How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
bigmike323, SolsticeSHO, Bazza32, Klink_II, williamshrader
71828 Registered Users
88 registered members (2015_PSD, ARCOgraphite, 1978elcamino, ArrestMeRedZ, 64bawagon, alarmguy, 7 invisible), 1,255 guests, and 21 spiders.
Topics307,377
Posts5,309,603
Members71,828
Page 1 of 4 1 2 3 4
Why can't non-ACEA / OEM approved oils be used in European autos? #5460721 06/23/20 12:47 PM
wemay Online Happy OP
OP Online Happy
Leaving warranty discussion out of it and strictly from a technical point of view...
For example,
Some newer Porsche, Audi, VW and BMW recommend SAE 0W-20 or 0W-30 with an HTHS of 2.6 - 3.1. I've read on various boards that (some) owners are uncomfortable with the recommendation and will shorten the OCI to 5K miles versus the 10k.
Why wouldn't an easily attainable, locally sourced, high quality synthetic SN (now SP) motor oil, meeting the HTHS requirement suffice at this interval; or more for that matter? Ford and Honda (turbo heavy manufacturers) are doing fine without ACEA, why wouldn't the Euros do just as well?
Another example is my Santa Fe Sport 2.0T. Has simply use a good synthetic and 215K miles later...still going strong.
19 Passat Wolfsburg TSi, Valvoline Euro 5W-40 - S11784XL
13 Santa Fe Sport 2.0T, GTX Magnatec 5W-30 - M1-104A
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460734 06/23/20 12:58 PM
K
kschachn Online Content
Online Content
K
Well for one thing the European approval contains more than just an HTHS requirement, it also contains other requirements such as oxidation resistance, shear stability and viscosity retention. Unless the oil is tested against the entirety of the specific approval then how would you know if it is entirely suitable as a replacement?
Approvals matter, right? Not just grade. All of that plays into the long-life component of the approval. Go look at the Afton Specification Handbook for a typical European approval and see what the oil has to prove it is capable of doing.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Why can't non-ACEA oils be used in European autos? [Re: kschachn] #5460736 06/23/20 01:02 PM
OP Online Happy
Are those things as important if you're changing to a 5K mile oci versus 10K, which is why i put emphasis on that portion of the original post. Plus, there are SN oils that go 10K miles all the time too. No?
Devil's advocate whistle
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460742 06/23/20 01:07 PM
K
Online Content
K
No those are valid points, you don't have to be the devil wink Your comment about a shorter OCI is relevant and I missed that in your post.
Maybe you would take an oil with only an SN license to 10,000 miles in your Audi or VW, but I wouldn't,
1994 BMW 530i, 253K
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460743 06/23/20 01:08 PM
R
redbone3 Offline
R
You are not thinking European. You have to establish a separate standard to prevent the importation of cheaper products.
2014 Passat Wolfsburg, 1995 Miata.
Re: Why can't non-ACEA oils be used in European autos? [Re: redbone3] #5460744 06/23/20 01:10 PM
K
Online Content
K
Really? So you are advocating the position that an oil with only API SN is equivalent to one with Porsche A40 approval and could be substituted?
1994 BMW 530i, 253K
Re: Why can't non-ACEA oils be used in European autos? [Re: kschachn] #5460746 06/23/20 01:10 PM
OP Online Happy
Not planning to either. cheers
My Santa Fe 2.0T has gone over 200K miles on walmart synthetics, 4-5K mile oci and zero issues.
Re: Why can't non-ACEA oils be used in European autos? [Re: redbone3] #5460751 06/23/20 01:13 PM
OP Online Happy
Interesting point. Never thought of that.
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460765 06/23/20 01:27 PM
B
BMWTurboDzl Offline
B
For example,
Ford, Fiat/Chrysler, are members of the ACEA and they have their own ACEA based specifications so I'm not sure what you're talking about. GM has it's own specification. Honda and Toyota are members of the ACEA and I would think they have a particular specification for EU market.
Basically just about every motor oil out there has some sort of ACEA rating. Unless it's specifically marketed for hybrids. 5k OCI obviously matters but the majority of automakers have moved to long drain intervals so again, I'm not following you.
435i
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460768 06/23/20 01:35 PM
B
blingo Offline
B
Yes, with the longer intervals of for example up to 20,000 miles in lots of vehicles needing "longlife" oils anyway (and among those some times more engine-specific ones) there's much more focus on manufacturers' approvals than on ACEA over here.
Re: Why can't non-ACEA oils be used in European autos? [Re: BMWTurboDzl] #5460775 06/23/20 01:41 PM
OP Online Happy
For example,
I'm not talking about Ford or Honda sold in Europe...
I know there's a Long Life component to the ACEA OEM approved oils, again this concerns switching to a 5K-7.5K OCI.
Re: Why can't non-ACEA oils be used in European autos? [Re: wemay] #5460792 06/23/20 02:02 PM
B
BMWTurboDzl Offline
B
For example,
Almost every oil sold on the market is LL. Outside of Hyundai who's suggesting a 5k mile factory oci? Mazda?
435i
Re: Why can't non-ACEA oils be used in European autos? [Re: BMWTurboDzl] #5460802 06/23/20 02:12 PM
javacontour Offline
At least in 2012, Mazda suggested 7500 miles / 12000 km or 6 months.
I think 2019's went to a 10k mile / 16k km OCI...
network down, IP packets delivered via UPS -BOFH
Re: Why can't non-ACEA oils be used in European autos? [Re: javacontour] #5460808 06/23/20 02:17 PM
F
Fotoflame Offline
F
Subaru has a 6K OCI I believe.
Re: Why can't non-ACEA oils be used in European autos? [Re: Fotoflame] #5460828 06/23/20 02:32 PM
T
TTK Online Happy
Online Happy
T
Yes, Subaru has 6K or 6 months OCI
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Page 1 of 4 1 2 3 4
