Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
19 registered members (Bjornviken, blufeb95, alcyon, CARJ, Bailes1992, ctechbob, 2 invisible), 654 guests, and 25 spiders.
Topics307,388
Posts5,309,620
Members71,821
2012 Sonic - flashing "D" light #5463529 06/26/20 05:05 PM
Number_35 Offline OP
Hello wise Bitoggeratti - My friend phoned earlier today, a bit panicked. His Sonic (1.8 l, automatic) was running very poorly, the check-engine light was on (solid, not flashing), and the "D" light on the transmission gear selector was flashing. He limped over with the car (worried the car wouldn't make it), with the tranny taking a long time to engage.
He parked a few houses away due to construction on our street. We went out, and I started the car. It ran perfectly, and the "D" light did not flash when I put the car was in gear. The check-engine light was still on. Drove the short distance to my house and pulled the car into my driveway. My friend said that this had all started after he'd unintentionally shifted from R to D at low speed without stopping in between.
I read the code - P0601 (PCM internal fault) - and cleared it. It did not come back. My ScanGauge had detected two codes, but unfortunately I cleared both before I'd read the 2nd one.
At this point, I figured the car had just needed a "reboot" and had fixed itself just sitting a few minutes while my friend walked from the car to my house and we walked back. Regardless, I disconnected the negative battery terminal for a minute or so. Again, no problem once he restarted it.
So, what happened here? Did the inadvertent shift from R to D confuse the computer and send the car into limp mode? Or is that coincidental, and there's an underlying problem with the transmission that will resurface?
The car is a bit short of 120K km (75K miles) and I don't think the tranny has been serviced yet. There's no dipstick, so I'm leery of taking this on myself - I recommended that my friend have the fluid changed (not flushed) at a reputable transmission shop. I don't know if these have a filter that should be changed, or just a strainer that can be left alone.
Thanks all!
Re: 2012 Sonic - flashing "D" light [Re: Number_35] #5463562 06/26/20 05:53 PM
L
Lolvoguy Offline
L
Shifting from R to D (or vice versa) is never good on any auto transmission.
Considering this silly stunt does not seem to affect the car after clearing the codes, I wouldn't be worried.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: 2012 Sonic - flashing "D" light [Re: Lolvoguy] #5463566 06/26/20 05:58 PM
F
ffhdriver Offline
F
[quote=Lolvoguy]Shifting from R to D (or vice versa) is never good on any auto transmission.
Re: 2012 Sonic - flashing "D" light [Re: Number_35] #5463568 06/26/20 06:03 PM
F
ffhdriver Offline
F
I don't understand your comment. How do you shift from R to D then?
Re: 2012 Sonic - flashing "D" light [Re: ffhdriver] #5463591 06/26/20 06:27 PM
I am pretty OCD about it when driving an automatic - I come to a complete stop in R before shifting to D. I never shift to D while the car is still moving backwards.
Re: 2012 Sonic - flashing "D" light [Re: Number_35] #5463594 06/26/20 06:30 PM
c502cid Offline
I think the Sonic is the same as my Trax. Drop belly pan, drain plug is 10 or 11mm. Takes 4 1/4 qts if I remember right. Fill plug is easy to get to, need a long funnel. 45 minute job tops. There are youtube videos on the internet. Mine takes Dex6.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
77 E250 Quadravan 460/C6/NP205 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: 2012 Sonic - flashing "D" light [Re: ffhdriver] #5463595 06/26/20 06:30 PM
L
Lolvoguy Offline
L
You come to a complete stop prior to selecting any other gears.
Say "no" to Turbo!
Re: 2012 Sonic - flashing "D" light [Re: c502cid] #5463630 06/26/20 07:27 PM
W
WyrTwister Offline
W
Originally Posted by c502cid
I think the Sonic is the same as my Trax. Drop belly pan, drain plug is 10 or 11 mm. Takes 4 1/4 qts if I remember right. Fill plug is easy to get to, need a long funnel. 45 minute job tops. There are youtube videos on the internet. Mine takes Dex6.
We have a 2015 Sonic 1.8l automatic .
There is a drain plug on the bottom of the tranny , a " check " plug on the side and a fill plug on the top .
Drain the tranny , then replace the plug . You may wish to measure the amount of Dexron 6 that comes out .
With the car level , remove the side " check " plug and fill until ATF comes out . Put everything back together and do a long enough test drive , to get the ATF warm / hot .
Back home , jack it back up and run it through the gears , with the brake FIRMLY applied and return to Park . Remove the check plug ( with the car level ) and add enough ATF for it to come dribbling out the check hole . Put everything back together & you are finished .
Next thing is , has the timing belt & related parts , been replaced ? The coolant pump is driven by the serpentine belt , I think . I would not mess with it , if it is not giving any problems .
Wyr
God bless
Re: 2012 Sonic - flashing "D" light [Re: Number_35] #5463646 06/26/20 07:55 PM
J
JTK Offline
J
Is the factory battery still in it? I'm wondering if it's borderline maintaining ~14VDC at idle.
Hard to say what this could have been, or if the other code would have helped.
Just a wait and see if it comes back.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2012 Sonic - flashing "D" light [Re: Number_35] #5463698 06/26/20 09:17 PM
E
eljefino Offline
E
My wife had an HHR that she valet parked.
The valet must have gone from R to D, as it threw a code complaining about it. It did NOT light the CEL and the only symptom was the cruise control stopped working.
Cleared the code and all was well.
A PCM internal fault could be many tragic things, like bad caps, solder joints.
Re: 2012 Sonic - flashing "D" light [Re: WyrTwister] #5466533 06/30/20 05:28 PM
c502cid & WyrTwister - Good thoughts! If this were my car, I'd certainly take it on. Given that it's my friend's car, I'm reluctant to change fluid for him, and then risk bearing responsibility if the transmission fails at some point down the road.
I did a tune-up for a former friend many years ago (on a Plymouth Fury III w/ 383) and the timing chain failed a few days later. He blamed me for it, and bullied me into giving him some tires to compensate him. That was a lot of years ago, but I've never quite gotten over it. In retrospect he was pretty toxic (though very charismatic), and I was better off not having him in my life. In any case, I'm reluctant to put myself in a position where I might be blamed for an unrelated failure.
This is the same car I wrote about a few weeks ago, where a routine inspection by a garage doing a seasonal tire changeover had pointed out sloppy stabilizer-bar end links, a weeping strut, and a blown rear shock. I noticed at the time that the engine had a timing belt rather than a chain, and asked my friend the mileage. I thought he said 150K km. We checked the manual, and it recommended the belt be changed at 156K km, so I told him he shouldn't let it go.
But we checked the odometer during this recent transmission issue, and it's only at 117K km, so he's got lots of mileage left on the old one. I must have misheard (perhaps he'd said 115 rather than 150) a few weeks ago, or perhaps he was mistaken. In any case, I'm not sure whether I'd take on his timing belt or not. I've done several for myself, and a few for others, but it's always a risk.
