Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
93 registered members (555, 928, 2015_PSD, 97tbird, 55Test, addyguy, 13 invisible), 1,480 guests, and 31 spiders.
Topics307,431
Posts5,310,881
Members71,843
Varnish removal for Carburetor? #5460940 06/23/20 04:37 PM
M
maverickfhs Offline OP
M
What's the go to method for cleaning varnish from float bowl, other components of a carb?
No ultrasonic cleaner here, so looking for DIY stuff smile
Thank you thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5460942 06/23/20 04:43 PM
sloinker Offline
Get the can of Berryman carburetor cleaner with the dipping basket. Fully dis-assemble your carburetor and place all the parts in the basket and submerged in the chemical for a day or two. No rubber, plastic paper. I'm not sure they even make the original formula stuff anymore but it sure worked good. But that smell.............yick.
This is some truly evil brew. Don't drink, inhale or get it on you.
https://www.berrymanproducts.com/assets/2AA-E-0901-0905-0955-SDS-1.pdf
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5460944 06/23/20 04:46 PM
M
M
Is this true or no?
Something we radio control airplane guys use to clean our glow engines, is an old Crock-Pot that has the ceramic removable tub. Fill it with antifreeze that is compatible with aluminum, disassemble the carb and put it in the crockpot on low overnight.
You can drop an entire glow engine into this solution, and it will come out looking brand new. The ethylene glycol dissolves the varnish deposits that the burnt methanol, nitromethane and castor oil fuel leaves on the engine, and doesn't harm the metal at all. Most glow engines are aluminum castings with either brass plain bearings or steel ball bearings, it doesn't hurt any of the metals.
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461084 06/23/20 08:58 PM
W
WyrTwister Offline
W
Thank you thumbsup
They still make B-12 Chemtool . I have some around here , some where .
Now , a lot of people on youtube seem to be using an ultrasonic cleaner & something like water and liquid detergent or simple green .
Wyr
God bless
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461118 06/23/20 09:56 PM
R
ripcord Offline
R
I bought a ultra-sonic last year and love it, love it! I've had awesome results throwing small carbs in a glass peanut butter jar filled with Berrymans B-12 and putting the jar in the ultrasonic cleaner filled with plain hot water. I tried gasoline in the jar with the carb when I first got it, which worked OK, but the B-12 works better.
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461169 06/24/20 12:41 AM
K
Kamele0N Offline
K
For a DIY...you can use diesel fuel...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461354 06/24/20 09:35 AM
E
Ed_Flecko Offline
E
Thank you thumbsup
You didn't specify - are you wanting to take the carb off, disassemble and clean it or are you wanting to use a product that you simply run through a running carb that will remove the varnish?
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Varnish removal for Carburetor? [Re: Ed_Flecko] #5461356 06/24/20 09:39 AM
M
M
Thank you thumbsup
Ed
For small engines it'll be removal of the carb and for a motorcycle it'll be while being installed. thumbsup
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461401 06/24/20 10:58 AM
Yah-Tah-Hey Offline
Thank you thumbsup
I always used lacquer thinner to clean carb components(haven't touched a carb in thirty some years). Keep it away from composite components.
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461426 06/24/20 11:30 AM
J
jeepman3071 Offline
J
Carb cleaner or brake cleaner. Remove gaskets and o-rings before cleaning, as it can damage them or cause them to swell up. Let the metal parts being cleaned soak in the cleaner for a few mins before cleaning them with a wire brush and spraying off with more cleaner.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461504 06/24/20 01:31 PM
F
Fordiesel69 Offline
F
Mix up acetone, xzeylene, and laquer thinner in equal amounts, and let it soak overnight.
Then rinse with hot water. And soak in a bath of warm water and phosphoric acid or miriatic acid diluted. I dilute my hand and rought guess but you want to see just alittle bit of bubble action with the aluminum. It will look new when done and be a dark grey color. When using acid it cannot be left unattended. You must remain near it as if you make a mistake and forget, the carb will 100% dissolve into nothing.
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461684 06/24/20 06:09 PM
L
Lubener Offline
L
Thank you thumbsup
I have even used starting fluid to remove varnish when doing a carb cleaning..
The "thinking" man's friend.
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5461804 06/24/20 09:03 PM
Cujet Online Content
Online Content
The liquid cans (not spray cans) of Berryman's B12 are probably the strongest solvents around, short of the liquid paint stripper that is "carburetor dip". B12 will strip paint, but not all that quickly. The cans are about $4 and work wonderfully if care is used.
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5465657 06/29/20 01:26 PM
T
tnt_motorsports Offline
T
Is this true or no?
My son does this with his RC nitro buggy engine and pipe. It is crazy the crap that boils out of the exhaust pipe. I personally like the B-12 carb cleaner, but this does work...
2014 Chrysler T&C 3.6L Mobil Super Synthetic 5W30
2012 Ram 2500 6.7L Cummins Mobil Delvac 1300 15W40
2005 Jeep Grand Cherokee 3.7L Mobil 1 high mileage 5W30
Re: Varnish removal for Carburetor? [Re: maverickfhs] #5465766 06/29/20 03:58 PM
J
jhellwig Online Content
Online Content
J
I use the napa carb dip. Throw anything in it for a day or two and it comes out looking new. Sometimes you have to scrap off some gunk and throw it in again. It isnt like the old carb dip that worked almost instantly but it still works great. If you are dealing with heavy rust that the dip wont get off use evaporust after the carb dip. Both the dip and evaporust are water soluable so there is no nasty junk to get rid of afterwards and easy to clean up.
I have tried getting by just using the spray carb cleaner but it evaporates to quickly to be left setting on something to eat the gunk.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
