School me on '16 Camry cabin filter R+R
Marshfield , MA
I bought 2 OEM CAFs I'm totally clueless on the R+R. This is my first Cabin air filter equipped car. Please school me on the procedure.TIA
If you open the glove box and remove its contents, there is a large black "door" secured by a tab (on the right, as I remember) that you'll see makes up the rear of the cavity. Open that, and you'll find a smaller secondary door with tabs on each end. That covers the filter itself and is tighter-fitting. Take that off as well and you'll see the side-view of the filter.
The filter slides out; note the proper direction of installation and install the new one in the same way.
This shouldn't take more than 5 minutes; install on these is a breeze. Mine seem to be good for a year or two.
It's in the glove box. Pretty straight forward. Open glove box, remove access panel, remove and replace filter.
CAUTION: Some Toyota models require "RECIRC" on to avoid damaging the internals so you may want to investigate before proceeding.
Thank You gennulmen. Next stop You Tube
