Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
27 registered members (4WD, Donald1953, Char Baby, doolah02, ctechbob, 3 invisible), 566 guests, and 40 spiders.
Topics307,389
Posts5,309,626
Members71,821
Broken manifold bolts and sealing the manifold.. #5463629 06/26/20 07:26 PM
J
joshuawesl Offline OP
J
Wrenching on my 2003 Durango 4.7L, and I'm replacing exhaust manifold gaskets.
The driver's side manifold came off easy with ZERO bolts breaking off. I was able to replace the gasket on that side easily. The passenger side is a different story. It's being a royal pain in the butt. I've been able to extract all but TWO bolts that have broken off flush with the engine. They're just not coming out. Not even some heat from a oxy-acy torch could get them to cooperate. My only option to removing them is to drill the entire bolt out, and I'd rather not do that.
The broken bolts are on the same port, one above the other, kinda. One is at 1 o'clock and the other is at 7 o'clock. The third port from the front of the engine.
I've been thinking about doing something I absolutely do not like to do, and that's to cut a pretty sharp corner here. People are going to sneer at my idea, because it's not a very good one, but in the words of Mr. Heemeyer, sometimes reasonable men must do unreasonable things. Or something like that.
Of course I have new gaskets and new hardware..
What if I grab some really high temp sealant and apply some to both sides of the gasket when reinstalling the manifold, and just leaving the broken bolts where they are, as it appears they're pretty happy with not moving...
Sure, all of the other studs and bolts would be in place to clamp down the manifold, except for in the one area where the two broken ones are.
Thoughts from the shadetree and pro-wrenchers, please?
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463632 06/26/20 07:28 PM
R
Rand Offline
R
do it once do it right. buy tools if you need to.
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463635 06/26/20 07:36 PM
W
WyrTwister Offline
W
Start out with a small drill bit and work your way up , maybe , using left handed drill bits .
If it has not come out with the drill bits + penetrating oil , consider an appropriately sized ezy-out .
Wyr
God bless
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463636 06/26/20 07:37 PM
P
philipp10 Offline
P
Wonder what it would cost at this point to tow it in to a local shop and have those bolts extracted?
Re: Broken manifold bolts and sealing the manifold.. [Re: WyrTwister] #5463637 06/26/20 07:38 PM
J
J
Tried that. With and without heat. Broke the EZ out off in the drilled hole.
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463639 06/26/20 07:41 PM
B
bullwinkle Offline
B
It would still leak eventually, the lack of clamp force would allow the gasket to blow out. Any chance of getting one of the maniifold c-clamps on there?
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463650 06/26/20 08:03 PM
J
JimPghPA Offline
J
Is there room to drill it out to a much larger size and tap threads to the larger size? If there is that is what I would do if I were doing that job.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463653 06/26/20 08:06 PM
ctechbob Online Content
Online Content
If you have a welder, you can weld a nut onto the broken portion and back it out that way. SMA has a few videos of that procedure I think of Ford and Dodge both if memory serves.
https://www.youtube.com/watch?v=vDlk7B-PRAA
Should be 11 min in if that is actually the right video.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463657 06/26/20 08:15 PM
Snagglefoot Online Content
Online Content
You were asking about hi temp sealant. Yes, I ran Permatex Ultra Copper and it is crutching me through on my 6.0 Chev with two busted bolts on each manifold at the ends. By the way, it does not contain copper. It only has a copper colour. I did not remove the manifold. I just ran a bead around each flange with the busted bolts.
www.permatex.com
If you want the job done right......do it yourself.
Re: Broken manifold bolts and sealing the manifold.. [Re: philipp10] #5463847 06/27/20 05:59 AM
M
msmoke00 Offline
M
This ^. No sense in taking the chance in them leaking by doing it half way when you've invested this much already. At our shop we will try to weld a nut on if the stud is flush or just sticking out, but if recessed we go to drilling. We've got several sets of the Promaxx guides to help with that, which you could also buy too and diy if you want but my guess is a shop will have about the same cost in it as you buying the tool. I'd also suggest at minimum checking the manifold for true with a machinist straight edge or having them mill planed. Nothing worse than doing all the work to have one tick down the road.
https://www.promaxxtool.com/product/27
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463857 06/27/20 06:23 AM
M
ms21043 Offline
M
Drilling the entire stud out free hand in situ with out damaging the head is just about impossible. You need a drilling jig to have any chance, hopefully you got that broken screw extractor out.
Here's a cheaper drill jig.
https://maniboltdriller.com/product/csb-102-d-chrysler-3-7v6-4-7v8/
...how it's set up on the head.
https://maniboltdriller.com/how-to-tips-tricks/
5W30, whatever's on sale
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5463880 06/27/20 06:52 AM
T
Trav Offline
T
Rule number 27 (I just made that up) , never try to remove a bolt that broke off due to corrosion with an EZ out, broke off going in yes, no problem. Not a very useful comment I grant you at this point, that horse is out of the barn but keep it in mind.
You need to make a small drilling jig, no need to buy one use your manifold as a template on 3/8 flat stock (aluminum is fine) with a drill press. once you have the holes drilled for the correct size bolts eg M6-8 drill the holes in the jig half way though only with a larger size drill, more on that later.
Get some round stock about 10-12 mm O.D. 10 for M6 or 12mm for M8 bolts and cut it into 1/4" and one 1" lengths (you may find washers you can use for the 1/4" ones. Depending on how many bolts the manifold uses for an example we will use 6, drill 5 of these through the middle with the original bolt hole size and the 1" long with a M3 or M4 hole.
The O.D. of these slugs is the size you will drill in the jig plate halfway through. Carefully grind any protruding bolt or tooling flush with a dremel, bolt the plate with the slugs using the smaller slugs and place the long one over the broken bolt by switching the location of the slugs any of the holes can be drilled through the longer one.
The small hole will act as a guide, in the hole with the broken EZ out in it you want to use a right hand drill bit, it will eventually loosen, once it is out go to left hand bits.
Use you original bolts to determine the depth of the drill bit including the slug and put a few turns of tape or drill stop at that point so it cant go past the slug.
Aluminum drills very easy and is easy to work with, for a longer lasting tool I would make the long slug out of steel but its not necessary for a one off job with a few holes.
Once the hole is drilled you can work up on size at a time without the slug, the bit with chase the hole by itself.
I am no expert but this has worked for me many times.
Re: Broken manifold bolts and sealing the manifold.. [Re: ctechbob] #5464027 06/27/20 10:33 AM
W
wag123 Offline
W
+1
This is hands-down the best way to get those broken bolts out. The heat and electricity flowing through the broken bolt during the welding brake the metallic bond and it will usually come right out. If you have broken an easy out in the bolt, you don't really have any other choice. Drilling them and trying to use an easy out is always a waste of time on these IMO.
Re: Broken manifold bolts and sealing the manifold.. [Re: wag123] #5464128 06/27/20 12:51 PM
T
Trav Offline
T
It works great but many times you need to pop the head. Most EZ outs are no big deal with the right drill bit.
Re: Broken manifold bolts and sealing the manifold.. [Re: joshuawesl] #5464189 06/27/20 02:21 PM
R
Rhymingmechanic Offline
R
Dorman and some other companies make repair clamps for broken GM LS manifold bolts. I can't seem to find the same thing for Dodge, but maybe something could be rigged up if you can't remove the bolts yourself. Amazon listings for the part numbers below will have photos that show how they work.
Snagglefoot, these Dorman numbers could be a permanent fix for your 6.0 Chevy:
917-142 Left Front and Right Rear
917-107 Right Front and Left Rear
917-108 Center ports
