2002 Chevy 1500 Express with the Explorer package.
Problem is the motorized bench seat/bed.
Wires to the motor have 12V all the time. Removed the up/down switch completely from the circuit, no change.
Went looking and found a bank of 4 30 amp relays that the motor wires and power run to.
When the left two relays are removed, power to motor stops.
I replaced them with the other two relays, no change.
I read somewhere that there should be a controller, but I can't find one wired in the circuit.
If need be I can by a new controller and run new wires, but I'd rather fix the problem.
Any ideas guys?
Any ideas guys?
