Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
21 registered members (dervdave, Duke, farrarfan1, bernardch, bbhero, Falcon_LS, 4 invisible), 745 guests, and 21 spiders.
Topics307,436
Posts5,311,047
Members71,848
Ok to use left over 1/2 a bottle of Nissan CVT fluid? #5462639 06/25/20 05:07 PM
M
mahanddeem Online Content OP
OP Online Content
M
Hello,
I have a one half of a Nissan CVT fluid NS2 bottle left over from a previous CVT drain and refill a year and a half ago.
So planning to buy new 4 quarts (I typically drain 4.5 quarts).
Am I ok in using that left over? It's sitting securely closed with the lid, covered by plastic bag in my storage room inside the house (getting AC as rest of the place year round)
Thanks
2009 Nissan Maxima
2011 Nissan Maxima
2004 Honda Odyssey
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462642 06/25/20 05:12 PM
J
Jeffs2006EvoIX Offline
J
As long as the spec is the same on the old bottles and new (Nissan revises their oils fairly often) and you kept the old bottle free of contamination it should be fine.
If the cap is lose, and the spec has changed on the new bottles? Then get rid of it. That way all the fluid is the same going in. Hope that makes sense?
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: Jeffs2006EvoIX] #5462664 06/25/20 05:33 PM
M
OP Online Content
M
It's the NS2 Nissan fluid. They used to have an old part no 999MP-NS200P but in the last 3 years the new (current) part no is 999MP-CV0NS2.
Both are NS2 class fluid.
Thanks for your reply.
2009 Nissan Maxima
2011 Nissan Maxima
2004 Honda Odyssey
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462676 06/25/20 05:44 PM
J
JTK Offline
J
I'd use it without concern.
That half a quart is still like $10 worth of fluid based on dealer prices.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462682 06/25/20 05:56 PM
slacktide_bitog Offline
It will be fine smile
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: JTK] #5462689 06/25/20 06:04 PM
B
bbhero Online Content
Online Content
B
I agree ^^^^^^
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462690 06/25/20 06:05 PM
B
Online Content
B
I'm now at 311,200 miles on my car with the CVT... 28,000+ miles since the first drain and refill... Car runs perfectly well still.
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462709 06/25/20 06:26 PM
B
blufeb95 Offline
B
About the only fluid I wouldn't use if it's been opened and sitting for a year is Brake fluid everything else is fair game.
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5462757 06/25/20 07:20 PM
toneydoc Offline
Absolutely
1994 Jeep 168k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 9k Pennzoil Platinum 5w30
2014 HD Ultra 52k Mobil1 15w50
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5463062 06/26/20 07:23 AM
A
ARCOgraphite Offline
A
Good to use.
I have seen no viscometric difference between NS-1, 2 and 3.
Maybe more anti-foamants in some and/or differing friction modifiers - just a guess.
Seeing how many have good luck with early changes using any aftermarket stuff, I would not worry.
If it goes bad sitting around the house for a couple years, it will go bad 30x faster in the transmission!
Oil is very stable stuff at typical ambient temps.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5463491 06/26/20 04:11 PM
M
OP Online Content
M
Thanks guys for the replies. Cheers!
2009 Nissan Maxima
2011 Nissan Maxima
2004 Honda Odyssey
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: mahanddeem] #5465237 06/28/20 09:52 PM
A
Avery4 Offline
A
ATF and other oils don't absorb moisture like brake fluid does and is therefore stable in storage almost indefinitely, it's shelf life will outlive its usefulness by far. Just give it a quick shake before you use it in case any additives settled out. Think about it- If ATF absorbed moisture your transmission would be full of water since it is vented and therefore open to the outside at all times.
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: Avery4] #5465718 06/29/20 02:44 PM
SoNic67 Offline
Except Toyota WS fluid - even the manual says that will oxidize quickly in air. I think that the Kia fluid is the same way.
Re: Ok to use left over 1/2 a bottle of Nissan CVT fluid? [Re: SoNic67] #5465806 06/29/20 04:56 PM
A
Avery4 Offline
A
I think that's nonsense to get people to throw out perfectly good fluid so they buy more. Think about it- The transmission has air in it since it isn't filled to the top and it is open to the atmosphere and the fluid is at ~200 degrees and being splashed around, exposing the drops to air. That would oxidize it extremely rapidly compared to sitting on a shelf in a bottle at 80 degrees. Also, don't forget that the new bottles aren't filled completely to the top, there is air in those bottles too so if that was the case the bottles of new fluid would be oxidized right from the start.
