Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
79 registered members (77GrandPrix, 4WD, 97tbird, alarmguy, 2015_PSD, 87sammy, 11 invisible), 1,395 guests, and 33 spiders.
Topics307,433
Posts5,310,929
Members71,847
A3B4 vs C3 And Oil Consumption #5459889 06/22/20 12:51 PM
M
moonlightblue Offline OP
M
Hello all,
First, I am already aware that this topic has been discussed long ago and I have read all posts.
However my question is that will it be really better to use A3B4 instead of C3 for minimizing the oil consumption?
Currently switched the oil from vw504 (liqui moly 4200 5w30) to the vw502 oil (Castrol Edge 5w40 still C3) and the consumption got even worse despite increasing the viscocity.
I am really struggling to find the A3B4 5w40 oil with peace of mind as nearly nowhere sells this and I can not trust to the genuinity of the oils that I find from small shops who are not global in any way.
I would like to read your opinions about this oil (Castrol Edge 5w40 C3) with Vw502 approval on my 2010 audi 1.8 tfsi (cdhb engine).
Cheers.
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5459902 06/22/20 01:13 PM
M
M
Originally Posted by moonlightblue
Hello all,
In my case, to reduce the oil consumption I am thinking to switch to the Castrol Edge 0w40 A3B4. According to the video below it really could make the trick on an Audi about reducing the oil consumption.
https://www.youtube.com/watch?v=jH6...ronfnjM5oYvw&start_radio=1&t=379
What do you think?
Cheers.
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5459943 06/22/20 02:29 PM
J
Jetronic Offline
J
If the issue is with low tension piston seals, higher viscosity isn't going to help. Your best bet to curb consumption is a lower viscosity so the seals manage to scrape excess oil off the walls. But that also means higher chance of wear. Extra zddp and calcium and moly might help there, or maybe it won't.
But the video you linked didn't say what the cause is, so all just a guess from my part.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460041 06/22/20 04:24 PM
K
Kamele0N Offline
K
Hello all,
Cheers.
Huh.......there are many options for A3/B4 oils in 5w40 in EU......Shell (GTL)....Mobil1 (various oil bases...depending on viscosity)
What do you want to use actually? Because you seems to be a little bit confused here smile A3/B4 or C3?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460090 06/22/20 05:36 PM
PimTac Offline
There are a couple of recent threads on this very subject.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5395423/oil-selection-query#Post5395423
https://www.bobistheoilguy.com/foru...need-help-on-info-about-oils#Post5409986
Like I said before, it’s deja vu all over again. I’m not sure what the OP is trying to get answered here.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460113 06/22/20 06:04 PM
edyvw Offline
Hello all,
Cheers.
What was oil consumption with C3? What is with Castrol 5W40? Just because oil is thicker does not mean lower consumption. Also, take into consideration that VW 504.00/507.00 oils are almost W40 oils.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: A3B4 vs C3 And Oil Consumption [Re: edyvw] #5460143 06/22/20 06:43 PM
M
M
Hello all,
Cheers.
About 1 lt every 1000 km. And yes with Castrol Edge 5w40 (c3). Sometimes less than that sometimes more than that especially in city driving.
Nearly no consumption on a long drive.
Re: A3B4 vs C3 And Oil Consumption [Re: Kamele0N] #5460155 06/22/20 06:55 PM
M
M
Hello all,
Cheers.
There are not many options where I live in regards to A3B4.
In regards to Mobil 5w40. There is no Mobil 1 5w40, however there is Mobil Super 3000 5w40. It is advertised as fully synthetic and has vw502 approval. It is also an A3B4 oil as well. But definitely not a Mobil 1. I dont know if that matters alot at Mobil ?
As you can see from the video below, this guy improved the oil consumption on his audi by switching to castrol supercar 10w60 oil. But my audi is with a turbo so I do not want to go beyond 5wXX.
I am in between Castrol Edge 0w40 a3b4, Shell 5w40 a3b4 (which I can not find at the moment) , Mobil 5w40, Mobil 5w50
Mobil 5w50 is also available as FS X1 which is without any VW approval, and I am not sure if it will cause any issue.
As I understand A3B4 is for petrol and C3 is for diesel engines...I wonder if C3 oils make oil consumption much worse...
https://www.youtube.com/watch?v=72I6DxMB0BI&t=622s
Re: A3B4 vs C3 And Oil Consumption [Re: PimTac] #5460159 06/22/20 06:58 PM
M
M
Question is clear. I wonder whether what I watch on the video link which I shared is true and whether a3b4 will protect the engine better and help oil consumption get better than a c3 oil ?
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460177 06/22/20 07:16 PM
B
blingo Offline
B
C3 is about reduced ash formation, so not much difference to be expected with the faulty TFSI rings as they're on the wet side. One A3/B4 5W-40 highly regarded for some exceptional cleanliness in general is the Kroon Polytech.
For final playing around with such an engine before having to exchange anyway there might be routes of aggressive cleaning attempts like there once had been with Mazda's Zoom-Zoom-cleaner for the Renesis engines.
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460244 06/22/20 08:17 PM
P
Popsy Offline
P
In Europe you should be able to get Shell 5W40, Total 5W40, Elf 5W40 (probably same as Total), Motul 5W40....A3/B4 and MB 229.5 approval as cherry on top. They are literally everywhere ?
Also some lesser known, Igol, Yacco, Repsol, Agip/Eni...
5W40 C3 is another story, except for Valvoline?
I'd go with some Total Quartz 9000 Energy 5W40. Cheap, MB229.5 approval.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, M1 TDT 5W40 | Colt Ralliart, 300V 0W40
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460383 06/23/20 12:11 AM
edyvw Offline
Hello all,
Cheers.
What is your highway driving regime. I am thinking evaporation loss due to higher oil temperature in the city.
Check Mobil1 ESP 5W30 VW504.00/507.00. It ahs pretty low Noack.
Re: A3B4 vs C3 And Oil Consumption [Re: Popsy] #5460432 06/23/20 04:51 AM
K
Kamele0N Offline
K
Repsol elite is C3 5w40
Re: A3B4 vs C3 And Oil Consumption [Re: moonlightblue] #5460436 06/23/20 05:12 AM
dlundblad Offline
I would try a non VW502 such as a conventional 10w40 A3/B4 and give that a try if a 5w40 A3/B4 VW502 is not working for you.
I would not expect to see much of a difference in terms of consumption with a (mid SAPS) C3 A3\B4 vs a (High SAPS) VW502 A3/B4 especially with European fuel. US fuel is a different story.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: A3B4 vs C3 And Oil Consumption [Re: edyvw] #5461228 06/24/20 05:33 AM
W
weasley Offline
W
That's an unexpected mistake for you to make! VW 504 00/507 00 oils can only be 0W-30 or 5W-30.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
