FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
52 registered members (BAJA_05, Astro14, AlienBug, 94astro, AndyB, alarmguy, 3 invisible), 1,093 guests, and 21 spiders.
Topics307,398
Posts5,310,374
Members71,843
Clean that Condensor ! #5463980 06/27/20 09:15 AM
W
WobblyElvis Offline OP
W
Just thought I'd pass this on.
I have an old 99 Dodge Caravan [ I know, don't laugh] and the AC was giving a bit of problem. The high side pressure was relatively high while the low side was low and the vent temperature was wavering in the 50F range. I first added a little refrigerant but only the high side pressures increased. I thought I had a restriction somewhere but as a last resort I did a minor cleaning of the condenser. Big improvement, I haven't checked the pressures yet and I probably won't as the vent temperatures dropped to the 40F range.
The condenser [original] was dark grimy in colour but it had no bugs stuck in it and very few if any bent fins. A flash light shone through it quite well so I originally didn't suspect it was the problem. I simply took a spray bottle, loaded it with warm water and about %20 dish detergent and sprayed it as best I could through the grill without removing any bumper/grill parts. I let it soak 5 minutes and repeated process. After waiting another 10 minutes I hosed it off, being careful not to bend any of the aluminum fins. The condenser doesn't really look much cleaner but shazam....success!
Recommend this maintenance if you live in a hot climate.
Re: Clean that Condensor ! [Re: WobblyElvis] #5464022 06/27/20 10:26 AM
M
mikered30 Offline
M
Yep, works wonders, Eric the car guy did pressure readings pre and post condenser cleaning and showed a noticeable decrease in pressure, although his condenser may have been wet when he did the post readings.
https://www.youtube.com/watch?v=r_em9lm69HQ
Re: Clean that Condensor ! [Re: WobblyElvis] #5464028 06/27/20 10:33 AM
F
Falcon_LS Offline
F
I've been using Virginia Alki-Foam Condenser Coil Cleaner for quite some time now. I bought quite a stash of the stuff, and use it every 6 months. It works wonders in 1:1 concentration!
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Clean that Condensor ! [Re: mikered30] #5464166 06/27/20 01:38 PM
A
A_Spruce Offline
A
The same exact guy and video I thought of immediately when I saw this post! thumbsup I'm thinking about doing it to my truck. cool
'03 Suburban
Re: Clean that Condensor ! [Re: WobblyElvis] #5464207 06/27/20 02:45 PM
M
MasterSolenoid Offline
M
OP - Good idea, especially since you say it looked good visually.
I would imagine this will also work on Radiators & Transmission Coolers as yearly PM.
I always try flushing from the 'back to front' to more easily dislodge anything.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Clean that Condensor ! [Re: A_Spruce] #5464211 06/27/20 02:49 PM
Yah-Tah-Hey Offline
Make a bug screen out of window screening,a few grommets, clamps and ty-raps and that problem can be avoided.
Re: Clean that Condensor ! [Re: Yah-Tah-Hey] #5464286 06/27/20 04:12 PM
A
A_Spruce Offline
A
I've done that in the past, but not with this vehicle, and not something that 98% of the population is going to do. In Eric's video, the vehicle he was working on had no visible signs of issue with the condenser, but he washed it out anyway. The before/after results were significant in the temperature blowing out the vents, and all that was done was clean the condenser.
'03 Suburban
Re: Clean that Condensor ! [Re: WobblyElvis] #5464331 06/27/20 05:15 PM
Z
zrxkawboy Offline
Z
If you ride a motorcycle and happen to have some S100 cleaner on hand, that works quite well for cleaning grime out of condensers, etc. Spray on, let it sit a few minutes, and hose off.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Clean that Condensor ! [Re: A_Spruce] #5464375 06/27/20 06:00 PM
A
artbuc Offline
A
Vent temp did not change after cleaning but high side pressure did decrease substantially. However, I wonder if Eric let the condenser dry before checking the pressure? Wetting a condenser will make a big impact on overall heat transfer coefficient.
Re: Clean that Condensor ! [Re: artbuc] #5464381 06/27/20 06:11 PM
A
A_Spruce Offline
A
My bad, going from memory, thought the vent temp went down as well as system pressure.
'03 Suburban
