Forums Migration
Please read this thread
Time to Dump or Repair?
by GMFan - 07/09/20 12:46 PM
TIREREVIEW : Videos
by odie - 07/09/20 12:39 PM
HYUNDAI ; Manual tranny w/o a clutch pedal
by odie - 07/09/20 12:30 PM
Need Pressure Washer Recommendations
by qdeezie - 07/09/20 12:28 PM
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
117 registered members (77Se7en, 53' Stude, 2004tdigls, 94astro, 1911CHAMPION, 2010Civic, 12 invisible), 1,942 guests, and 37 spiders.
Topics307,645
Posts5,314,901
Members71,897
Gl-5 or gl-4 #5460032 06/22/20 04:09 PM
E
Espada Offline OP
E
My manual recommends 75w 90 gl-4 but most of what i found was 80w 90 gl-5 could gl-5 be used safely instead of gl-4?
1300cc Mitsubishi lancer 1.3 manual transmission
Re: Gl-5 or gl-4 [Re: Espada] #5460036 06/22/20 04:19 PM
Number_35 Offline
Hello Espada - I think you should use GL-4, even if have to order it. GL-5 has additives which can damage the brass synchronizers in a manual transmission.
I have been very pleased with Redline MTF. It's designed for manual transmissions, and contains friction modifiers than help the synchronizers get up to speed.
Best regards!
Re: Gl-5 or gl-4 [Re: Espada] #5460042 06/22/20 04:25 PM
J
Jimzz Offline
J
yup
Re: Gl-5 or gl-4 [Re: Espada] #5460064 06/22/20 04:46 PM
MolaKule Offline
Global Moderator
Global Moderator
Here is a list of MTLs in the 14-15 cSt (SAE 75W90) range:
NOTE: This list is only a “summary” list of MTFs available in the MTF Lubricant Market. It is not an endorsement nor a critique of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear.
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission Fluid XT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-9
9. LiquiMoly 75W-90 GL4
10. Pennzoil 75W90 GL-4
11. Motul Gear 300 GL-4/GL-5 (Product Number 100118)
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: Gl-5 or gl-4 [Re: Espada] #5460079 06/22/20 05:18 PM
G
GJM120 Offline
G
I'm trying to determine the correct differential fluid for my car. It's a BMW 1 Series.
It isn't clear if the fluid should be GL-4 or GL-5. The parts info shows a different fluid for earlier models but the differential is the same part number across all years.
Is there any harm in using one or the other?
I've asked this on a BMW forum to no avail.
Re: Gl-5 or gl-4 [Re: GJM120] #5460085 06/22/20 05:29 PM
J
Jimzz Offline
J
Gear oil for the diff will be GL-5. Many manual trans will call for GL-4.
yup
Re: Gl-5 or gl-4 [Re: Jimzz] #5460097 06/22/20 05:41 PM
G
GJM120 Offline
G
That's what I'm hoping as I changed out the fluid with GL-5. I don't think there are soft metals in the diff which I believe is where GL-5 can cause a problem.
I have to add the the fluid on one of the aftermarket vendor sites shows GL-4 for earlier cars and GL-5 for later. But, like I mentioned above, the part number is the same for all years of the car.
I think some people may be putting GL-5 in the transmission of manual cars. Mine is AT so not a concern for me.
Re: Gl-5 or gl-4 [Re: Espada] #5460115 06/22/20 06:07 PM
B
bullwinkle Online Confused
Online Confused
B
Some full syn gear oils like RP Max Gear are rated for both GL-4 and GL-5, but my experience was that Max Gear was too slippery and synchronizer operation was almost non-existent. A swap to GL-4 Pennzoil Synchromesh, and all was fine again!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Gl-5 or gl-4 [Re: Espada] #5460128 06/22/20 06:31 PM
Snagglefoot Online Content
Online Content
Not sure if you can find Pennzoil GL-4 transmission oil In your area.
If you want the job done right......do it yourself.
Re: Gl-5 or gl-4 [Re: Espada] #5460154 06/22/20 06:54 PM
J
JerryBob Offline
J
Here in the US, GL-5 is much more common also, but I go to the trouble of buying GL-4 online. I feel it's worth it for my Toyota manual transmission.
https://www.widman.biz/uploads/Transaxle_oil.pdf
Re: Gl-5 or gl-4 [Re: Espada] #5460162 06/22/20 07:00 PM
G
GJM120 Offline
G
CRC markets a GL-4 non synthetic. Also, Red Line MT90 is easy to find and it's a synthetic GL-4.
Re: Gl-5 or gl-4 [Re: JerryBob] #5460163 06/22/20 07:01 PM
G
GJM120 Offline
G
That paper is what got me searching for a GL-4 for the gearbox of my old motorcycle.
Re: Gl-5 or gl-4 [Re: Espada] #5460180 06/22/20 07:20 PM
A
aquariuscsm Online Content
Online Content
A
GL5 will ruin your synchros. Plus you'll get gear clash. If your car specs 75W50,get some Amsoil MTG or Redline MT90.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Gl-5 or gl-4 [Re: Espada] #5460253 06/22/20 08:27 PM
P
Popsy Offline
P
As Molakule suggested. My pick for that transmission...have it in two cars of my sig. Syntrans transaxle feels smoother on the long term.
Edit : maybe I presumed a bit, If you have the last gen Lancer, than I have the same Getrag transmission wink
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, M1 TDT 5W40 | Colt Ralliart, 300V 0W40
Re: Gl-5 or gl-4 [Re: MolaKule] #5460259 06/22/20 08:32 PM
RDY4WAR Online Content
Online Content
1. Amsoil MTG
2. Redline MT-90
I would add Driven GO GL-4 80w-90 to that list as well.
"He who is without oil, shall throw the first rod." - Compressions 9:1
