How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
87 registered members (555, ARCOgraphite, 2K2AcuraTL, 2015_PSD, 1978elcamino, 64bawagon, 6 invisible), 1,296 guests, and 21 spiders.
Topics307,317
Posts5,308,856
Members71,828
Wix question #5464523 06/27/20 10:09 PM
G
Granitepeak Offline OP
G
I am new to the forum.
I bought a Wix filter which is very different from the Fram equivalent. The ports are tiny holes unless built into the filter in a way I cannot see it. Concerned about flow rate. Picture attached.
Thanks
Don
Re: Wix question [Re: Granitepeak] #5464526 06/27/20 10:14 PM
Z
zfasts03 Online Content
Online Content
Z
What application? What part number? Doesn't look right!
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Wix question [Re: Granitepeak] #5464536 06/27/20 10:31 PM
G
G
WIX Oil Filter 51050 replacing Fram PB50
It is for my 1956 MHF tractor to which I converted to a spin on with a kit
Re: Wix question [Re: Granitepeak] #5464540 06/27/20 10:40 PM
J
jhellwig Offline
J
Look at the bolt from the original canister. I would be concerned about too much flow since it is just a bypass filter.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Wix question [Re: Granitepeak] #5464542 06/27/20 10:44 PM
dogememe Offline
I looked at a pic in the computer of a Wix 51050 and it only has two little holes in the base plate
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Wix question [Re: jhellwig] #5464559 06/27/20 11:02 PM
G
G
The adapter came with the Fram, which has what I would call more typical flow ports
Pic attached from MF showing original canister type.
Not sure what you mean about bolt size or having to much flow.(new to this type of discussion)
Thanks
Re: Wix question [Re: dogememe] #5464562 06/27/20 11:05 PM
G
G
Exactly, but how could that be correct?
Thanks
Re: Wix question [Re: Granitepeak] #5464564 06/27/20 11:07 PM
G
G
Picture of the kit
Re: Wix question [Re: Granitepeak] #5464570 06/27/20 11:29 PM
Z
ZeeOSix Offline
Z
If it's supposed to be a full flow filter, then one tiny inlet hole isn't going to be good. Does the filter conversion kit say to use what filter by brand/model, and if so does it list different brands and models of filters to use?
Re: Wix question [Re: ZeeOSix] #5464572 06/27/20 11:36 PM
G
G
I had previously been told that the original filtration system was bypass. Someone did a write up to convert the system to full flow. The kit came with the Fram PB50.
Thank you everyone for helping!
Re: Wix question [Re: Granitepeak] #5464588 06/28/20 12:45 AM
M
mattwithcats Offline
M
Try RockAuto, but watch the shipping...
https://www.rockauto.com/en/parts/fram,PB50,oil+filter,5340
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Wix question [Re: Granitepeak] #5464675 06/28/20 07:41 AM
K
Kira Online Content
Online Content
K
Try taking additional photos using different lighting angles. I, for one, cannot tell what I'm looking at.
How long ago did you convert your system?
Re: Wix question [Re: Granitepeak] #5464699 06/28/20 08:18 AM
A
ARCOgraphite Online Content
Online Content
A
OP: Is there a small hole ( for restricting flow ) in the adapter in the Fram kit or is it a large dia drill thru?
If both are different, someone designed it incorrectly.
If the Fram kit Adapter restricts it, then further inline restrictions should not pose and issue in this application.
Further restrictions being the small inlet and outlet holes in the wix. Bat all this adds possibilities of plugging with flotsam.
If the original M-F canister was a bypass, the WIX wouldn't cause an equipment failure, but the kit would become ineffective.
What is the flow capability ( assessment) of the original canister and cartridge assembly that came on the M-F tractor?
Assess by the thru hole diameters at various junctures. Use the smallest as your primary restriction gauge.
A field of holes at any juncture on a surface must have their port areas combined - not addressed singly.
- Ken
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Wix question [Re: Kira] #5464708 06/28/20 08:40 AM
G
G
About 6 months ago.
So it seems that the Fram has a small hole port in the middle and 6 larger holes closer to the seal. The Wix has a small hole in the center and 2 holes closer to the seal.
When built, came from Massey with a bypass filtration system using a replaceable element in a canister.
The spin on kit which came with the Fram used a bypass filter. Now I wonder if that should be a full flow filter given the system is already of bypass design or might that cause a pressure drop.
48CA6DFF-9BD2-4CD9-8C4E-C7A898A1EE81.png09A89472-D6C9-42CE-A1CD-694ED4A35625.jpegB76A37F7-0F86-4102-B752-50515CA5EFDF.jpeg
Re: Wix question [Re: Granitepeak] #5464719 06/28/20 08:53 AM
A
Online Content
A
Yeah, but the Adapter piping? IS that restricted on the Fram kit?
