FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
55 registered members (Astro14, BAJA_05, AlienBug, 94astro, AndyB, bmod305, 5 invisible), 1,120 guests, and 22 spiders.
Topics307,398
Posts5,310,377
Members71,843
Page 1 of 4 1 2 3 4
Who's using Liquimoly Molygen? #5463674 06/26/20 08:46 PM
TiGeo Offline OP
I switched over to the Molygen last change and will be changing it out next week with a fresh batch at 40M on my 2018 VW Golf Sportwagen that's turbo-swapped and tuned. I've been doing UOAs since new and have used LM's Leichtlauf High Tech 5W40 since the first change at 7.5k. I've used Ceratec and MoS2 friction modifier additives. The Molygen has it's own friction modifier they call MFC (Molecular Friction Control) and it's tungsten-based; no news to use a separate additive and in fact LM specifically says not to use Ceratec with Molygen. They have confirmed that using MoS2 is ok. I've done a VOA on it which is posted in the appropriate sub-forum. Finally, I realize this oil does not actually have any OEM approvals and is only "recommended for" which does pose questions for the warranty worry-warts. The VOAs indicate that this is basically Leichtlauf with the MFC and green color/additive that fluoresces under UV light (that FCP Euro includes with the oil change kit) which, IMHO, is why it doesn't have the approvals...quite sure it meets the necessary specs. I've been accused of being a LM fan-boy but honestly, it's decent oil, works well in my application, they have good customer service if you have questions, and I like to buy the pre-made change kits from a few different online Euro suppliers that support the VW "scene". I pay about $65 delivered for 6 qts of oil, a Mann filter, and a drain plug. I don't think that's much for something I do 3-4x a year for a high-performance car (albeit my daily) but yes, it's more than a run to Walmart for Mobil 1 or Castrol 0W40 VW502 00. Did I mention it's green and looks like Predator blood? Discuss amongst yourselves.
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly Molygen 5W40 VW filter
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463680 06/26/20 08:54 PM
sloinker Offline
Is that a 502/504 specification....whatever meets that and is least expensive is the go to advice on this board. If it was mine:
https://www.blauparts.com/ravenol-c...N2S-u3rgpxA2XzJAQPNINtE3HfIaAsLfEALw_wcB
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Who's using Liquimoly Molygen? [Re: sloinker] #5463685 06/26/20 08:59 PM
TiGeo Offline OP
It would effectively be a "502 equivalent" - doesn't actually have the approval but likely meets/exceeds the specs for that approval. This board seems to have an obsession with the cheapest oils that meet approvals and while I get that angle, it's also fun to use/discuss stuff that isn't especially on a car that I've spent significant dollars on upgrades to add power/drivability. Not everyone cares about saving a few bucks, hoarding stocks, and rebates. I get it, but it's not me on this car. My UOAs have looked great.
Re: Who's using Liquimoly Molygen? [Re: sloinker] #5463687 06/26/20 09:02 PM
TiGeo Offline OP
What is the deal with Ravenol? I've heard folks talk about it, almost like it's mythical! Just very good stuff? Mostly "real" syn base?
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463758 06/26/20 11:43 PM
J
Jimmy_Russells Offline
J
This stuff just seems like a total gimmick to me. I would use LM sure but what is the point of this? UV tracer dyes already exist if you are trying to find a leak.
Ravenol is real group IV with OEM approvals, not many of those out there.
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463759 06/26/20 11:44 PM
CleverUserName Offline
Yeah supposedly they mostly use Group IV in there "Vollsynth" CleanSynto labeled oils. They do have impressive specs on paper, but the company is very secretive with normal documentation like an MSDS.
I contacted their German office once for the MSDS on some of their oil after blauparts ignored my request. They basically told me to to "prove" that there could be people exposed in a work setting to the oil. I've never experienced anything like this, a total lack of transparency on something basic like an MSDS.
I think Ravenol and Rowe have better base oils than LM. It is very difficult if not impossible to find a LM oil that is not primarily group III that is sold in NA.
Re: Who's using Liquimoly Molygen? [Re: CleverUserName] #5463766 06/27/20 12:16 AM
edyvw Offline
Wasn't Ravenol involved in some scam with oils?
I remember Ravenol from Europe, before moving here to US. It was always afterthought of an oil. I mean on paper they look good o paper, but cannot escape feeling of newcomer that is pushing that German aura, same like LM.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463770 06/27/20 12:30 AM
sloinker Offline
Double post
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463773 06/27/20 12:33 AM
sloinker Offline
There is an SDS for the VMP I use online. Doesn't tell you much unless you read between the lines. White oil like PAO and many esters aren't hazardous under the SDA protocol's so they only list the toxic portions.
Google the oilchoice russia VMP 5W30 sds and it will show up as a .pdf download
I think it must be the real deal as they have spent the time and money for formal approvals. Maybe someone can get the PQIA to take a look and see what they see.........
Re: Who's using Liquimoly Molygen? [Re: sloinker] #5463800 06/27/20 02:43 AM
PAO is usually listed in an SDS but it has another name.
It’s POE and other esters which aren’t.
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463809 06/27/20 03:14 AM
Marco620 Offline
Do as you like. I too jumped back on the Redline train today. I enjoy helping small local Kansas business and getting great oil with a easy pour spout.
15' Civic r18, 342,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: Who's using Liquimoly Molygen? [Re: TiGeo] #5463840 06/27/20 05:42 AM
wemay Online Happy
Online Happy
TiGeo, I've never been a LM fan or hater, but may pull the trigger on Molygen in the future as I'm intrigued. My biggest concern with that is bumping up to a 5W-40.
I'm even more "off the rails" than you guys. Been considering Mobil1 EP 0W-20 for the Passat. The GTX Magnatec I was considering will go in mom's HRV. I still have 2-cases of the VW branded 508 to go through, but my wavering opinion and world events may change that landscape too. crazy
19 Passat Wolfsburg TSi, GTX Magnatec 5W-30 - CH11784
13 Santa Fe Sport 2.0T, GTX Magnatec 5W-30 - M1-104A
Re: Who's using Liquimoly Molygen? [Re: CleverUserName] #5463855 06/27/20 06:18 AM
sloinker Offline
Yep, I know that it usually is. This SDS shows a few ingredients but not % by volume.
Re: Who's using Liquimoly Molygen? [Re: Jimmy_Russells] #5463876 06/27/20 06:48 AM
TiGeo Offline OP
For sure there is wow/gimmick involved here. UV dye and a friction modifier. Cool name. They sell a ton in the VAG community.
Re: Who's using Liquimoly Molygen? [Re: CleverUserName] #5463884 06/27/20 06:54 AM
TiGeo Offline OP
So as I said...."mythical"! ahahahah
The Group 3/4 thing - doens't really matter to me but I know some folks are obsessed with it. LM has Group 4 syn oils butt hard to find here I think. I believe this is the one and it is labeled as "fully synthetic":
https://products.liqui-moly.us/oils/synthoil-energy-a40-sae-0w-40-1.html
Page 1 of 4 1 2 3 4
