Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
88 registered members (928, 2015_PSD, 97tbird, 55Test, addyguy, 555, 14 invisible), 1,463 guests, and 30 spiders.
Topics307,431
Posts5,310,881
Members71,843
2013 328i Convertible Top repair #5463607 06/26/20 06:54 PM
Scout1 Offline OP
I always told my wife if her hardtop/convertible ever stopped working, I was going to run away from home! Three roof pieces and the trunk bonnet mechanism all moving with eight hydraulic actuators to stow the roof in the trunk and then back up again plus a complicated locking mechanism with cables, micro switches, etc.
Well, it happened last weekend; stopped half way deployed with a message saying "roof movement impaired". Ugh...but fortunately the car was sitting in our driveway. After she begged me not to run away from home, I got my new code reader and found the convertible top module had a code "A691 Hallsensor VSW5.2" Turns out that is the sensor on top of one of the bonnet rams that senses when the ram is fully extended. Only $42 at my local BMW dealer so not bad to buy. Putting it in was kind of a pain since you have to snip a number of zip-ties and re-tie them as you route about 3 feet of wire from the sensor. Plus the removal of a bunch of trunk trim to get to the wire routing. But all is well now and the top is working again.
The question I have though is the hydraulic fluid to use if I ever need to add any to the convertible pump? I know BMW sells their own convertible top oil but I have some Pentosin CHF 11S... anybody know if that fluid would be a good choice or is the BMW fluid mandatory?
Scout1
Truth will always bear up against falsehood, as oil does above water
Re: 2013 328i Convertible Top repair [Re: Scout1] #5463670 06/26/20 08:41 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Good to know it’s diy. Ive always been curious of the same - what’s the right stuff, and when/how do you replace it?
In a way I kind of wish my 135i top was all mechanical...
Re: 2013 328i Convertible Top repair [Re: Scout1] #5463688 06/26/20 09:02 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I had the opportunity to buy a convertible BMW. Once I saw how the top operates, I ran away.
Pentosin CHI 11S is used in Mercedes hydraulic top mechanisms.
Re: 2013 328i Convertible Top repair [Re: JHZR2] #5463691 06/26/20 09:07 PM
Scout1 Offline OP
Well, I know it's a "lifetime" fluid but it's only a matter of time before some leaks out an actuator seal or a hose fitting so I figure I better get an idea on how to top it up and with what fluid!
When I was in college, a friend had a little Honda convertible that was mechanical. Popped a handle and it fell backwards and just picked it up when it was time to close. Now THAT'S reliability! Unfortunately, the roof on my wife's 328i is made out of steel and quite heavy. I had to manually lift the bonnet to get to the sensor I replaced and even though it was on hinges, it was fairly heavy to lift up.
Scout1
Re: 2013 328i Convertible Top repair [Re: Scout1] #5463784 06/27/20 01:16 AM
U
user52165 Offline
U
You got very lucky. $42 part and in stock. Kudos on fixing it yourself.
Hydraulic fluid on a recent model convertible? I thought they dumped that years ago. Last conv I had was 73 Pontiac 455 Grand Ville with the great GM "Scissors top". Very refined all electro mechanical system that never failed. Have a friend with a 330i conv. about 2010.She is older and rarely drives now.. Same system as yours?
Re: 2013 328i Convertible Top repair [Re: Scout1] #5463896 06/27/20 07:12 AM
A
Audios Offline
A
CHF 11S is approved for the top, theyve used that since the early 90s. CHF 202 is also an approved replacement fluid.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 2013 328i Convertible Top repair [Re: user52165] #5464758 06/28/20 09:55 AM
Scout1 Offline OP
Originally Posted by user52165
[quote=Scout1]
I think all the recent model convertibles are hydraulic, which recent cars have a mechanical system? I had a 2001 Audi TT and we had to add hydraulic oil after one of the rams started leaking. That's when I bought the Pentosin and still have a lot left. The total oil capacity on my 328i is only .8 qt. I think.
The 330 convertible is a rag-top I think isn't it? That would be a totally different design. I have the steel hardtop that separates into three pieces and folds into the trunk. It's a lot more complex than the rag-top convertibles.
Scout1
Re: 2013 328i Convertible Top repair [Re: user52165] #5464765 06/28/20 10:02 AM
Scout1 Offline OP
[quote=Scout1]
Actually, the sensor had to be ordered in so I had to wait a couple of days for it to come out of their California warehouse... and to be totally honest, the first sensor I ordered was the wrong sensor. I had the right part number but the BMW counter guy talked me into a different part number which I thought he said was superseding the number I wanted. At any rate, that's why it took me a week to fix. Unfortunately, it was nice weather here in Seattle and the wife didn't have her convertible to drive... :-(
Scout1
Re: 2013 328i Convertible Top repair [Re: Scout1] #5466944 07/01/20 09:36 AM
A
Anduril Offline
A
It's hydraulic oil in a closed system that sees very little use. Unless you're OCD about changing the fluid in your floor jacks as well, I wouldn't bother unless it's leaking. The convertible top on my Mustang takes ATF, and Ford says you don't need to change it. I don't see why I would need to, either.
At least you didn't have to replace the entire top like I did, turns out that's a fair bit of work!
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
