Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
15 registered members (Bailes1992, ctechbob, Danno, blufeb95, Brynjaminjones, edhackett, 1 invisible), 652 guests, and 38 spiders.
Topics307,388
Posts5,309,617
Members71,821
ATF change using MityVac? (no serviceable filter) #5462603 06/25/20 04:40 PM
9
97tbird Offline OP
9
I have seen many posts re: oil changes using a MityVac (I also use the method for changing oil on my BMW), but was wondering if anyone does or recommends using the mityvac method (suck and fill) for ATF changes also...
My 2010 Escape with the 6F35 auto trans has no serviceable/replaceable filter = no filter changes with drain/fill service, so is there any harm in doing the mityvac method instead of a traditional drain/fill?
My goal is to do several suck/fill cycles to replace the full 9.5 qts of ATF new. (I have no idea how may quarts one can suck out with a MityVac; only about 4 qts can be replaced with a drain/fill on this transmission, which has already been done at 85k miles a few weeks ago: tech noted that the ATF was "pretty dark")
If any of you guys have attempted or done this: any tips/advice? any disadvantages?
(The one thing i am worried about is sucking ATF out hot/warm vs cold, due to the possible volume discrepancies of ATF at different temps.
I guess to be sure, I can suck it out when cold, that way both old AND new ATF is at same temp so I can just fill whatever volume I took out.)
Sufficiently Caffeinated...
Cars: 1997 Thunderbird v8 sports(sold), 2003 Elantra GLS (totaled at 225k), 2005 BMW 330Ci ZHP, 2014 Mazda 6 Touring, 2010 Ford Escape Limited v6 AWD
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462609 06/25/20 04:42 PM
R
redbone3 Offline
R
Measure the volume after the ATF has cooled.
2014 Passat Wolfsburg, 1995 Miata.
Re: ATF change using MityVac? (no serviceable filter) [Re: redbone3] #5462618 06/25/20 04:49 PM
9
97tbird Offline OP
9
Makes sense. Nice tip. Thanks!
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462633 06/25/20 05:04 PM
U
UncleDave Offline
U
Yup I use it to drain and fills.
They usually come with two tubes one with a black connector one with a red.
I use the red one for trans, and the black for oil(s)
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462641 06/25/20 05:12 PM
W
williestreet Offline
W
A few years ago I did a drain and fill followed by a cooler flush. I was able to get right around 4.5 litres out of my Nissan Frontier during the pan drain.
Last year I was going to do another drain and fill, but decided to use my mityvac instead and see how much I could get out with it. I am sure every car/truck is a little different but for me I was able to get exactly the same amount out using the vacuum method.
From now on I will be using a vacuum every time with confidence. I take the truck for a short drive to get it warmed up, but trans fluid is pretty thin anyway and much easier to suck than cold engine oil. Cold or hot it will come out pretty easy.
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462647 06/25/20 05:19 PM
9
97tbird Offline OP
9
Thanks!
How do you guys measure the volume that comes out? The MityVac has markings on it, but IDK how exact they are.
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462662 06/25/20 05:29 PM
U
UncleDave Offline
U
Originally Posted by 97tbird
Thanks!
I pour it into a graduated but empty container (usually old 5Qt oil jug)
UD
Uncle Dave
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462681 06/25/20 05:56 PM
dwcopple Offline
I use a vacuum pump on my Mustang to suck and fill ATF. I do 3qts at a time. Once per month for the months I drive it here in MI
2017 Acura MDX SH-AWD
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462721 06/25/20 06:37 PM
P
Pelican Offline
P
Thanks!
Recent MityVacs have a reverse valve so you could refill it with fresh ATF to the same level and reverse the action, then you'd be certain of the amount.
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462736 06/25/20 06:46 PM
J
JeffKeryk Offline
J
If the drain plug has a magnet, I would pull and clean the plug on the 1st iteration.
I plan on using my new MityVac for every-friggin-thing I can think of...
Gonna throw away my trolley jacks, etc.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462835 06/25/20 09:15 PM
R
ripcord Offline
R
A fluid extractor rocks for ATF exchange. I'll never be without one again. That said, the 6F35 has a drain plug underneath the plastic bottom cover. No Miti-vac required.
Re: ATF change using MityVac? (no serviceable filter) [Re: Pelican] #5462836 06/25/20 09:16 PM
9
97tbird Offline OP
9
Thanks!
I **THINK* mine has that function too, but i have used it for oil a lot and PS fluid, so IDK if I can ever get it clean enough to feel good about putting fresh ATF in it.... I should have kept it a bit cleaner, I guess.
Re: ATF change using MityVac? (no serviceable filter) [Re: 97tbird] #5462838 06/25/20 09:18 PM
R
ripcord Offline
R
Also, don't freak out if the fluid looks pretty dark. In my experience, LV seems to get dark really quickly relative to other types of ATF.
Edit: just noticed that you said it was just changed. I would do one more change and just do a drain and fill every 30K going forward.
Re: ATF change using MityVac? (no serviceable filter) [Re: ripcord] #5462842 06/25/20 09:21 PM
9
97tbird Offline OP
9
It does. But I am thinking of MityVac method for convenience (as I am somewhat hesitant about putting the car on jacks/stands etc, and I just want to avoid getting under the car and avoid messes), AND it doesn't have a filter that is replaceable anyway.
I already had a traditional drain/fill done, so the drain plug and magnet were inspected and were clean. I can always get a drain and fill done once in a while even if the "main" method is MityVac....
(I do the same with OCs on the BMW: for every 4th MityVac DIY I get a traditional drain/fill done)
Re: ATF change using MityVac? (no serviceable filter) [Re: ripcord] #5462844 06/25/20 09:23 PM
9
97tbird Offline OP
9
Thanks.
Yeah I was already warned about the dark Mercon LV. It is less dark than it was for sure, even with the one drain and fill.
