Haven't had much experience with threadlockers. The MG decided to part ways with a couple of machine screws holding the auto choke on the the carburetor. It was suggested to me to add a dab of blue Loctite to them. Only wrinkle is that the hole for one of them is tapped into the side of the float bowl; I figured out something was wrong when I got a whiff of gas fumes as it was dribbling out of the hole. I put them all back in with a dab of it, made sure they were tight, but does it hold up to gas? I'm letting it cure for the recommended 24 hours before I try to start it.
Lock washers aren't an option since these are flathead screws.
