Forums Migration
Please read this thread
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
89 registered members (01rangerxl, 2K2AcuraTL, 2015_PSD, 28oz, 4WD, 1911CHAMPION, 13 invisible), 2,014 guests, and 41 spiders.
Topics307,633
Posts5,314,693
Members71,894
Oil spill clean up #5459463 06/21/20 09:33 PM
R
Rappy Offline OP
R
Not sure if this is the correct area, but here goes. I changed the oil on my parents vehicle a few days ago. Unfortunately the oil drain plug fell right in the drain hole of the used oil container that I was using, causing it to overflow. I had a piece of cardboard under the container as well, but it still spilled over and onto the garage floor. I used oil dry to get as much off the floor as possible.
So my question is, what is the best way to get rid of most (if not all) the oil that has stained the cement? So far I’ve used some dish detergent and scrubbing. Helped a little, but have a ways to go getting it clean.
Any help would be appreciated.
2019 GMC Terrain 2.0L
2006 Aveo
2018 Jeep Compass
Re: Oil spill clean up [Re: Rappy] #5459467 06/21/20 09:43 PM
U
user52165 Online Content
Online Content
U
Simple Green diluted 50/50 with water. Spray it on, hose it out, won't hurt a thing.
Re: Oil spill clean up [Re: Rappy] #5459471 06/21/20 09:45 PM
T
tbm5690 Offline
T
Degreaser followed up by a pressure washing should do it.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport/Tech
2007 Honda Shadow Spirit VT1100C
Re: Oil spill clean up [Re: Rappy] #5459477 06/21/20 09:58 PM
5
55hambone Offline
5
I use full strength Purple Power for spills during oil changes in the driveway. I spray it on and leave it, the next rain rinses it all away.
Re: Oil spill clean up [Re: Rappy] #5459507 06/21/20 10:59 PM
P
Polyalphaolefin Offline
P
I use brake cleaner spray
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: Oil spill clean up [Re: Rappy] #5459636 06/22/20 07:07 AM
spasm3 Offline
Simple green works well. There will always be some sort of stain if its unsealedl concrete. I cleaned and pressure washed my garage floor, it had stains from the carbon, no matter what i did. But the floor coating adhered nicely. Even with the oil gone, the carbon from the used oil will leave a stain.
One member here has suggested wood ashes, i've never tried that, you have nothing to lose.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Oil spill clean up [Re: Polyalphaolefin] #5459649 06/22/20 07:24 AM
supton Offline
That is what I resorted to recently. Opened the door and all the windows and tried to be upstream of it, made sure to wear gloves. Lay down a stream and immediately wipe up with paper towels. Small section at a time. Seemed to do the trick--I suspect it'll never been completely clean, but who cares, it's a garage.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Oil spill clean up [Re: Rappy] #5459653 06/22/20 07:30 AM
R
Rand Online Content
Online Content
R
+1 brake cleaner spray.
Re: Oil spill clean up [Re: Rappy] #5459655 06/22/20 07:38 AM
4WD Online Confused
Online Confused
I’m getting where those double wall drain pans annoy me … either something like what happened to you … or they splatter oil all over … Finally found and open top big enough and still has a filter landing …
Re: Oil spill clean up [Re: Rappy] #5459772 06/22/20 10:34 AM
28oz Online Content
Online Content
For oil that's soaked into cement, I've used Krud Kutter with great success. I scrub it in a little, keep it wet for a few minutes and then hose it off. It's non-toxic and biodegradable. Probably the best de-greaser I've ever used.
1990 Nissan 300zx VG30DE - M1 EP 10W-30
2004 Nissan Quest VQ35DE - M1 EP 10W-30
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - QS HM 5W-30
Re: Oil spill clean up [Re: Rappy] #5459854 06/22/20 12:12 PM
O
odie Offline
O
Glass cleaner works very well for cleaning engine oil .
Re: Oil spill clean up [Re: Rappy] #5459892 06/22/20 12:57 PM
N
NoNameJoe Offline
N
AutoZone sells a super concentrated degreaser that it claims is for driveway cleaning. It smells just like purple power, sure felt more powerful though. Not sure if it was just my imagination and them doing a vertical with purple power (just renaming the same product for a specific use) or what.
2015 Civic LX Coupe
