Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
111 registered members (72te27, 4WD, 55hambone, 2015_PSD, A310, AandPDan, 10 invisible), 1,927 guests, and 23 spiders.
Topics307,462
Posts5,311,611
Members71,850
Urethane adhesive to fix leaking windshield #5463937 06/27/20 08:16 AM
M
MoneyJohn Offline OP
M
I posted this question before at https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5380099.
Trav and others suggested using flowable silicone. I used as mentioned in some of the YouTube videos. It worked for a couple of months. Last week, I got the car washed and noticed water on the EZ pass transponder. So instead of trying to fix it myself, I took it to the mechanic. He doesn't do windshield work and directed me to a local auto glass place.
As I was expecting, they tell me its not worth fixing it and they would replace a windshield for ~$600 (glass+labor, including cleaning the leak area. They suspect its rusted at the leak point, by the bubbles on the top of the roof).
TBH, I do not want to spend that money at the moment, so I am going to see if I can use anything else.
A little bit of googling tells me that silicone can expand and contract depending on the temps so I wonder if it makes sense to use Urethane sealant? If it does, can I use https://www.amazon.com/Aleenes-Liquid-Urethane-Adhesive-4-Ounce/dp/B00KD6YW46
If at all it doesn't work, and I can at least get through 'virus-related job-on-the-line' time period, I know, I am going to replace the windshield.
Thanks in advance.
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5463948 06/27/20 08:35 AM
W
wog Offline
W
Flex seal? Made a screen door floatšŸ˜¬
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5463951 06/27/20 08:37 AM
B
BigD1 Offline
B
I used Lexel years ago to seal up a leak on a windshield, and it is still working. I bought the five ounce tube from a local hardware store.
https://www.lowes.com/pd/Lexel-5-fl-oz-Clear-Paintable-Solvent-Caulk/1000269867
1992 Toyota Pickup--SuperTech 10W-30 conventional--Fram PH3614
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5463958 06/27/20 08:49 AM
L
Lubener Offline
L
I always had good results with Permatex flowable silicon.
https://www.amazon.com/Permatex-81730-Flowable-Silicone-Windshield/dp/B000BKEBO0
The "thinking" man's friend.
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5463982 06/27/20 09:22 AM
doitmyself Offline
I wonder if some kind of commercial window seal tape might work : https://www.ebay.com/i/123980815502...chpii6gIVRdbACh0szg5JEAQYAiABEgLdXvD_BwE
[Linked Image from ]
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5464003 06/27/20 09:53 AM
F
Fattylocks Online Content
Online Content
F
Plumbing tape. Won't be pretty but neither is bubbly rust.
https://tchristy.com/product/2-wide-x-100-20-mil-thick/
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: Urethane adhesive to fix leaking windshield [Re: Lubener] #5464006 06/27/20 09:57 AM
T
Trav Offline
T
Same here.
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5464014 06/27/20 10:10 AM
spavel6 Offline
Use Dow U-428Plus with a hand calk gun. This is the ONLY way you will seal it permanently. It's the urethane that is used to install your windshield. Yes, it's a large tube, but it's only ~$13 on amazon. It's also very messy, so be prepared with gloves. It comes off with acetone if you need to take off "oopsies".
One trick is to heat it in a big pot of almost boiling water for a few minutes to get the tube warm and flowing better.
Dow U-428 Plus
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5464041 06/27/20 11:03 AM
J
JTK Offline
J
My Ram 2017 Ram 1500 had the rear glass replaced very poorly at some point before I bought the truck used. The rear glass leaked water badly. My glass guy had to remove it and re-install it. He initially tried applying a bead to the inside of the glass, but that didn't work and it all had to come off. I didn't think to ask him what he though the previous "installer" used in terms of sealant, but I think the guy I use, uses a 3M product.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5464066 06/27/20 11:54 AM
B
benjy Offline
B
Betaseal U-418 quick cure primerless to auto glass urethane adhesive was used to set an aftermarket sliding rear glass in my truck, but i would try 100% silicone thats 100% get clear, sets in about 10 min. clean as good as possible before + since its a beater you can leave a bead exposed. read how to use it on line, good luck! i caulked 1/4" spaces required between composite flooring years ago, still no leaks!!
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5464076 06/27/20 12:03 PM
J
JimPghPA Online Content
Online Content
J
Years ago I went to the local NAPA and asked them for something for a windshield leak. They recommended a fairly thin black rubber type glue / sealant that came in a decent size squeeze tube. It is a little messy to work with so you have to be slow and neat with using it. It sealed the leak in my cars front window, and I drove it for many years after that and it never leaked. I used it on a few things for a few years, and a neighbor had a pair of cheep shoes she liked but the sole was falling off, and I used up the remainder of it to fix her shoes.
You might check your local NAPA to see if they still offer it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Urethane adhesive to fix leaking windshield [Re: spavel6] #5464105 06/27/20 12:29 PM
T
Trav Offline
T
Do not make blanket statements like that are blatantly false.There is vary rarely just an "only" way or only product that can do the job.
The trick is to get it in the area of the crack/split in the original install material, it will flow into the damage and seal it. The thicker stuff sits on top of the damage and tries to make a new seal.
Re: Urethane adhesive to fix leaking windshield [Re: MoneyJohn] #5465609 06/29/20 12:05 PM
N
nthach Offline
N
The best way to fix it to find a competent glass guy who can take care of the rusted pinchweld. For now, flowable silicone is probably a good band-aid.
Was the windshield ever replaced with non-OEM? I've seen rusted pinchwelds cause this, and its almost always careless or rookie installers who cause this. Dow, Sika, Dinitrol and 3M are very adamant about using their urethane systems as a whole and mandate if ANY metal is scratched, their black primers for metal prep is to be used ASAP to prevent rust. All of them prescribe repair and epoxy primer(like PPG DP40LF) if the pinchweld is too rusty beyond sanding to reveal fresh metal/
