmer line feeding and cleaning the sunroof tray area maintenance item part of at least a 6-monthly routine.
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5465173 06/28/20 08:29 PM
spk2000 Offline
Would a 22 rifle cleaner work?
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5465645 06/29/20 01:04 PM
J
JohnG Offline
J
Quote
Too stiff. Not long enough. LOL
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5465767 06/29/20 04:00 PM
9
97tbird Offline OP
9
I say weed trimmer 0.095 weed trimmer line (about $6 at Lowe's) or if you need something a bit thicker: Speedometer cable (with non-terminated ends; if you get a "kit" from AZ or AA you can get that, it's about $6). I have read some use "fishing line" but i have no clue which one to get - I just went with weed trimmer line and had a speedometer cable as backup.
I'd guess for most cars you'll need at least 5-6 feet to be safe.
These 2 "tools" seem to be the most popular and successful at this job. (I feel like I read everything on the www when I needed to do this LOL)
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5466474 06/30/20 04:15 PM
super20dan Offline
this is my first and last car with a sunroof. drain is clogged on one side and requires the wiper cowl to come off to access it.
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Check Sunroof Drain Tubes periodically [Re: super20dan] #5466991 07/01/20 10:36 AM
9
97tbird Offline OP
9
Yeah I never WANTED sunroofs either - they just had them on my 2 used cars (BMW and the Ford) - on wife's Mazda bought brand new, we were able to "escape" it.
Which car is that you have to take the wiper cowl off? Most cars route them through the A pillar and onto the fender behind front tire. Have you tried de-clogging from the top of the sunroof?
Removing cowl requires removing the wipers, of course.
Like stated in this thread, I am going to check the under-cowl drains on for clogging today on the Escape. Although the sunroof drain tubes are now free and fixed, i want to eliminate all possible leak areas before car goes tested in a heavy downpour again.
I have seen YT videos where people remove wipers without the tool, and just by wiggling and pulling them off. Hopefully that works, if not I will have to go to Adv auto and get a wiper removal tool.
Re: Check Sunroof Drain Tubes periodically [Re: 97tbird] #5468564 07/03/20 09:18 AM
endeavor to persevere Offline
I have to do this on my wifes 2016 Nissan Rogue with the panoramic sun roof. The front driver side will stop up and get the carpet wet. She is not a happy camper when this happens. I run some trimmer line down it followed by compressed air. Hasn't happened in a while.
