Forums Migration
Please read this thread
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
100 registered members (77Se7en, 4WD, Anthony, Avery4, 2015_PSD, ABN_CBT_ENGR, 8 invisible), 1,951 guests, and 29 spiders.
Topics307,771
Posts5,317,483
Members71,916
spark plug thread chaser #5459965 06/22/20 02:54 PM
Donald Offline OP
So the old Ford 300 engine in my snow cat. I started all the plugs in the spark plug holes and left the engine alone for 3-4 years. This weekend I unscrewed the spark plugs and the holes are rusty, new plugs do not want to go in easily.
i ordered a spark plug thread chaser.
How to I make sure that I get the tool in at the proper angle so I do not make the rusty hole worse?
2015 Ford F-250 w/Powerstroke
Re: spark plug thread chaser [Re: Donald] #5459980 06/22/20 03:07 PM
A
andyd Offline
A
Do you have a plumber's brush for cleaning copper pipe insides? Clean the threads, oil them, and start the plugs in by hand,
Thick oil is better grin2
Re: spark plug thread chaser [Re: Donald] #5459983 06/22/20 03:09 PM
supton Offline
I'd think a chaser would be unable to cut new threads. I'd want to put some grease on, so nothing falls into the engine, which should also lube the threads. So I'm thinking it's just a matter of feel--if it feels cross threaded, it is. If not, then just turn a bit harder.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: spark plug thread chaser [Re: Donald] #5459984 06/22/20 03:09 PM
J
JohnG Offline
J
A proper thread chaser should have a generous taper at the nose to prevent just what you are saying. Just be careful and gentle. I'd say that if you use oil, that should keep most of the debris from falling into the cylinder.
Re: spark plug thread chaser [Re: Donald] #5460005 06/22/20 03:29 PM
Convert Offline
I use one on my Moto Guzzi Motorcycle a couple of times a year, if you have ever used a tap you wont have any problems.
I bought a NOS cylinder head and was installing a spark plug and it would only go in 1/2 way due to corrosion on the thread's,
ran a chaser through the hole and everything was good. Head was off the bike but was going to be installed so it was easier to do the chasing .
You can do it!
Convert
Tom
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
2003 Husqvarna GTH2248XPC
USAF 1966-1970
Re: spark plug thread chaser [Re: Donald] #5460057 06/22/20 04:41 PM
CT8 Online Content
Online Content
Don't forget to put grease in the flutes of the thread chaser to catch the chips of metal / rust carbon etc.
2015 F150 2.7
2018 F350 6.2
Re: spark plug thread chaser [Re: Donald] #5460072 06/22/20 05:00 PM
J
JeffKeryk Offline
J
I spray a little WD-40 down the plug hole to clean and lube the threads.
And just a slight brush of anti-seize on the plug threads.
If I can't spin 'em in by hand, I find out why before continuing.
Finish with torque wrench.
Perhaps try this; if it fails go for the greased up plug chaser.
Easy peasey. Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
