Forums Migration
Please read this thread
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
48 registered members (bullwinkle, bigjl, AlienBug, 87sammy, Char Baby, 77GrandPrix, 5 invisible), 903 guests, and 46 spiders.
Topics307,627
Posts5,314,507
Members71,888
Brake pads: caliper vs v-brake? #5460023 06/22/20 03:55 PM
Quattro Pete Offline OP
I've got an old mountain bike that uses basic caliper brakes. I need to get new brake pads for it.
Are the pads for caliper brakes different from pads for v-brakes?
Would pads like these work in caliper brakes?
https://www.amazon.com/gp/product/B005OLYU74
This is what's currently on the bike:
[Linked Image from i.imgur.com]
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460038 06/22/20 04:22 PM
skyactiv Offline
I've owned several bikes over the years but I had to Google V brakes to get an idea what they are. I've had a bike with such brakes and V brake pads tend to be longer.
New pads might not mate up perfectly flat to the rim when new until they are worn in. The pads in the link you posted should work fine despite the extra material.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460062 06/22/20 04:44 PM
T
Taildragger Offline
T
Have you tried your local bike shop? We have bulk bags of those.
73 Big Block, 4sp Corvette
Couple of airplanes
2019 F-150 Coyote
"Turbos on an engine is God's way of telling you it ain't got enough cylinders." Mike Skinner
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460078 06/22/20 05:17 PM
I
IndyIan Offline
I
Looks like those would work. You can also quickly flatten out or angle your brake pads on a sheet of coarse sand paper as well. I find the older the pads get the better they work as well, so I don't replace them until they are near the metal. I've got some V brake pads near 20 years old that will easily put you over the bars with 1 finger. Also if you take the tire off you can resurface your rims using a wire brush on a dremel to get some better braking.
06 Focus ZXW, 5spd manual, 220km
18 Outback 2.5 CVT 35km 0W20
Re: Brake pads: caliper vs v-brake? [Re: IndyIan] #5460086 06/22/20 05:30 PM
This bike sat for 20+ years. Plenty of material still left on the pads, but it doesn't seem to be doing much. I was thinking of resurfacing the rims, too. I was hoping something like goo-gone would get rid of old pad deposits, but maybe it's not strong enough?
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460110 06/22/20 05:59 PM
I
IndyIan Offline
I
I'd try flattening the pads out and use brake cleaner on a rag to clean the rims and brake pads, it seems to have no effect on the tires. Also have a look at your levers, some have a choice of two cable end positions which can give you more leverage. Even proper cable routing helps, one of my kids friends got a new dept store bike and the brake cables were being forced to contort around the shifter cables. Re-arranging the brake cables so they are straighter out of the lever and adjusting the brake pads got it stopping much better.
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460188 06/22/20 07:25 PM
Surestick Offline
Mounting style and pad length.
Some (cantilever brakes) use a non-threaded post. V-brake and road bike calipers brakes use a threaded post.
V-brake pads tend to be longer to the rear of the pad, road bike caliper brake pads look like the ones in the OPs pic, shorter.
I imagine the length difference has to do with frame clearance.
If I had to suggest pads for rim brakes I'd say KoolStop Salmon pads every time (unless you're using carbon rims or, getting old-school here, Mavic ceramic coated rims) but from the pic the OP posted neither is the case. The caliper brakes suggest a cheaper bike so I'd say clean the rims and throw on whatever the bike shop gives you for pads.
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5460479 06/23/20 06:52 AM
L
Lubener Offline
L
The pads you have are everywhere. I see them even in my local drug store and department stores for under five bucks.. I would just get the same style. They will work as well as anything else.
The "thinking" man's friend.
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5461091 06/23/20 09:06 PM
Thanks all. Those pads I linked to in OP fit fine, and I got the rims cleaned up with sandpaper. The squeaky noise is gone, but they don't stop any better than the old pads, unfortunately. I guess you can't expect this type of brakes to work as well as disc brakes or even v-brakes.
Re: Brake pads: caliper vs v-brake? [Re: Quattro Pete] #5461780 06/24/20 08:28 PM
I
IndyIan Offline
I
Keep an eye out at the dump, you could find someone tossing a bike with a V-brake fork and swap it over. Even cheap v-brakes set up well will stop well with two fingers. I almost pulled a bike out of the bin last weekend, it was old but looked new and stored inside, but I didn't really need anything on it.
