Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
82 registered members (4WD, 77GrandPrix, 55hambone, 555, 928, 2015_PSD, 10 invisible), 1,454 guests, and 28 spiders.
Topics307,432
Posts5,310,893
Members71,847
Upper control arm preload? #5460513 06/23/20 07:43 AM
J
joshuawesl Offline OP
J
Replacing upper control arms in my 2003 Durango. I understand that the bushings should be tightened with some weight on the suspension.
As I have the wheel off - access is substantially easier. I have jackstands supporting the front side I'm working on, so could I theoretically just place a floor jack under the suspension assembly, pump away at it until the vehicle just comes off the jack stand, and tighten the bushings?
Or would it be best to just get the wheel back on, get the vehicle sitting level, and then tighten?
Re: Upper control arm preload? [Re: joshuawesl] #5460520 06/23/20 08:00 AM
Chris142 Online Content
Online Content
Tire on the ground
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Upper control arm preload? [Re: joshuawesl] #5460539 06/23/20 08:39 AM
A
ARCOgraphite Offline
A
If you lube 'em it may not matter as much.
I would Lube 'em and do what you were going to do.
Just completely re-built a '67 buick skylark front end
- all bushings, in the upper and lower A- Arms.
New Ball Joints
and new sway bar bushings and end links.
NO Issues - the car drives NEW.
I just used the screw jack to lift up the LCA to "near level"
[Linked Image]
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Upper control arm preload? [Re: joshuawesl] #5460543 06/23/20 08:49 AM
SLO_Town Offline
If they are rubber bushings that need to be pressed in, do NOT lube them. Let me clarify. When pressing in rubber bushings I often times use a window cleaner (Windex) or a very weak solution of dish washing soap and water (liquid Dawn) when pressing them it. That said, NEVER use grease intended for poly bushings. The bushings will turn in their bores and wear prematurely.
And, yes, like Chris said, tighten with the car on the ground and at its normal ride height.
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Upper control arm preload? [Re: joshuawesl] #5460571 06/23/20 09:23 AM
T
Trav Offline
T
On some vehicles it is impossible to gain clearance needed to tighten them with the wheel mounted on the ground, in that case load the suspension from the lower arms and tighten. It doesn't matter how you load the suspension as long as its loaded.
WD40 for rubber bushings works well and harmless to the rubber.
Re: Upper control arm preload? [Re: joshuawesl] #5460578 06/23/20 09:30 AM
K
kschachn Offline
K
I always liked how my old BMW manual showed the requirement (including passenger loading), you can get this any way you want as long as the measurement is met. This is for the rear but the front is similar:
[Linked Image]
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Upper control arm preload? [Re: joshuawesl] #5460881 06/23/20 03:23 PM
double vanos Offline
I take a measurement from wheel bearing hub to bottom of fender prior to starting. Lifting the arm til it just comes off the jack stands was pretty close to that measurement. Never had a problem.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Upper control arm preload? [Re: joshuawesl] #5460909 06/23/20 03:46 PM
K
Kawiguy454 Offline
K
Maybe I'm mistaken but aren't rubber bushings heat fused to the inner and outer sleeves? Neither sleeve ever rotates inside the rubber so no lube is needed. Lubing them can eat away at the rubber and cause the rubber to break loose from the metal.The rotation will then quickly wear out the rubber. Of course Poly bushings do rotate and need lube.
The Preload is supposed to "Capture" the inner sleeve in position with full load and rubber at rest. As the suspension moves the rubber provides elatomeric movement only and acts line a spring.
Re: Upper control arm preload? [Re: Kawiguy454] #5461017 06/23/20 06:59 PM
T
Trav Offline
T
Some bushing do not use a metal ring just rubber, for these WD40 helps get them in easy and will not damage the rubber. The metal shell ones require no lube.
Both of these are for the LCA, the metal shell for RWD the all rubber for 4WD.
[Linked Image]
[Linked Image]
Re: Upper control arm preload? [Re: SLO_Town] #5461313 06/24/20 08:35 AM
A
A
Scott
The "working" bores should be lubed for assembly - just a little.
The stationary part of UCA/LCA that press into the arms are captured in a shell and should not be lubed.
Got to be specific with working parts.
And poly or rubber anti-sway bar working bores should be lubed also. Unless you like squeaking and squawking.
You can use spit if you want for assembly. The fresh rubber has quite the bite to it.
