Forums Migration
Please read this thread
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
32 registered members (bmod305, 07hemi, carlprop, ArrestMeRedZ, 3 invisible), 880 guests, and 23 spiders.
Topics307,580
Posts5,313,558
Members71,876
Battle of Oils in Middle East? What should I choose? #5463021 06/26/20 06:22 AM
J
John344 Offline OP
J
Greetings,
I have a Grand Cherokee 3.6 L 2018 and I had issues before with finding the right oil since I live in a very very hot climate 131F (55C) in daylight. So considering that I had limited oil choices here I was struggling to choose the best, but now I found a place that sells Amsoil 0W-20 (which the manufacturer recommends). I really don't know anything about Amsoil and I heard that it's suitable for racing cars?
The option that I have are the following:
1- Amsoil OE 0W-20
2- Mopar 0W-20 (I think Shell Helix provide them)
3- Mobil 1 5W-30 ESP Formula
4- Liqy Moly Special Tec LL 5W-20
This What the manual says:
[Linked Image]
What do you think about Amsoil is it worth it??
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463024 06/26/20 06:23 AM
B
buster Offline
B
Of the oils you listed, the Amsoil 0w20 and Mobil 1 ESP 5w30 would be my choice. Being your car calls for a 0w20, the Amsoil would be a good choice.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Battle of Oils in Middle East? What should I choose? [Re: buster] #5463030 06/26/20 06:36 AM
J
John344 Offline OP
J
Does Amsoil 0W20 have the FCA Material Standard MS-6395? I searched online but no one mentions that it has it?
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463031 06/26/20 06:39 AM
B
buster Offline
B
Amsoil does not submit their Signature Series oils for official approval.
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463038 06/26/20 06:54 AM
CT8 Offline
Originally Posted by John344
Greetings,
1- Amsoil OE 0W-20
[Linked Image]
Is better low temperature starting and vehicle fuel mileage a consideration where you are living. 0W oil is for starting at below about -35*f
2015 F150 2.7
2018 F350 6.2
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463042 06/26/20 07:02 AM
PimTac Offline
I doubt that Fiat recommends Amsoil. From the copy you posted Shell must be paying for prominent recommendations. Nothing wrong with that though.
Your cooling system and air filter are very important considering your climate.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463059 06/26/20 07:19 AM
Cujet Offline
There is no reason to use exceptionally low viscosity oils in extremely high temperatures. A quick glance at a viscosity graph demonstrates that even a more viscous spec like 5W-30 is "thinner" at 40c than 0W-20 is at 10c. (10c = 50f a very common temperature in the USA) (40c = 104f a very common temp in the Middle East)
As I've mentioned in another thread, oil temperatures are not well managed in the vast majority of modern vehicles. This means oil temperatures will continue to climb, as outside air temperature climbs. Especially during hard use. The only real way we have to manage oil viscosity at extremely high temperatures is to choose properly.
I'm sure you know that many vehicles in the Middle East use more viscous oils. The manuals may suggest it, or it may simply be "the way it's done".
Modern engines are not significantly different from older designs and very few engines actually use internal components designed to last a long time with ultra low viscosity oils.
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463073 06/26/20 07:40 AM
Cujet Offline
Re: Battle of Oils in Middle East? What should I choose? [Re: PimTac] #5463097 06/26/20 08:02 AM
J
John344 Offline OP
J
I do take good care of that since we have a dusty environment, The only issue is that we have less imported oils the only trustworthy oils that I found are the ones I mentioned in the post.
Re: Battle of Oils in Middle East? What should I choose? [Re: Cujet] #5463100 06/26/20 08:05 AM
J
John344 Offline OP
J
Here we rarely get to 0C freezing point. and we have more hotter months than cold, The issue is that we don't have trustworthy oils here, so I have to stick with one of the mentioned oils. I don't know why Chrysler insists on using 0W-20 on all their new cars including the chargers. I would love to see a high mileage car that only used 0W-20 oil. so at least I feel better when I use it.
Re: Battle of Oils in Middle East? What should I choose? [Re: Cujet] #5463103 06/26/20 08:07 AM
J
John344 Offline OP
J
so looking at that chart in my case using thicker oil won't matter right? I mean my Oil temp always sets at 95C (203 F) it's rare that it reaches 100C (212 F). Even in summer.
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463111 06/26/20 08:23 AM
SR5 Offline
Out of that lot, Mobil 1 5W30 ESP.
It’s a VW 504 / 507 oil which a very high standard to reach.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463230 06/26/20 10:48 AM
L
LubricatusObsess Offline
L
FCA is a very euro-centric company, and most familiar with Royal Dutch Shell products because of it. It's essentially a Fiat company now. The low vis is for fuel economy standards in both europe and north america. Middle East is a much hotter climate and if there were a temp / vis chart like OEM's used to supply, you would see a higher viscosity recommendation for your climate.
I don't know why OEM's discontinued these charts - perhaps government fuel economy mandates forced them to? I know I would be running M1 ESP 5W-30 if I were you.
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463233 06/26/20 10:52 AM
JohnnyJohnson Offline
Frankly to many other good oils are available for less money. $10 a jug less is pretty easy to achieve. But in most cases choice of oil has very little to do with what is going to protect your car as much as personal predjudice.
2004 Corolla 140681
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Battle of Oils in Middle East? What should I choose? [Re: John344] #5463235 06/26/20 10:53 AM
K
Kuato Offline
K
There is a member here that lives in the Middle East. Drives a vehicle specified for a 20 grade, has an oil temperature gauge and has chosen to run a 40 grade oil based on his high oil temperatures.
Since you're also driving in extreme temperatures and the Pentastar was originally specified for 5w30 (in the US) I would think that a 40 grade would be safe choice. Since Amsoil is available to you, perhaps you might consider their 0w40, which is a very good oil that I've used in the past - in a vehicle specified 5w20.
Thick vs Thin test still in progress.
