2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
84 registered members (bdcardinal, Ag76, 2015_PSD, aquariuscsm, ArrestMeRedZ, 555, 8 invisible), 2,075 guests, and 40 spiders.
Topics307,411
Posts5,310,590
Members71,843
Oil pressure #5460960 06/23/20 05:03 PM
M
MoparJR87 Offline OP
M
2003 Dodge ram 1500 4.7 when driving for 15 minutes oil pressure gauge drops at stop lights and when brake is let off pressure comes back to normal. Not the oil pressure sending unit that was changed twice. What the heck is going on? Is this common for the magnum engines?
2003 Dodge ram 1500 4.7L 156k
2006 Ford Explorer 4.0L 110k
2011 Kia rio 1.6L 56k
1999 Ford E 150 4.2L 200k
Re: Oil pressure [Re: MoparJR87] #5460966 06/23/20 05:12 PM
E
eljefino Offline
E
What happens if you throw it in neutral (to get slightly higher RPM)?
Are you sure you have an actual gauge, vs an idiot light with a moving needle (normal or low, binary)?
I put 5w20 in my ratty old 1994 dakota 3.9 and got an oil light at hot idle in neutral. I guess 10w30 was just thick enough to keep the light off.
Re: Oil pressure [Re: eljefino] #5460977 06/23/20 05:29 PM
M
M
Thrown it to neutral and it goes back to normal when im at a stop.i know the 4.7 are notorious for sludge issues im looking to removing the pan and looking what might be the issue. Yes the gauge goes all the way down till i let off the brake.
Re: Oil pressure [Re: MoparJR87] #5461033 06/23/20 07:30 PM
A
AandPDan Offline
A
Put a mechanical gauge on it.
I have an '00 with the 4.7. Sludge really isn't an issue if it has been maintained.
Re: Oil pressure [Re: MoparJR87] #5461331 06/24/20 09:10 AM
A
ARCOgraphite Offline
A
If you got around 15 at idle hot that should be OK.
Are You running weasle wee oil?
OTW may have some worn bearings or as Mopar jr87 mentioned, drop the pan and take a look at the pickup screen
IDK if these are known for loose or leaky pickup tubes over time ....
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Oil pressure [Re: MoparJR87] #5461379 06/24/20 10:24 AM
Duffyjr Offline
Had the exact same thing happen to my 89 GMC 5.7 and then one morning I fired it up and it sounded like someone was hitting the side of the block with a 5# sledge hammer. I now have a gently used crate engine in it.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Oil pressure [Re: MoparJR87] #5461399 06/24/20 10:55 AM
B
BAJA_05 Offline
B
I was under the impression the Magnum Engines were -- the 3.9L -- 5.2L and 5.9L gas engines for 94 through 2002??
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (48K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Oil pressure [Re: MoparJR87] #5461456 06/24/20 12:20 PM
DGXR Offline
Brakes are usually vacuum-assisted. Is there any connection between oil pressure and vacuum?
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Oil pressure [Re: BAJA_05] #5461497 06/24/20 01:20 PM
I
incognito_2u Offline
I
The 4.7L V8 was "Originally" referred to as the MAGNUM Engine, later referred to as the POWERTECH Engine.
Chrysler/Dodge 4.7L V8 Powertech
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Oil pressure [Re: ARCOgraphite] #5461565 06/24/20 03:13 PM
M
M
running the truck on Kendall liquid titanium GT-1 5w-30 with an stp extended life oil filter.
Did some research and a common problem is the pick up tube screen being slightly clogged so dropping the pan is what im doing this weekend. worst case it might be the bearings.
