Forums Migration
Please read this thread
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
71 registered members (alarmguy, 55hambone, 77Se7en, afree, 94astro, ABN_CBT_ENGR, 10 invisible), 1,177 guests, and 45 spiders.
Topics307,629
Posts5,314,526
Members71,888
Page 1 of 3 1 2 3
Plumbing woes: laundry cleanout plugged again #5462453 06/25/20 02:15 PM
Y
y_p_w Offline OP
Y
I've had this problem before and paid a plumber to clean it out.
We've got a laundry room cleanout on the lower floor. It seems that the upstairs kitchen sink drain is also connected. We used to have problems with the kitchen sink filling up, but not any more. However, what I see now is that water shot up through a sink in the laundry room and is filling up the washing machine. I'm removing that water by hand and dumping it. It smells like dishwashing detergent. I tried cleaning out the cleanout with a 25 ft plumber's snake, but that's not doing anything. When I remove the plug it will often shoot water up and slightly flood the floor, but it's slightly inclined and moves away.
I don't think it's creating a problem with our main sewer line. If it was the waste from the toilet would be coming out of the cleanout. Like I said, it smells like dishwashing detergent. If there was human waste in there I'm sure I could tell. I'm not quite sure how it all started recently other than I had problems with the kitchen sink flowing slowly, so I used a plunger to try to clear it out. When I first opened the cleanout plug, I saw some crusty stuff come out as well as some brown sludge. There's also a lot of sand that shot out of the laundry room sink.
I'll probably get a plumber, but that might take some time to get an appointment.
Once it's fixed, should I used one of those enzyme build-up removers? I had a little bit left and tried dumping it in the cleanout, but I'm not sure how fast that would act.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462460 06/25/20 02:24 PM
W
WhyMe Offline
W
go to home depot and rent a larger snake and snake it yourself. its $50 or so for 4 hours.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462476 06/25/20 02:38 PM
Donald Online Content
Online Content
Hire the plumber. While he is clearing the clog ask him what to do to prevent and what to do next time it happens.
2015 Ford F-250 w/Powerstroke
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462501 06/25/20 03:06 PM
old1 Offline
Sand shot out?? That sounds like somewhere in the ground there is a pipe that is broke or somehow has a hole in it. If that is the case, just cleaning it out will result in only a very temporary fix.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462514 06/25/20 03:29 PM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
I've had our laundry drain pipe develop atherosclerosis from lint buildup. Thankfully it is only a 3' pipe to the main house drain. A complete disassembly and cleaning of the pipes cured the problem.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462535 06/25/20 03:43 PM
PimTac Offline
Sand doesn’t sound good. The plumber should be able to run a camera down and check for a break in the line. You are in earthquake territory and pipe breaks happen.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462537 06/25/20 03:43 PM
CT8 Offline
Did you buy my house in San Bruno? I had a problem where there was a section of pipe under the garage floor that about every 3 or 4 years would clog. just ran a snake through the clean out on the wall .
2015 F150 2.7
2018 F350 6.2
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462568 06/25/20 04:11 PM
BlueOvalFitter Offline
How old is the house? In the '40's, to save money, the government had plumbers install tar wrapped cardboard pipe called ORANGEBURG. Sometimes when a plumber snaked out a sewer line the snake head would put a hole in it. Plumbers installed this pipe into the 1960's.
2007 F150, XL, 4.2 V6
5W30 Amsoil Signature Series Oil
NAPA GOLD 1516 Oil Filter
Re: Plumbing woes: laundry cleanout plugged again [Re: BlueOvalFitter] #5462677 06/25/20 05:44 PM
Y
y_p_w Offline OP
Y
The house is old. If I could afford to, I'd tear the whole place down and start from scratch just to eliminate all the issues with late 40s construction and weird 60s/70s era remodeling.
But the pipe is solid. It's definitely metal.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462737 06/25/20 06:47 PM
PimTac Offline
We lived in a house built in the 20’s that had a iron sewer line. It started to give us problems and we got used to twice annually renting a snake. Finally the problem got so bad a contractor came in. The line had rusted badly and collapsed. It was condemned and a new ABS line was installed and patched into the main outlet.
Being made of metal is not a sure thing.
2017 Mazda CX5
Roki OEM filter.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462747 06/25/20 07:07 PM
In Tampa, FL. there is an Island named DAVIS ISLAND. In the '20's they dredged Tampa Bay and built DAVIS ISLAND with that material. 95% of the houses built there had Orangeburg pipe for there sewer lines.
My best friend there owned his own plumbing company. When l wasn't detailing cars on the weekends l would help him replace sewers on DAVIS ISLAND. That OB pipe was some nasty stuff. Its biggest enemy was roots. And, a plumbers snake line.
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462801 06/25/20 08:29 PM
1
14Accent Offline
1
I don't have much to add as far as your problem goes, but it reminded me of a funny story of mine:
My house is OLD, built in 1905. One of the first in the neighborhood as far as I know. It's been updated many times over the years, including the plumbing, but the sewer lines are definitely old compared to the rest of the plumbing.
I was dating my ex when I bought the place, and soon after we moved in she decided that we needed a garbage disposal. I never had a disposal as a kid, and I was 100% against the idea, but guess who won that discussion... Keep in mind this is the house that I paid for, whose name was on the deed, etc. etc. Anyways, full well knowing it was a bad idea, I helped her dad install a disposal. Not one week went by before we had our first issue: she cooked cheese tortellini for dinner and decided to dump the leftovers down the disposal... turning them into somewhat of a pasta-cement. Low and behold, the sink clogs. I went down into the basement and found the clean-out, which was directly below the kitchen sink. Between being annoyed and naive, I proceeded to remove the access plug... which immediately resulted in a pressurized stream of backed up water and chopped, cooked pasta being sprayed all over me and the basement floor. Needless to say, I was not happy.
Long story short, it took her father and I 2 hours with a 100' snake to clear things out. No, it wasn't all the pasta, but to this day 6 years later I've never had another issue with the sink or any of the plumbing, for that matter. I've also unplugged the stupid disposal. Trash goes in the trash, not the drain. Also note: I said EX!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5462896 06/25/20 10:31 PM
7
77Se7en Online Content
Online Content
7
When the dirty clothes water exists the washing machine, is there always a filter on the end of the black hose?
In the laundry tub, I use a specific, specialized drain cleaner that removes hair and garment residue. Sold at Lowes or Home Depot.
Crusader / Intuitive / Whisperer-Medium
My Christmas Wish List reads.....
Ravenol DXG
Schaeffer 9000
Re: Plumbing woes: laundry cleanout plugged again [Re: y_p_w] #5463001 06/26/20 05:05 AM
Delta Offline
Old metal pipes are very easy to build up gunk and cause problems. They start corroding and build up very quickly. Honestly if it's easily accessible a re-pipe in plastic is the best and cheapest route. I've done that here; got tired of snaking out the old 1 1/2" galvanized on a couple lines. Replaced all with plastic and haven't had to touch it since. The larger 4" cast iron isn't near an issue as the smaller galvanized they used.
'17 VW GTI 2.0T - 6MT - 22K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 27K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 142K - RGT 5w30
Re: Plumbing woes: laundry cleanout plugged again [Re: 77Se7en] #5463250 06/26/20 11:18 AM
Y
y_p_w Offline OP
Y
There's no filter. It goes straight into a dry standpipe that I had to to make myself out of several pieces of plastic pipe after the previous metal one wore away at the bend. When I was younger, my parents had a laundry setup where the drain hose went straight into a sink. My mom set it up with some old stockings as a filter to trap lint and sand. The house they've lived in for years started off with a traditional cast iron sink. Even after they remodeled and moved the laundry area, they set it up with the drain hose into the sink so they could filter it with the stockings.
I just ordered a 3-pack of something called Green Gobbler sold at Home Depot. They have a variety of different treatments and cleaners, including powders, strips, and liquids. The one I ordered comes in single-use packets. They claim that it eats through grease/food/etc. They even have an infomercial:
I'm skeptical, but I'll give it a try. Plumbers around here are charging a few hundred for a visit. I know one plumber who is very reasonable (maybe $120 to clean out a line) but he's really busy and doesn't always respond quickly.
Page 1 of 3 1 2 3
