Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
100 registered members (28oz, 1911CHAMPION, AdamZ, afree, 2015_PSD, amh, 11 invisible), 1,840 guests, and 47 spiders.
Topics307,632
Posts5,314,677
Members71,894
Page 1 of 4 1 2 3 4
High oil temp while towing: need more PAO/Ester, or more viscosity? #5459923 06/22/20 01:59 PM
Z
zuluplus30 Offline OP
Z
2017 Silverado 5.3 towing 7.5k on a routine basis now. Coolant temps hold at 207, then up to 215-220 until the fans pull it back to 207. I notice when I stop, the oil psi drops to <20 so the oil temp is definitely warm, but no gauge for accurate measurement oil temp measurement though.
My question is keep running 0w-20 Dexos (Currently on M1EP) and stay with a higher PAO/Ester oil, or step up a grade to 0w-30/5W-30 for the higher HTHS? I don't give 2 squats about MPG. This is purely for wear protection.
Edit: Almost out of powertrain warranty so viscosity in regards to warranty are moot.
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459927 06/22/20 02:08 PM
Z
zfasts03 Offline
Z
You could always shoot the oil pan with a non-contact thermometer and get an oil temp. reading.
From my understanding you do have an oil cooler, so probably all is fine. Probably also fine sticking with 0w-20 Dexos1gen2 also.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459929 06/22/20 02:11 PM
H
hemitom Offline
H
you answered your own question.
I would be running 5w30 .
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459932 06/22/20 02:16 PM
E
Eddddd Offline
E
No need to worry about wear protection with the 0W20 oil and a heavier weight oil won't necessarily give you better protection. I say you are fine with the 0W20.
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459939 06/22/20 02:21 PM
J
Jetronic Offline
J
Modern cars with variable displacement oil pumps try to keep the oil pressure at 15 psi. so as long as you are above that you're still fine. However, piston skirts and rings and cam lobes/followers aren't lubricated under pressure.
I would probably step up a grade, the heat of summer might make the oil even thinner.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459940 06/22/20 02:22 PM
MolaKule Offline
Global Moderator
Global Moderator
Or, use a 5W20 which has less VII and uses slightly higher viscosity base oils.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: Eddddd] #5459941 06/22/20 02:23 PM
K
kschachn Online Content
Online Content
K
Why not? MOFT always wins. Sounds like better protection to me.
And it's a grade, not a weight.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459944 06/22/20 02:29 PM
L
Linctex Offline
L
Purely anecdotal ... If it were me in your shoes, 5W-30 towing in the summer.
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: zuluplus30] #5459948 06/22/20 02:37 PM
P
PowerSurge Offline
P
How do you know the oil temp is high? All I see are coolant temps in your OP. You have plenty of engine protection with that EP M1 0w-20
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: kschachn] #5459953 06/22/20 02:41 PM
E
Eddddd Offline
E
Stand corrected. Heavier grade. There was a discussion about MOFT here on the forum. Here's the link. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5118764/1 If going to a heavier grade helps you sleep at night, then do you. It won't hurt the engine. I have a Tundra 5.7, live in South Texas and have towed 7k+ on a regular basis using 0W20. Oil samples show no issues but then again, we are talking about a Toyota. smile
Re: High oil temp while towing: need more PAO, or more viscosity? [Re: MolaKule] #5459960 06/22/20 02:45 PM
B
blufeb95 Offline
B
I'm not sure if that's necessarily the case with mobil1 EP, the 0w20 is like 60-70% PAO on the SDS, the 5w20 is only 5-10%, I assume the rest is probably hydrocracked dino if they don't specify. Since there's so much PAO in the 0w20 isn't it possible that since it uses a presumably higher quality base oil that it might actually have a lower VII content than the 5w20 variant.
Re: High oil temp while towing: need more PAO/Ester, or more viscosity? [Re: zuluplus30] #5459967 06/22/20 02:56 PM
splinter Offline
Perhaps that it has made it this far serves thusly for some as partial validation?
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: High oil temp while towing: need more PAO/Ester, or more viscosity? [Re: splinter] #5459985 06/22/20 03:13 PM
Z
Z
60K miles is hardly a nod to longevity.
Re: High oil temp while towing: need more PAO/Ester, or more viscosity? [Re: Eddddd] #5459987 06/22/20 03:14 PM
K
Online Content
K
I wouldn't expect it to.
1994 BMW 530i, 253K
Re: High oil temp while towing: need more PAO/Ester, or more viscosity? [Re: PowerSurge] #5459988 06/22/20 03:15 PM
Z
Z
Pure assumption, except under normal driving the oil pressure sits about 30-35 psi at idle. After towing, it sits about 19-20 during idle. My assumption is the oil is hot and thin.
Page 1 of 4 1 2 3 4
