Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
90 registered members (77GrandPrix, 4WD, 97tbird, alarmguy, 2015_PSD, 87sammy, 14 invisible), 1,436 guests, and 30 spiders.
Topics307,433
Posts5,310,929
Members71,847
Transmission fluid change #5463430 06/26/20 02:58 PM
dan765 Offline OP
Hello,
I've got a 2012 Hyundai Genesis Sedan, 3.8L. 93,3xx miles on it. I recently purchased it and I don't know if the tranny fluid was changed.
My questions is, should I take it to the dealership to get it changed (they'll charge $250) or should I take it to my mechanic to change it (he'll charge $150)? Apparently on the 2012, the 8-speed transmission was a bit finicky at first so I want to make sure I get it done right (I don't want to do it myself for that reason).
What are your thoughts?
2012 Hyundai Genesis 3.8L sedan
2015 Hyundai Santa Fe Sport 2.4L
Re: Transmission fluid change [Re: dan765] #5463440 06/26/20 03:06 PM
JustN89 Offline
If you trust your mechanic, I don't know why you wouldn't just take it to him. That would be my recommendation.
You know what they say, cross threads are tighter than locktite!
Re: Transmission fluid change [Re: dan765] #5463441 06/26/20 03:07 PM
H
Hermann Offline
H
I would go to the dealer, if you think the car is worth the extra c-note then I would have the dealer do it, with Hyundai fluid.
No flush at that mileage. Drain and fill + filter if there is one that is easily replaceable.
Last edited by Hermann; 06/26/20 03:08 PM. Reason: Additional vital information LOL
2018 Ford F-150 XL Reg Cab - 3.3L NA V-6
Motorcraft 5w-20 Syn Blend and Motorcraft FL-500s
1991 BMW R100GS 20w-50 Maxlife & Mahle OX36D filter
Re: Transmission fluid change [Re: JustN89] #5463448 06/26/20 03:17 PM
W
WyrTwister Offline
W
Yes .
Wyr
God bless
Re: Transmission fluid change [Re: dan765] #5463451 06/26/20 03:21 PM
A
Aredeeem Online Content
Online Content
A
I just did the drain and fill on my CVT Versa after much hand wringing. My Indy charged me $125 for two drain and fills and about $23.99 per Quart of Nissan NS-2. My advice, take the plunge. My fluid looked good coming out after 75k.But now it’s done already. Nothing better than putting it behind you.
Re: Transmission fluid change [Re: dan765] #5463466 06/26/20 03:34 PM
R
rob1715 Offline
R
Ask if your mechanic has done Genesis before. A bit different than regular drain and fill, but not complicated. If he hasn't go to the dealership.
2003 Toyota Matrix - Whatever synthetic is cheapest - OEM Filter
2019 Kia Sorento - OEM Filter
“Think of how stupid the average person is, and realize half of them are stupider than that.”
Re: Transmission fluid change [Re: Hermann] #5463468 06/26/20 03:35 PM
JustN89 Offline
Most Hyundai dealerships won't fill with OE fluid unless you specify, and then they'll charge more for the service. I think most Hyun/Kia dealers use BG fluids, but that's just been my experience across multiple dealerships.
Re: Transmission fluid change [Re: dan765] #5463475 06/26/20 03:44 PM
L
Lubener Offline
L
Better yet, take it to a good transmission shop.
The "thinking" man's friend.
Re: Transmission fluid change [Re: dan765] #5463487 06/26/20 04:05 PM
CKN Offline
Do we use the term "Flush" on here interchangeably when we mean "fluid exchange"?
Because most machines "change out" the fluid and not "flushes the transmission".
All that can be avoided with transmission fluid exchange. This service is sometimes referred to as a transmission flush, but they aren’t one in the same. A transmission fluid exchange is when the old fluid is replaced with new fluid. A transmission flush involves forcing chemicals through the system to clear out debris. Transmission fluid exchange is preventative maintenance whereas a transmission fluid flush is closer to a repair that’s correcting a problem.
https://www.jackwilliams.com/blog/all-about-transmission-fluid-exchange/
Re: Transmission fluid change [Re: dan765] #5463500 06/26/20 04:17 PM
A
Online Content
A
Mine did a drain and fill. X amount out, the same in. Twice. After a bit of a run in between. The subtle slip I had during acceleration is gone. Ymmv.
Re: Transmission fluid change [Re: dan765] #5463510 06/26/20 04:30 PM
U
user52165 Offline
U
The 8 speed is different from other Hyundai transmissions in that it requires fluid meeting SPH-IV-RR, not the normal SP III or SP IV.
See TSB 14-AT-005
Good news. Valvoline Maxlife meets those specs.
Re: Transmission fluid change [Re: dan765] #5463520 06/26/20 04:41 PM
A
Online Content
A
Wow, what a subtle endeavor to keep this stuff out of the reach of a shade tree mechanic. Not so subtle I guess.
Re: Transmission fluid change [Re: Aredeeem] #5463523 06/26/20 04:46 PM
U
user52165 Offline
U
Not all shade tree mechanics are created equal.
Re: Transmission fluid change [Re: user52165] #5463547 06/26/20 05:33 PM
J
Jimzz Offline
J
See TSB 14-AT-005
Ive used MaxLife in several of those transmission with good results.
yup
Re: Transmission fluid change [Re: dan765] #5463597 06/26/20 06:36 PM
A
Online Content
A
I agree User. But just find a trustworthy Indy and get it done. The anticipated dread is so much worse than the actual event. We have independents here in Jersey that offer sedation during transmission servicing. You wake up and remember nothing.
