Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
37 registered members (Ausfahrt, blufeb95, 53' Stude, 2009Edge, bismic1, 5 invisible), 669 guests, and 23 spiders.
Topics307,747
Posts5,316,945
Members71,910
Replace AC condensor fan as preventive maintenance? #5463755 06/26/20 11:24 PM
M
motor_oil_madman Offline OP
M
Anyone replace their outside condenser fan as preventative maintenance on their house HVAC system? I think a lot of older systems don't have any kind of fail safe, so I imo if the fan fans outside, then the unit is going to keep running until the head pressure goes insanely high and probably starts leaking out. I believe my dad just replaced the whole system once shortly after he had someone put a new fan in. I guess it had problems after that.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463776 06/27/20 12:42 AM
P
PowerSurge Offline
P
Unless it’s not running correctly, I’d leave it. Condenser fan motors have been known to run 20-30 years or more. I do check the capacitor every spring.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463793 06/27/20 02:26 AM
ctechbob Online Content
Online Content
I keep a spare capacitor on hand, but other than that, no. If the compressor is running with no fan it should slam right into the thermal cutout to save itself. Probably not the best thing for it, but it shouldn't burn up.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463808 06/27/20 03:04 AM
Skippy722 Online Happy
Online Happy
Nope. When it starts making abnormal noise then I’ll replace it. But man, that York unit is almost silent!
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463817 06/27/20 04:08 AM
dishdude Offline
Ridiculous. sailing
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463822 06/27/20 04:28 AM
L
Lubener Offline
L
The motor's current draw will determine its condition. They last a loooong time. The only item I have changed as PM when my outside unit hit the ten year old mark was the multi section capacitor. For roughly $89 you could have a qualified person pay you a visit and perform a P.M. on your system.
The "thinking" man's friend.
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463844 06/27/20 05:47 AM
A
Amkeer Offline
A
10-15 years is when the whole system should be replaced.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Replace AC condensor fan as preventive maintenance? [Re: Amkeer] #5463873 06/27/20 06:47 AM
P
PowerSurge Offline
P
Negative. If a system has been reliable, run it until it dies unless you just want to upgrade and have money to burn or you have an R-22 leaker. The power savings going from say a 10 SEER to a 14 isn’t as great as a lot of companies promise.
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5463929 06/27/20 08:06 AM
I
irad Offline
I
I have oiled the condenser fan. The unit stopped turning and was hard to turn manually. I oiled it and spun it by hand until it kept spinning when turned by hand with the power off. It has been at least 5 years ago. My daughter has since sold that house but I assume it is still running. So non detergent oil either through an oil port or directly where the shaft meets the motor body. You could open up the motor and clean and grease/oil the bearings.
Re: Replace AC condensor fan as preventive maintenance? [Re: Amkeer] #5463970 06/27/20 09:01 AM
L
Lubener Offline
L
Nope. Mine is running like a champ at 20 years. A sales person might say something like that. At 13 Seer, cannot justify replacing a working system just because it is old. You won't realize a ROI for many years.
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5464099 06/27/20 12:23 PM
M
M
I had the a.c. guy out a last month and he said the motor was leaking. Isnt it just a sealed bearing with grease? He also said he's seen them leak for years and be fine. The voltages and pressures looked fine when he hooked up to the condenser unit.
Re: Replace AC condensor fan as preventive maintenance? [Re: Lubener] #5464106 06/27/20 12:29 PM
M
M
Yeah they consider the newer units to be old and due for replacement after only like 12 or 13 years now, so I prefer the old one just stay running. The electric bill during the summer is only like 80 bucks.
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5464156 06/27/20 01:28 PM
A
A_Spruce Offline
A
Fan replacement no, if it's that far gone that you need to change the fan, then change out the whole unit. Otherwise, lubricate the shaft seasonally, or spring/fall if running a heat pump, since it will run year round. As long as an electrical check-up tests fine, lube the fan and forget it.
The last condensor problem I had was the capacitors gave out. Cheap fix.
'03 Suburban
Re: Replace AC condensor fan as preventive maintenance? [Re: PowerSurge] #5464312 06/27/20 04:49 PM
B
BISCUT Offline
B
I'm with you....I have R22 and so far it still cools so I pray each and every June!!!!!!!! Where I'm at I need it June July August and a week or so into September.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(48k)
2017 Sub OB M1 5-30 EP FRAM Ultra(78k)
Re: Replace AC condensor fan as preventive maintenance? [Re: motor_oil_madman] #5464322 06/27/20 04:59 PM
spasm3 Offline
My r22 system is getting old, 4 ton unit.
16 years on the compressor, the attic coil is 24 years old.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
