Forums Migration
Please read this thread
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
94 registered members (2015_PSD, 379KITTY, 2004tdigls, 2003f7, 4WD, 4.8 Silverado, 13 invisible), 1,928 guests, and 32 spiders.
Topics307,771
Posts5,317,458
Members71,916
Increase 91 octane fuel. #5462632 06/25/20 05:03 PM
dbvettez061 Offline OP
I have a ZL1 Camaro which I’m sure would love 93-94 octane but in western Colorado the best I can get is 91. How can I increase up to 92-93 without creating any issues. Thx in advance.
2001 Z06 Forged Blown Stroked 650 RWHP 645 RWTQ
Vietnam Vet 5thSFGA
Re: Increase 91 octane fuel. [Re: dbvettez061] #5462640 06/25/20 05:08 PM
J
Jeffs2006EvoIX Offline
J
What is your elevation? If your above 4000 ft then 91 should be all you need if not MORE than adequate. If your at sea level, and your vehicle is modified with lets a header back exhaust and a tune for premium fuel then I can see it.
91 should be all this Camaro needs. oilburner
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: Increase 91 octane fuel. [Re: dbvettez061] #5462669 06/25/20 05:39 PM
T
tenderloin Offline
T
I use Lucas in 2 of our 3 ecoBoosts time to time on long trips including towing on one of the Escapes..Also if steep climbing etc.. Not sure about GM but Ford uses 93 octane for it's HP ratings. In Ca we only get 91. Lucas raises the octane 3 full points. Noticeable difference on full throttle and heavy loads...It works in these turbo applications. Not sure in non turbo cars BTW around town all 3 ecoBoosts run fine on 87 although on full throttle you can notice a difference even with 91
Re: Increase 91 octane fuel. [Re: dbvettez061] #5462705 06/25/20 06:24 PM
9
92saturnsl2 Offline
9
91 octane in your area is equivalent to 93+ at sea level, as far as preventing pre-ignition / detonation is concerned. Many folks at sea level are stuck with 91 as their premium option, so you've got it good.
I just can't fathom why you'd need anything higher than that-- if you have performance mods that require that high octane, they likely recommend race gas only.
Easiest way to increase octane (without using ethanol which has drawbacks) is to add toluene and/or xylene (available most anywhere that sells paint solvents) to your gas. I'm sure if you do a Google search you'll find resources that will help you calculate the mixture. I used to use it on a '00 supercharged Bonneville I owned when I took it to the track so I could run a smaller pulley. It works but it gets expensive. Not something you would do on a regular basis!
96 Grand Prix SE 150k Chevron Delo 5w-40 Synthetic
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Rotella T5 10w-30
Re: Increase 91 octane fuel. [Re: Jeffs2006EvoIX] #5462718 06/25/20 06:33 PM
M
MrHorspwer Offline
M
ZL1 is supercharged. It makes it's own atmosphere, regardless of the altitude.
I'd first get something you can do a bit of data logging with and see if the ECM is pulling any timing. If it's not, you're golden.
If you're looking to up octane, I'd get some VP Racing HP 101 (101 octane unleaded that can be ordered in 5 gallon pails) and blend it in to your 91 until you end up with the desired octane.
Re: Increase 91 octane fuel. [Re: dbvettez061] #5462741 06/25/20 06:55 PM
4
440Magnum Offline
4
As others have said, don't waste your money. What sets octane requirement is cylinder pressure just after ignition, where excessive pressure causes spontaneous ignition away from the existing flame front and before TDC. Being at high elevation reduces that pressure significantly, which is why they don't even bother offering 93 up there. Supercharging tends not to maintain pressure with elevation, either. Turbo vehicles might be able to use higher octane, but in a practical sense not so much... turbocharging (done right, the way OEMs do it) is less "octane hungry" than high static compression ratio, so even if the turbo causes the same cylinder pressure as it would at sea level, detonation is less likely.
Bottom line, you can try the snake oils... but don't expect to notice anything significant unless you use one that contains MMT... but then don't expect your O2 sensors to live long, either.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Increase 91 octane fuel. [Re: tenderloin] #5462763 06/25/20 07:31 PM
R
Rand Offline
R
IIRC: 3 points is .3 octane rating.
all that juice in a can does nothing really.. you need gallons to raise the octane.. e85 works good for example.
Re: Increase 91 octane fuel. [Re: MrHorspwer] #5462790 06/25/20 08:09 PM
J
jhellwig Online Content
Online Content
J
Unless it is it has some form of boost control and boost is cut back at sea level it is affected by atmospheric pressure. crzy
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Increase 91 octane fuel. [Re: dbvettez061] #5462799 06/25/20 08:24 PM
T
typ901 Offline
T
http://race-gas.com/
I used it in my 911. no issues.
Re: Increase 91 octane fuel. [Re: Rand] #5463068 06/26/20 07:34 AM
javacontour Offline
Bingo!
Vague labels on the package making people think it's going up by 3 when it goes up by .3
network down, IP packets delivered via UPS -BOFH
Re: Increase 91 octane fuel. [Re: MrHorspwer] #5463305 06/26/20 12:18 PM
Surestick Offline
Boost is likely referenced to current atmospheric pressure so additional altitude will still decrease boost.
The OP said he thinks his car "would love" higher octane which suggests it doesn't need it, he's just looking for added performance.
Re: Increase 91 octane fuel. [Re: Jeffs2006EvoIX] #5463352 06/26/20 01:13 PM
4500 feet elevation where I’m at.
Vietnam Vet 5thSFGA
Re: Increase 91 octane fuel. [Re: javacontour] #5463456 06/26/20 03:24 PM
T
tenderloin Offline
T
Originally Posted by javacontour
Bingo!
My fault for using points instead of octane rating number. Lucas when used as directed adds 30 points or 3 full numbers to the octane in the gasoline. 91 becomes 94 BTW the "vague" label states "Increases Octane Rating By 3 Full Numbers" Verified by Lucas Tech..
Re: Increase 91 octane fuel. [Re: javacontour] #5463457 06/26/20 03:24 PM
T
tenderloin Offline
T
Bingo!
My fault for using points instead of octane rating number. Lucas when used as directed adds 30 points or 3 full numbers to the octane in the gasoline. 91 becomes 94 Verified by Lucas Tech support...
Re: Increase 91 octane fuel. [Re: dbvettez061] #5463556 06/26/20 05:41 PM
javacontour Offline
No worries, the whole octane boost market seems to be a bit shady.
How can anyone tell that their fuel is now 94 instead of 91?
I even saw one review that suggested the amount of octane boost you get depends on the condition of your car. Uhhh, no, the fuel is or isn't changed regardless the condition of your car. Perhaps the ability of the vehicle to take advantage of such changes depends on the condition of your car, but the fuel itself experiences the change in properties regardless.
It just seems to be a shady marketplace to me.
