Not sure if this is the correct area, but here goes. I changed the oil on my parents vehicle a few days ago. Unfortunately the oil drain plug fell right in the drain hole of the used oil container that I was using, causing it to overflow. I had a piece of cardboard under the container as well, but it still spilled over and onto the garage floor. I used oil dry to get as much off the floor as possible.
So my question is, what is the best way to get rid of most (if not all) the oil that has stained the cement? So far I've used some dish detergent and scrubbing. Helped a little, but have a ways to go getting it clean.
Any help would be appreciated.
