Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
85 registered members (55Test, andyd, addyguy, 555, 928, 55hambone, 16 invisible), 1,474 guests, and 28 spiders.
Topics307,431
Posts5,310,875
Members71,843
What a mess! #5461511 06/24/20 01:42 PM
Chris142 Online Content OP
OP Online Content
Another shop took in an AC job on a early 90's chevy pickup. They made a mess of things. First they wanted to upgrade the condenser to one for R134a.
They ordered one for a newer truck. FYI R12 ac lines on this truck are sae. When GM went to R134a they also went to metric threads. The other shop tried to ram the lines home.
Had a leak there since the line did not seal. Then they got the correct condenser but managed to cross thread that one. I spent the morning with a thread file,. Torch to clean the aluminum chips out of the metal threads and got it together.
They beat the snot out of the new compressor trying to install it instead of figuring out why it was such a tight fit.
Then fat o-rings where skinny ones go,this cuts the o-ring.. Incorrect sealing washers on the rear of the compressor resulted in yet another leak.
Pics for your enjoyment.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What a mess! [Re: Chris142] #5461532 06/24/20 02:21 PM
B
BMWTurboDzl Offline
B
What a mess
435i
Re: What a mess! [Re: Chris142] #5461544 06/24/20 02:38 PM
M
Miller88 Offline
M
Was the customer able to get anything back from the other shop?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: What a mess! [Re: Miller88] #5461546 06/24/20 02:41 PM
OP Online Content
The other shop brought it to me. Guess they never heard of pressure testing stuff.
Re: What a mess! [Re: Chris142] #5461551 06/24/20 02:53 PM
Throt Offline
What I don't get is the repeated error making. They consciously and knowingly continued to do things they knew weren't correct. So many times they could've stopped but plowed ahead anyways. Don't get it.
'18 Honda Accord Touring, 1.5T, 25,000mi, PUP 5w20 w/ FU.
'19 Elantra, 2.0NA, 10,000mi, Dealer Fill/Filter, hers (lease)
Re: What a mess! [Re: Throt] #5461608 06/24/20 04:07 PM
L
Lolvoguy Offline
L
It's really quite simple to understand.
This is the result of underpaid, and inexperienced/untrained staff attempting to do repairs that only those with experience/time can do.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: What a mess! [Re: Throt] #5461675 06/24/20 05:52 PM
L
Linctex Offline
L
Olden days auto mechanic shops were better at researching & diagnosing. Chris142 is one of the few that remain.
The rest..... load up the parts shotgun and blast away with Chinese parts.....
Re: What a mess! [Re: Lolvoguy] #5461706 06/24/20 06:41 PM
T
The_Nuke Offline
T
My money is on pigheadedness...the former mechanic(s) saw the vehicle’s unwillingness to submit as an affront to their manhood and took a “I’ll show you!” approach to the rest of the job.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: What a mess! [Re: Linctex] #5461730 06/24/20 07:14 PM
OP Online Content
Thanks. I am not perfect though. But I have never beat a compressor into submission lol
Re: What a mess! [Re: Chris142] #5461741 06/24/20 07:29 PM
02SE Offline
Lots of hacks out there masquerading as competent in their profession.
Re: What a mess! [Re: Chris142] #5461759 06/24/20 07:58 PM
B
bullwinkle Offline
B
I'm still at a loss as to why shops don't use R12 in an R12 system (or even MP39 or R409A), it would be a LOT easier than attempting to change literally everything to try to run R134A (which is on it's way out anyway for R1234YF)!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: What a mess! [Re: Chris142] #5463087 06/26/20 07:54 AM
SeaJay Offline
Like many other businesses today, everyone wants the lowest price. And that is what many shops provide along with the work quality commensurate with the lowest price.
Re: What a mess! [Re: Throt] #5463862 06/27/20 06:31 AM
J
Jarlaxle Offline
J
Mix inexperience with stubornness. Add a heaping helping of stupid and garnish with incompetence.
1979 Coupe de Ville, 542 stroker, Super Tech 15W-40, Super Tech filter
2013 Challenger SRT8 Core, Valvoline synthetic 0W-40, Purolator
2011 Sportster 883, SYN3 20W-50, HD black
Re: What a mess! [Re: bullwinkle] #5463863 06/27/20 06:32 AM
J
Jarlaxle Offline
J
Mostly...because R-12 is essentially unobtanium. (And a lot of the available "R-12" is actually propane.) R-134a is available at Walmart. My Caddy and my wife's Blazer and Grand National have R-12 systems converted to R-134a.
Re: What a mess! [Re: Chris142] #5463865 06/27/20 06:36 AM
Mr Nice Offline
Unfortunately some mechanics have zero pride in the quality of their work.
Slap on parts and move on to the next vehicle. smirk
