Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
49 registered members (antone, 4WD, AlienBug, Boomer, BigCahuna, 4 invisible), 872 guests, and 29 spiders.
Topics307,389
Posts5,309,650
Members71,821
Engine sound difference with different oils #5463410 06/26/20 02:35 PM
V
vivaUkraine Offline OP
V
I'd love to hear from the knowledge gurus regarding engine sound changing with different oils. In audio world there's an omnipotent myth that different amplifiers/av receivers have different sound signature. This has been definitively disproven with scientific blind tests, time after time.
I would guess that the same holds true for "this oil quieted my engine" or "that oil made my engine sound coarser", assuming identical viscosity is used. So, how can, FOR EXAMPLE, 5W-40 oils with the same MB 229.5 approval, but from different brands cause engine sound signature to change, as is often claimed? I can understand a lighter weight oil vs heavier weight oil causing a change in sound signature, but again, same 229.5 (JUST AS AN EXAMPLE), in the same viscosity, just different brand producing a difference? Sounds like a typical human myth to me.
What do you say?
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463413 06/26/20 02:38 PM
N
nascarnation Offline
N
I see a lot of opinions on noise and no data.
Which tells me most of the opinions are worthless.
(since you don't need a 3000 dollar B&K sound meter any more to measure this stuff).
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463427 06/26/20 02:56 PM
T
TmanP Offline
T
What do you say?
I mean, the fact that two oils meet the same standard doesn't mean that they are identical in any capacity. Similar, sure. But there is still latitude for the manufacturers to design an oil as they wish, so long as it meets the spec they say it does (perhaps calcium vs sodium in the additive package). And viscosity isn't necessarily identical within that spec. Again, it can be similar without being the same. Different enough to make a difference? I can buy it sometimes, in some cases. Will that difference be tangible and/or matter? Probably not. For example, the PP Euro and M1 are not exactly the same product despite meeting the same spec, 229.5. There are many examples of this (for example, not all TT gas is the same - Shell doesn't necessarily use the same additives as Chevron or Mobil or BP, but they're all TT). The fact that it performs similarly, and is certified to do so, does not mean that it is the same product, or that it will necessarily perform the same way in all conditions. What it does mean is that the initiating party agency (in this case, MB) says that the product meets their standards. The companies making it are free to do so as they want, and some differences should be expected.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463449 06/26/20 03:18 PM
J
JMJNet Offline
J
In Engineering world it is called "Tolerances".
Most spec is stated in a range of value, NOT absolute.
For example:
Absolute value "5".
Then when it is expressed as a range: 5 +- 5% or 5 + 5% or 5 - 5%.
Note, the first one is "plus minus", second is 5 or greater up to 5% of 5, etc.
So a company can go on the minimum, maximum or the middle of the tolerance.
Nothing in this world is really absolute.
Will it ever be 5, heck no.
This spec is valid for the oil and the car.
Means both the cars and oils are made based on tolerance NOT absolute.
  • 2017 Toyota Sienna
Re: Engine sound difference with different oils [Re: JMJNet] #5463471 06/26/20 03:37 PM
R
rob1715 Offline
R
You sound absolutely certain about this.
2003 Toyota Matrix - Whatever synthetic is cheapest - OEM Filter
2019 Kia Sorento - OEM Filter
“Think of how stupid the average person is, and realize half of them are stupider than that.”
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463488 06/26/20 04:06 PM
T
The_Nuke Offline
T
The 3.5L V6 in my 2010 Challenger would sound like a typewriter when started any morning when ambient temps were below 50F and the engine oil was conventional 10w-30 of any brand (IIRC QSGB, PYB, and ST were all tried with no relief).
A switch to Valvoline Maxlife 10w-30 stopped the typewriter noises on the colder mornings the very first start, and the noises didn’t return as long as I ran that oil.
I won’t say I know what is about the MaxLife that quieted that engine so completely, nor will I say Maxlife is the best oil for other applications. Whatever it was, however it did it, Maxlife 10w-30 and that terrible Dodge V6 worked well together where others would not.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463490 06/26/20 04:11 PM
G
gfh77665 Offline
G
My 2006 Honda Odyssey 3.5 sounded significantly different with 5w-20 vs. 5w-30. The 5w-30 was much quieter.
In my 5.3 Chevy truck, I cannot tell any difference between 5w-30, and 10w-30, or even SAE 30wt.
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463493 06/26/20 04:12 PM
B
BLND1 Offline
B
My engine sounds different at different times of day/drive with the same oil. Good luck trying to ascribe a change in sound to oil.
Re: Engine sound difference with different oils [Re: The_Nuke] #5463494 06/26/20 04:12 PM
T
Triple_Se7en Online Content
Online Content
T
Nuke
Sometimes the typewriter sounds are stuffed inside the oil filter and not in the oil galleys.
So when you switched to the quieter Maxlife, you also switched oil filter brand / model too?
Or, have you stayed with the same exact oil filter, throughout the entire ordeal / OCI changes?
19' Hyundai Santa Fe 2.4 GDI -- Valvoline Modern Engine 5w30 - AC Delco Ecore
20' Kia Soul X-Line 2.0 MPI -- Kia Total Quartz Syn-Blend 5w20 - OEM Filter ...(Next Up) Pennzoil Ultra Platinum 5w30
Re: Engine sound difference with different oils [Re: The_Nuke] #5463533 06/26/20 05:09 PM
A
aquariuscsm Offline
A
Maxlife full synth or synth blend?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Engine sound difference with different oils [Re: Triple_Se7en] #5463575 06/26/20 06:10 PM
T
The_Nuke Offline
T
Originally Posted by Triple_Se7en
Nuke
That engine got nothing special in the way of oil filters. The normal one would have been the MicroGard filter from O’Reilly Auto. If I strayed from MG for that car, it would have been a standard Wix oil filter.
Also, I usually run an oil filter for 2 consecutive OCIs unless something happens that prevents it. Whether or not a coincidental change from MG to Wix occurred right at the swap to Valvoline Maxlife, I cant say with any real certainty I remember that happening.
Re: Engine sound difference with different oils [Re: aquariuscsm] #5463576 06/26/20 06:11 PM
T
The_Nuke Offline
T
IDK...whichever one comes in the red bottle and whispers sweat nothings in old Dodge V6s’ ears, that’s the one!!
Re: Engine sound difference with different oils [Re: The_Nuke] #5463582 06/26/20 06:18 PM
T
Online Content
T
That's the synblend. My former S-10s 4.3 engine's favorite oil. Always popular with BITOGers, as is the Valvoline Durablend..
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463640 06/26/20 07:42 PM
4WD Online Confused
Online Confused
What do you say?
I say hats off for the effort … but nothing other than viscosity typically comes up as a reason … and my own DB testing in two engines confirmed that a 40 can be quieter than a 30 … but debunked the brand name assumptions …
Re: Engine sound difference with different oils [Re: vivaUkraine] #5463742 06/26/20 10:48 PM
G
GMguy84 Offline
G
Earlier this year, I was running Shell gas truck 5W20 in my old crown vic police interceptor and it idled funny like a slight miss and had "meh" acceleration
I switched to M1 truck/SUV 5W20 and HOLY MOTHER [email protected]&! talk about a big difference in engine sound and torque/acceleration !!
STRONGLY thinking of running it in my Suburban/Silverado work fleet thumbsup
Dave
01 Silverado 1500HD Shell RGT 5W30/XG3675
01 Suburban 1500 Mobil 1 Truck/SUV 5W30/XG3675
02 Suburban 1500 Delo 400XLE 10W30/Protec166
82 Trans Am (KITT) M1 10W40HM/XG5
