Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
100 registered members (4WD, 72te27, Arob, 08z06, 555, 8 invisible), 1,935 guests, and 32 spiders.
Topics307,462
Posts5,311,588
Members71,850
Antisieze #5463608 06/26/20 06:57 PM
A
A_Spruce Offline OP
A
Anyone want to talk about antisieze? There are many flavors out there, why so many, what is each one suited for, can the "best" one be used for all purposes? We should probably stick to talking about a single brand for simplicity, I'm choosing Permatex for the basis of this conversation, but if you have a brand you prefer, feel free to elaborate as to what flavors they have and are best suited for.
Copper, aluminum, nickel??? What's the difference?
If copper is for high heat, can it be used for low heat applications too? Are there surfaces that it shouldn't be used on, say, aluminum in the case of water pump bolts or manifold bolts on an aluminum head?
'03 Suburban
Re: Antisieze [Re: A_Spruce] #5463613 06/26/20 07:03 PM
SuperDave456 Offline
I think copper is for aluminum and stainless steel.
You can use higher temp stuff on lower temp materials, just that the higher temp stuff is gonna be more expensive.
I have a large tube of the silver cheap stuff and a small bottle of the copper stuff.
For my purposes they are both more than I'll use in my lifetime.
BTW the stuff that comes on Glocks is copper antisieze. I know folks who use it religiously after cleaning.
Re: Antisieze [Re: A_Spruce] #5463627 06/26/20 07:22 PM
Skippy722 Online Happy
Online Happy
We used copper anti seize on everything at my old shop. Smells kinda good when it gets hot.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Antisieze [Re: A_Spruce] #5463663 06/26/20 08:28 PM
ctechbob Offline
I find the regular permatex silver is the best for me when I'm wanting to cover every single tool and water fixture in the house, along with every article of clothing I'm wearing at the time.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Antisieze [Re: A_Spruce] #5463676 06/26/20 08:51 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I wish there was a good chart that showed which were best for what.
Makes no sense to me to use cu with aluminum parts. I use zinc based on my aluminum wheels to the rotors. I also keep some marine type around. The little jars on amazon aren’t so expensive that you can’t have a bunch. I don’t think it really goes bad.
Ive not really found a use for the nickel type yet...
Re: Antisieze [Re: A_Spruce] #5463679 06/26/20 08:53 PM
Snagglefoot Offline
I posted this a while back. Mine is one of several on that page. Enjoy.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5405755/nickel-vs-copper-anti-seize
If you want the job done right......do it yourself.
Re: Antisieze [Re: ctechbob] #5463700 06/26/20 09:20 PM
R
Reddy45 Offline
R
LOL great post. I truly feel for anyone who gets even a dab of it on their finger without realizing.
@JHZR2-
[Linked Image from asaptec.com]
Also: https://anzordev.cdn.prismic.io/anzordev%2F8bface4d-47ae-4b9f-925f-a93e94efef33_anti+seize.pdf
Re: Antisieze [Re: A_Spruce] #5463704 06/26/20 09:26 PM
T
Triple_Se7en Online Content
Online Content
T
2400 degrees Permatex Nickel works best on Muzzleloader breechplugs with 777 powder.
Stay Safe - Stay Healthy
Think things out - b/4 jumping on the wrong daily path.
Keep Your TGDI / GDI engines clean....4k OCI.
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Antisieze [Re: A_Spruce] #5463709 06/26/20 09:37 PM
A
A_Spruce Offline OP
A
Thanks for the link, Snagglefoot, that will keep me busy for a while! :lol: I bought some permatex copper for it's heat resistance, figuring it would be a decent all around anti-seize. From reading several of the post in that link, it may not have been the right choice for the water pump replacement.
This is one of the things that chaps my hide about product labels and manufacturer recommendations, they're all wonderfully vague about where you should and shouldn't use them. While you can't necessarily list every application, is it so hard to say DO NOT USE with aluminum/steel connections or SAFE TO USE with XX material combinations?
'03 Suburban
Re: Antisieze [Re: A_Spruce] #5463712 06/26/20 09:46 PM
2015_PSD Offline
In a former life, I worked in the petro-chemical world and we used Fel-Pro Hi-Temp C-100 Molybdenum Disulfide Anti-Seize everywhere. Some of the ethylene furnaces would reach temperatures that could melt many metals, but the stud bolts would break free every time.
I can remember breaking a 18" chlorine header apart that had been in operation about 10 years. The B7 nuts were so corroded they had lost at least 25% of the surface area. I broke them free with a 24" pipe wrench and there was still anti-seize on the threads.
You could spread a drop of this stuff between the planets and have some to spare. I have a can of it from 1983 that is still over half full.
[Linked Image]
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Antisieze [Re: A_Spruce] #5463718 06/26/20 09:58 PM
T
thescreensavers Offline
T
I buy nickle anti-seize works for all materials and high heat, I don't need to have multiple types in my garage.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Antisieze [Re: A_Spruce] #5463720 06/26/20 10:02 PM
KeithS_NW_Ohio Offline
[Linked Image]
2012 Ford Fusion - Mobil 1 0W-20EP/HM
2005 Nissan Altima - Mobil 1 0W-30AFE
LawnBoy w/Honda GCV160 engine - Amsoil ASE 10W-30
Mine to Maintain
2018 Jeep� Compass - Mobil 1 0W-20EP
Re: Antisieze [Re: ctechbob] #5463778 06/27/20 12:45 AM
DukeOfFrontenac Offline
I'm with ya.
Re: Antisieze [Re: JHZR2] #5464002 06/27/20 09:52 AM
doitmyself Offline
Originally Posted by JHZR2
I wish there was a good chart that showed which were best for what. Makes no sense to me to use cu with aluminum parts. I use zinc based on my aluminum wheels to the rotors. I also keep some marine type around. The little jars on amazon aren’t so expensive that you can’t have a bunch. I don’t think it really goes bad. Ive not really found a use for the nickel type yet...
I have the same thoughts. We should at least limit these discussions to the most commonly available ones: "silver", copper, nickel and forego discussions on nuclear power plant grade antiseize. After dozens of discussions here, we still have not come up with some very general guidelines about which product is best where. It's difficult when Permatex recommends both silver and copper for spark plugs in aluminum blocks. We also dwell on the temperature ratings - do we really need 2400F capability?
Re: Antisieze [Re: doitmyself] #5464119 06/27/20 12:44 PM
Drew2000 Offline
For steel into aluminum threads, zinc-based anti-seize works the best. I bought a can years ago primarily for working on motorcycles. The zinc dust is not abrasive to soft metal and prevents di-electric corrosion. Never had a problem removing or stripping aluminum threads that had a dab of this on them. Have 1lb can of Loctite Zinc that's 25 years old and will last me a lifetime.
https://www.antiseize.com/zinc-anti-seize-zinc-dust-and-petrolatum-compound-aircraft-grade
https://www.manufacturing.net/home/article/13216826/understanding-the-true-value-of-antiseize
17Escape 2.0
11Mustang GT
06Tribute
05Honda ST1300
03Yamaha FZ1
93Regal
91Explorer
87F250
85FJ1100
83CB650
