Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
108 registered members (72te27, 2010Civic, 18LateModelFan, 14Accent, 4WD, 9 invisible), 1,807 guests, and 25 spiders.
Topics307,463
Posts5,311,619
Members71,852
Page 1 of 3 1 2 3
hi perf engine runs bad. how to diagnose? #5461809 06/24/20 09:08 PM
T
tomcat27 Offline OP
T
we built this a few years ago - Dart 351 block with Eagle stroker kit. ran strong and good. until now. I strongly suspect one of the kids trashed on it; and he also replaced the ignition box with a different unit, anticipating to add nitrous (against my wishes). I know its hard to diagnose without seeing; but how do I proceed?
it misses, stumbles, cant hold a steady idle, and has only middling power. compression is good - 180. the timing makes NO sense: when we built the engine, it had 35 degrees total advance. I dont know the initial timing; likely around 20? right now it needs 50 degrees of initial timing to run somewhat smoothly. Yes, that makes NO sense. we checked that TDC is correct and aligns with the timing marks. I've swapped the original MSD box in there and it still runs poorly. replaced. I don't know what to check next - or why the timing is so wacky. vacuum seems to go up when you accelerate. I know. makes no sense. my buddies in our "garage club" are puzzled.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461819 06/24/20 09:18 PM
clinebarger Offline
The cranking compression is high....Especially with any kind of performance grind which I assume it has? I would consider checking Cam/Valve Timing.....Maybe it sheared the dowel pin on the camshaft?
2001 Chevy Camaro L92/4L80E
Re: hi perf engine runs bad. how to diagnose? [Re: clinebarger] #5461824 06/24/20 09:22 PM
T
tomcat27 Offline OP
T
pull the timing cover? it's a mid-performance grind. 12:1 compression; or maybe 11.5:1
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461839 06/24/20 09:40 PM
Astro14 Online Content
Online Content
If it takes 50 degrees of timing to run right, then I suspect that the chain itself has jumped a tooth, or two.
So, the mark for TDC is fine, but the cam is nowhere near where it should be when the crank was at TDC. Cam timing off by 15 degrees explains everything: weird timing to get it to run, high compression, poor idle, lousy power, and vacuum.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461843 06/24/20 09:42 PM
Online Content
Yep, pull the cover.
This happened to me on a 302 Ford many years ago. Not a high performance car, but many of those symptoms, and the chain (with the nylon silencer on the gears) had jumped a tooth on the cam gear.
New timing set. Ran like a dream.
32 Packard 15W40
05 MB S600 0W40 M1
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461860 06/24/20 10:13 PM
Srt20 Offline
Pull the dist. cap??
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461915 06/24/20 11:39 PM
L
Linctex Offline
L
You only have :
1) fuel/air mixture correct (including bad gas)
2) ignition at the right time
3) valves open & close when they should
Let us know what you find!
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461938 06/25/20 12:07 AM
spasm3 Offline
Is the 180 compression on all cylinders, or did you just check one? I agree with pulling the timing cover. I might pull the valve covers first and make sure all the rocker arms are in place and moving.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461978 06/25/20 03:32 AM
M
ms21043 Offline
M
Stick a breaker bar on the crankshaft bolt and rock it back and forth while watching the distributor rotor.
5W30, whatever's on sale
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5461988 06/25/20 04:41 AM
M
ms21043 Offline
M
...also while you're rotating the crankshaft back and forth with the breaker bar, is there any unusual feel or movement of the crank damper & pulley assembly?
Re: hi perf engine runs bad. how to diagnose? [Re: Astro14] #5461994 06/25/20 04:56 AM
O
OVERKILL Offline
O
Yup, this.
If it's easier to pull the passenger side valve cover, you should be able to check that both valves are closed when it's on TDC on #1 on the compression stroke. If they aren't, then you know valve timing is way off.
2020 Jeep Grand Cherokee SRT Ravenol SSL 0w-40, FRAM Ultra
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5462002 06/25/20 05:31 AM
M
ms21043 Offline
M
If any valve on the #1 cylinder was not closed at TDC on the compression stroke, that cylinder would have no compression.
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5462004 06/25/20 05:42 AM
M
ms21043 Offline
M
I've never seen cam timing jump towards advance in a running engine. I suppose it's possible. When cam timing does jump, it retards. If the engine is still able to run, symptoms include low compression on all cylinders and low vacuum.
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5462009 06/25/20 05:49 AM
T
Trav Offline
T
What distributor is this engine running, is it running a vacuum advance? For the vacuum to increase as rpm's rise you are taking a reading from ported vacuum.
It certainly could be some sort of of cam timing issue and I would almost bet it is but check the obvious first like the distributor controls eg connecting to manifold vacuum instead of ported, etc.
What cam is in this engine, compression is high for anything much more than stock.
Re: hi perf engine runs bad. how to diagnose? [Re: tomcat27] #5462047 06/25/20 06:44 AM
T
tomcat27 Offline OP
T
No vacuum advance in the MSD distributor. Cam is custom 226'duration intake 230 exhaust 110 separation with 565 lift. Compression was 180 in 5 cylinders, 160 in one, 170 on another. The two lower cylinders are not next to each other. I couldn't get the 8th.
Page 1 of 3 1 2 3
