Amazon has an MTF GL4 called Ultra-Lub for $6/qt
Other than Amazon, the easiest GL4 to obtain that's usable in a manual transmission is Liqui-Moly 20012 from Napa
Not being able to find good GL4 you can use in a non-Honda manual has been one of my worries for a long time, since I learned you can't use the GL5 that stores actually sell. It makes me afraid to buy a non-Honda manual transmission. Honda manual transmissions can use motor oil, so there is less of a problem (some parts stores even stock synchromesh MTF that is also usable in them)
Originally Posted by Snagglefoot
Not sure if you can find Pennzoil GL-4 transmission oil In your area.
I have never heard of that one before
You can find cases of it on eBay
Originally Posted by Popsy
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
As Molakule suggested. My pick for that transmission...have it in two cars of my sig. Syntrans transaxle feels smoother on the long term.
Edit : maybe I presumed a bit, If you have the last gen Lancer, than I have the same Getrag transmission
Where do you get your Castrol Syntrans?
Sometimes if you're lucky, you can find an eBay seller in Europe that will ship to the US, albeit at a high price
