Forums Migration
Please read this thread
Time to Dump or Repair?
by GMFan - 07/09/20 12:46 PM
TIREREVIEW : Videos
by odie - 07/09/20 12:39 PM
HYUNDAI ; Manual tranny w/o a clutch pedal
by odie - 07/09/20 12:30 PM
Need Pressure Washer Recommendations
by qdeezie - 07/09/20 12:28 PM
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
122 registered members (Alex38, Alfred_B, Ag76, 4WD, 2015_PSD, AdamZ, 8 invisible), 1,953 guests, and 52 spiders.
Topics307,644
Posts5,314,854
Members71,897
Loctite question #5460556 06/23/20 09:07 AM
Dave Sherman Offline OP
Haven't had much experience with threadlockers. The MG decided to part ways with a couple of machine screws holding the auto choke on the the carburetor. It was suggested to me to add a dab of blue Loctite to them. Only wrinkle is that the hole for one of them is tapped into the side of the float bowl; I figured out something was wrong when I got a whiff of gas fumes as it was dribbling out of the hole. I put them all back in with a dab of it, made sure they were tight, but does it hold up to gas? I'm letting it cure for the recommended 24 hours before I try to start it.
Lock washers aren't an option since these are flathead screws.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Loctite question [Re: Dave Sherman] #5460562 06/23/20 09:15 AM
B
Bighorn2500 Offline
B
Might be ok, depends how you interpret the data provided (95% of initial strength)
https://dm.henkel-dam.com/is/conten...242-Carded-Tube-0.20-fl-oz-2018-04-09pdf
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Loctite question [Re: Dave Sherman] #5460564 06/23/20 09:17 AM
T
Trav Offline
T
Quote
Chemical / Solvent ResistanceThe product retains effective properties in contact with automotive fluids, such as motor oil, gasoline, brake fluids, transmission fluids, alcohol and antifreeze solutions.
https://441py33rout1ptjxn2lupv31-wpengine.netdna-ssl.com/wp-content/uploads/tech_docs/tds/24206.pdf
Re: Loctite question [Re: Dave Sherman] #5460565 06/23/20 09:20 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Should be OK, IF you can get the surfaces clean and actually get a cure.
Even gasoline can leave behind hydrocarbons and oils that will influence the cure.
You should use 243, which is a bit more resistant to that, and use the loctite primer. The primer cleans and leaves some additional metal ions to help speed the cure. The ions arent always necessary (really there for more stable metals like stainless, to help speed the cure), but the cleaning is.
IIRC, the long term strength tests assume a well prepared, fully clean and properly cured connection.
So tell us how you cleaned and prepared it???
Re: Loctite question [Re: Dave Sherman] #5460588 06/23/20 09:41 AM
CT8 Offline
2015 F150 2.7
2018 F350 6.2
Re: Loctite question [Re: JHZR2] #5460591 06/23/20 09:44 AM
Thanks, I used a Q-tip that I wet with some carb cleaner in the holes, and even though the replacement screws were new in the bag I sprayed them with some carb cleaner and wiped them off. Made sure they were dry before I put the stuff on and put them in.
Re: Loctite question [Re: Dave Sherman] #5460626 06/23/20 10:30 AM
T
Trav Offline
T
That should be fine.
Re: Loctite question [Re: Dave Sherman] #5460672 06/23/20 11:17 AM
W
wings&wheels Offline
W
You should be fine, but I have used Hylomar w/ success on those exact threads on an MGB.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Loctite question [Re: Dave Sherman] #5460871 06/23/20 03:09 PM
U
Urshurak776 Offline
U
You should be good to go.
2012 Hyundai Santa Fe, 153,000 miles, Havoline Pro DS Full Syn 5W-20, COS3593A Champion Filter.
2014 Kia Rio, 92,000 miles, QS Full Syn 5W-30, COS3593A Champion Filter..
Re: Loctite question [Re: CT8] #5461131 06/23/20 10:21 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Originally Posted by CT8
That’s interesting stuff, but still needs cleaning and prep.
Quote
DIRECTIONS FOR USE
For assembly
1. For best performance, clean all threads with a cleaning
solvent such as Permatex Brake and Parts Cleaner and
allow to dry.
2. Determine if the threads to be bonded are Active or
Inactive Metals (Ref: Cure Speed vs. Substrate on the second page). If material is an Inactive Metal, spray all threads with Permatex Surface Prep and allow 30 seconds to dry. Priming is not required if the material is an Active Metal. If unknown, it is always best to use the activator.
Re: Loctite question [Re: Dave Sherman] #5461406 06/24/20 11:04 AM
DGXR Online Content
Online Content
I think you'll be fine. Surely you are planning to keep an eye on those screws for a while, right?
Mark the screw heads and flange with something (white out, marker, etc) so you'll notice if they start backing out.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
