Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
12 registered members (Brynjaminjones, GMguy84, edhackett, domer10, Char Baby, blufeb95), 570 guests, and 28 spiders.
Topics307,388
Posts5,309,615
Members71,821
Any other CX-9 owners here? #5462043 06/25/20 06:40 AM
grampi Offline OP
I've gotta say, two weeks into the ownership of this vehicle, I'm loving it more and more every time I drive it. It's an absolute joy to drive. It rides nice, it's quiet, has plenty of power, especially low end grunt, has plenty of interior space, and the build quality seems impeccable. The dash layout looks like it belongs in a much more expensive vehicle, all of the controls are simple to use, and it's easy to figure out how everything operates simply by using. My only disappointment is that I didn't consider this vehicle sooner! IMO, Mazda is building some of the best vehicles made right now. The build quality of this vehicle is much better than that of the Toyota Sienna we traded for it...
Re: Any other CX-9 owners here? [Re: grampi] #5462102 06/25/20 08:08 AM
Zee09 Offline
I looked at one and it was inexpensive and well made but can't tow much so I passed on it.
I think for a commuter vehicle you get way more than you pay for-no doubt.
"If I walked on water, they'd say I couldn't swim."
Re: Any other CX-9 owners here? [Re: grampi] #5462106 06/25/20 08:11 AM
drtyler Offline
Thank the turbo for the low end grunt, as you say. The non-turbo 2.5 is a dog in the heavier vehicles.
Re: Any other CX-9 owners here? [Re: grampi] #5462210 06/25/20 09:48 AM
JohnnyJohnson Offline
Nice looking cars but I'd personally like one in Non-Turbo and a V-6.
2004 Corolla 140556
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Any other CX-9 owners here? [Re: JohnnyJohnson] #5462238 06/25/20 10:14 AM
PimTac Offline
They don’t make them like that anymore.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Any other CX-9 owners here? [Re: JohnnyJohnson] #5462264 06/25/20 10:48 AM
M
mbacfp Offline
M
I had a 2012 Mazda CX-9 with the 3.5 (non turbo). Sold it at around 60,000 miles and had no issues with it. Great cars for sure. Only problem/concern is the engine has to be lifted up a bit to get to the water pump. Potential expensive long-term ownership cost.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Any other CX-9 owners here? [Re: PimTac] #5462341 06/25/20 12:38 PM
I know and I'm not about to buy a car with engineered in LSPI. With the oh you can fix it with this oil BS!
2004 Corolla 140556
2006 Duramax 77117
Re: Any other CX-9 owners here? [Re: JohnnyJohnson] #5462415 06/25/20 01:40 PM
grampi Offline OP
What's LSPI?
Re: Any other CX-9 owners here? [Re: grampi] #5462426 06/25/20 01:49 PM
PimTac Offline
Low Speed Pre Ignition.
We used to call it knocking. They have a fancy name for it now. The Mazda SkyActiv engines are not noted for this so don’t worry.
2017 Mazda CX5
Roki OEM filter.
Re: Any other CX-9 owners here? [Re: JohnnyJohnson] #5462787 06/25/20 08:03 PM
Number_35 Offline
The Mazda CX-7 was available with a turbocharged 2.3 l engine that was prone to LSPI. I'm not aware of any problems with the newer (SkyActiv) engines.
The 3.5 and 3.7 l V6 engines used in the previous-gen CX-9 were problematic; they are mounted transversely, and to make them fit the designers moved the water pump inboard, driven by the timing chain. When these pumps leak, the coolant can go right into the oil, ruining the engine quickly. This is also a problem with the Fords which use the same engine. Again, it's only the transversely mounted engines that are the problem - the N-S engines used in some Fords have enough clearance that the WP is mounted on the outside of the engine per usual practice. Given the record of catastrophic failures with the 3.5 and 3.7, I would only consider a CX-9 with the turbocharged 2.5.
Re: Any other CX-9 owners here? [Re: Number_35] #5462840 06/25/20 09:18 PM
PimTac Offline
Only the older CX9 had that Ford V6. The switch was 2016 I think as Mazda went totally SkyActiv with that model line. It was the last model to switch over I think.
2017 Mazda CX5
Roki OEM filter.
Re: Any other CX-9 owners here? [Re: JohnnyJohnson] #5463308 06/26/20 12:19 PM
edyvw Offline
One of the most inefficient engines in its class. It was FORD.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Any other CX-9 owners here? [Re: grampi] #5463993 06/27/20 09:38 AM
grampi Offline OP
The 3.5 Ford engine would've kept me away from the CX-9. That's the same engine Ford used in its Edge, with the internal water pump that had a very high failure rate. I have not heard anything bad about the 2.5 turbo engines...
Re: Any other CX-9 owners here? [Re: grampi] #5464039 06/27/20 10:54 AM
W
Ws6 Offline
W
Cx5, here. Same engine and transmission. Got 42k miles on mine nearly with narry an issue.
2019 CX5 Grand Touring Reserve
Re: Any other CX-9 owners here? [Re: grampi] #5464042 06/27/20 11:09 AM
ArrestMeRedZ Offline
Grampi, I thought your next vehicle purchase was to be a Corvette?
