Forums Migration
Please read this thread
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
Flat Back Diff Cover - Failures 🤔
by SavagePatch - 07/06/20 08:52 PM
VW 9M/9G Transmission fluid ?
by JswFL - 07/06/20 08:38 PM
First time UOA. Questionable potassium levels
by chknkatsu - 07/06/20 07:38 PM
STP oil treatment
by wymi516 - 07/06/20 07:12 PM
sycboi, BakonBittz, ssoH, Sumpter_al, Jeffham87
71868 Registered Users
63 registered members (Boomer, 4WD, antone, Anthony, bullwinkle, Bjornviken, 4 invisible), 1,020 guests, and 27 spiders.
Topics307,534
Posts5,312,656
Members71,868
Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration #5462464 06/25/20 02:28 PM
V
viscous Offline OP
V
I'm contemplating installing a Fram Ultra Synthetic (XG) filter. Fram specifies a shorter filter for my application (different model number in the PH series), but this XG filter has the same threads and a similar bypass setting.
1. Are Fram XG filters restrictive to flow? Some have suggested the high efficiency rating leads to flow restriction, while others say the synthetic media makes it easy-flowing.
2. Is it a problem that the bypass rating of the Fram XG is slightly higher than that of the OEM filter I plan to replace? Is this problem mitigated or exacerbated by the Fram XG's flow properties.
3. As the Fram XG filter is designed for a long OCI, are there any drawbacks (besides the price) to using it for short OCIs? Someone suggested that it may sacrifice fine filtration at the expense of high capacity, but I've seen other reports to the contrary.
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462467 06/25/20 02:30 PM
K
kschachn Offline
K
Today seems to be the day for oil filter flow posts.
1. No.
2. No, no.
3. No.
"Flow" is not a concern in a passenger car oil filter.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462509 06/25/20 03:14 PM
O
OilReport99 Offline
O
I have run Fram XG series for the last 12 years, almost exclusively. From 2K OCI to 17K OCI, and never had any problems with it. This is only a personal experience, but you will find tons of posts on this board speaking of their quality. Just run them in you car and sleep well.
2018 Ram 1500 - VME 5W-20
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462528 06/25/20 03:39 PM
CT8 Offline
In real life we will never see any differences with the choice of oil filters Over the owner ship unless there is a catastrophic failure then a major brand will be the best at covering the costs. The Air filter is the most important filter and yes other will regurgitate some white paper they read but I worked most of my life in fleet maintenance..
2015 F150 2.7
2018 F350 6.2
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: CT8] #5462707 06/25/20 06:25 PM
Bud Offline
Well said.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: kschachn] #5462744 06/25/20 07:02 PM
Z
ZeeOSix Offline
Z
1. No.
2. No, no.
3. No.
+1
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462760 06/25/20 07:22 PM
toneydoc Offline
Use it and your engine will be fine
1994 Jeep 168k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 9k Pennzoil Platinum 5w30
2014 HD Ultra 52k Mobil1 15w50
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: kschachn] #5462809 06/25/20 08:41 PM
V
viscous Offline OP
V
Why not? Would it be a concern in smaller 4-cycle engines?
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462816 06/25/20 08:57 PM
4WD Online Confused
Online Confused
Not likely to be full flow like larger engines …
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5462825 06/25/20 09:06 PM
B
bbhero Offline
B
It's not a concern... The positive displacement pump will only pull but so much oil through the oil filter... And the pressure difference across the filter media is so very small it will be no where near enough to be a concern.
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: bbhero] #5462923 06/25/20 11:26 PM
Z
ZeeOSix Offline
Z
^^^ Exactly
Only thing to be concerned about with oil filter restriction is, when the oil is hot, that either the oil filter goes into bypass at high RPM, or the oil pump hits pressure relief at high RPM. The former will allow oil to not be filtered, and the latter will slightly cut the flow volume of oil going to the engine.
When the oil if cold, it's possible to do both those things if you rev the engine high. The "fix" is to let the oil warm up all the way before going crazy with engine revs.
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: kschachn] #5463129 06/26/20 08:39 AM
M
Mainia Offline
M
1. No.
2. No, no.
3. No.
Agreed. So technically any other motor with a larger filter then Honda Should be ok. See next paragraph. So flow is not the issue. Of course myself with Hyundai's, I will take the Hail Mary "hope" that larger base plate holes in the Titanium will help the limited oiling problem with some Hyundai's. That may stop a remote chance of possible foam, because of the very small holes in only the Hyundai Fram filters, including the only Fram filter I will use, the Ultra and Titanium. Fleeting hope, I know. Ha Ha.
A Honda V6/all Honda 4 cylinders/except S2000 has a thimble sized oil filter. Could be said to be the smallest or second smallest spin on filter in modern automobile use. Honda S2000 sports car with it's 9,000 rpm redline, and just a hair larger sized thimble sized filter then the V6/4 cylinder filter. Yet Honda have one of the most reliable and high mileage motor on earth. So yes, flow is not an issue as you said.
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: viscous] #5463185 06/26/20 09:52 AM
F
Farnsworth Offline
F
1. Yes, all oil filters are restrictive to flow.
In a brand new Fram Ultra it isn't a problem, and the two ply structure helps thwart excessive early restriction. Any filter as it is loaded restricts more until eventually it no longer filters. But during restriction, smaller pores in the clogged media, or "pipes" increase pressure across them, and this "increased dp" maintains the same flow. So inspect your element if you are worried about restriction. Flow will be the same always and nearly instantaneous, so a clogged filter can quickly open the oil pump relief valve, which reduces flow.
2. Yes, but only if you have an engine that uses a variable oil pump which requires a specific bypass pressure. Bypass pressure ratings are sort of iffy, they don't often give a range, but Fram does and you can assume the single rating is in the middle of the range they give. And no, the Fram flows fine until like any filter, it is plugged up.
3. No drawbacks at all except price . The two layers give it higher capacity, The inner finer layer clogs slower because the outer coarser layer is dong the heavy lifting with large particles while still maintaining low flow restriction.
I hope some explanation helps rather than single word answers and all I said is best effort, my opinion, basis.
cheers
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: Farnsworth] #5463302 06/26/20 12:18 PM
Z
ZeeOSix Offline
Z
Variable volume PD oil pumps put out less oil volume at lower RPM because the engine doesn't need as much oil volume to properly lubricate it. And variable volume oil pumps typically don't put out as much oil volume over the RPM range as an "old fashioned" non-variable PD oil pump because engineers are always trying to reduce the oil volume flow to gain that extra 0.01 MPG, and still provide adequate oil flow for proper lubrication.
So if an oiling system has a variable output pump, it doesn't dictate what the filter's bypass valve is going to be set at. A bypass valve setting is dependent on the filter's flow performance, and what the expected max oil viscosity and flow rates are expected. One filter can be specified for hundreds of different engines, so the bypass valve setting is not specified specially for each application.
Re: Fram Ultra Synthetic: Flow Restriction, Bypass Setting, and Fine Filtration [Re: ZeeOSix] #5463310 06/26/20 12:25 PM
L
LubricatusObsess Offline
L
ZeeOSix,
Before my account is deleted, I want to ask aren't PD oil pumps variable flow with engine rpm? The amount of oil flowed is dependent on unit time, with lower speed the unit time is reduced.
I've appreciated your fact-based posts with your knowledge and background, not resorting to personal attacks on those trying to learn more. Thanks.
