FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
54 registered members (AlienBug, BAJA_05, 94astro, AndyB, Astro14, alarmguy, 6 invisible), 1,065 guests, and 39 spiders.
Topics307,398
Posts5,310,374
Members71,843
Pressure Washer Pump Suggestions? #5462099 06/25/20 08:06 AM
M
maverickfhs Offline OP
M
Have MSV3024 Power Washer with Honda GCV190, 3000 PSI and 2.4GPM and pump is toast.
Which one should I get or if you have any suggestions or recommendations would appreciate them? thumbsup
1
2
3
4
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462124 06/25/20 08:34 AM
Donald Online Content
Online Content
Based upon the engine you only have a limited selection.
AR makes good pumps, as does Comet. CAT makes the best. But you probably will not find a CAT triaxial pump for example.
2015 Ford F-250 w/Powerstroke
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462127 06/25/20 08:37 AM
Online Content
Some pumps are rebuildable if the housing is not cracked.
Why did the pump break?
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462128 06/25/20 08:38 AM
R
Rand Offline
R
with those options... 4.
Re: Pressure Washer Pump Suggestions? [Re: Donald] #5462130 06/25/20 08:40 AM
M
M
It leaks water not from the top/high pressure area, rather bottom part where the tube for soap goes into the pump housing.
I got it as-is so no idea why it broke down, assuming pump got frozen and cracked from various places.
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462191 06/25/20 09:35 AM
R
Rand Offline
R
a step up would be AR or comet brand expect near $200
Re: Pressure Washer Pump Suggestions? [Re: Rand] #5462226 06/25/20 10:04 AM
M
M
That's an AR or no? https://www.amazon.com/Atima-Replacement-308653052-RMW22G24-EZ-RMW22G24-EZ-SX-PKG/dp/B07NN5FTLR/ref=sr_1_23?crid=14P2EMVL3KWU2&dchild=1&keywords=510003+pump&qid=1593049527&sprefix=510003%2Caps%2C1963&sr=8-23
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462227 06/25/20 10:07 AM
R
Rand Offline
R
no that is altima brand.
just Chinese pump you never heard of.
AR pump
https://www.pwoutlet.com/AR-RMW2-5G28-EZ-Pump-p/rmw2.5g28-ez.htm
Re: Pressure Washer Pump Suggestions? [Re: Rand] #5462233 06/25/20 10:10 AM
M
M
AR pump
Thank you thumbsup
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462239 06/25/20 10:15 AM
dave123 Offline
None of above
CAT pumps I would recommend
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462246 06/25/20 10:17 AM
M
M
Any idea where can I find CAT pumps and if there be a one which can be installed on this power washer?
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462259 06/25/20 10:45 AM
M
MNgopher Offline
M
None of the above. AR, Cat, or Comet. Unfortunately, because of the engine style you aren't going to find a lot of better performing stuff - just a lot of consumer grade junk.
Re: Pressure Washer Pump Suggestions? [Re: MNgopher] #5462276 06/25/20 10:59 AM
M
M
Is it worth fixing in terms of the motor being good? Or just get rid of the working motor then and call it a day?
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462286 06/25/20 11:07 AM
M
MNgopher Offline
M
I'd just say if its worth fixing, its worth fixing right. Looks like AR may be the only pump manufacturer of the three many have mentioned that makes a vertical pump which you need for your application,
Re: Pressure Washer Pump Suggestions? [Re: maverickfhs] #5462305 06/25/20 11:36 AM
E
e30m3pilot Offline
E
I have a Honda GX 390 with a CAT pump. Wow is it good. Put on the zero deg nozzle at full pressure and WOT and you can cut wood like a water jet. Honestly its a bit much so I dial it back for normal work but its fun to know what it can do.
https://oiludder.com/ Inventor 1 of 2
1991 BMW E30 ///M3
2003 Chevrolet Silverado 2500 6.0L
2013 Chrysler 300S 3.6L
2007 Z06 Corvette - Sold
