Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
81 registered members (apham8, 77GrandPrix, 4WD, 97tbird, alarmguy, 2015_PSD, 11 invisible), 1,392 guests, and 33 spiders.
Topics307,433
Posts5,310,929
Members71,847
Styles of compressed air fittings #5459303 06/21/20 04:36 PM
9
92saturnsl2 Offline OP
9
I'm redoing some of the air plumbing in my garage and at the hardware store I noticed there are several different styles of air fittings. When I did my lines originally the store I went to only had one style, so that's what I got which ended up being "M" style, which I'm pretty sure is most common as I see that style regularly in other buildings. But there's a T, V, ARO, and a couple others I believe.
Does any style offer advantages over the other? I don't do anything particularly heavy duty and the fittings I have flow plenty of air for what I use it for.
But it does annoy me that the quick connect fittings I have aren't as reliable as I'd like. They seem to work okay for a few months but I notice that eventually they begin to leak if there's slight pressure on them or the hose twists. Replacing the quick connect coupler always fixes the problem but this is a headache I'd like to avoid. Curious if one of the other styles might be more resistant to this type of wear, or have a more secure connection that might be longer lasting.
Any info on the strenghts / weakness of the different styles would be helpful, or are they all created equal?
96 Grand Prix SE 150k Chevron Delo 5w-40 Synthetic
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Rotella T5 10w-30
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459314 06/21/20 04:55 PM
U
user52165 Offline
U
The Milton high flow "V" types have noticeably more air flow:
https://smile.amazon.com/gp/product/B001O2ZGQ6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
They hold up very well + you can insert a tool just by pushing, no need to withdraw the collar.
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459316 06/21/20 04:57 PM
H
hallstevenson Offline
H
I thought the common types were just called "industrial", "automotive", and some other type (without Googling, the name escapes me at the moment). Problem is, they're partly interchangeable although they don't fit or connect 100% perfect. It could have been the coupling I was using that was the problem too as I'm sure they're for specific types too. If I recall what happened, I had bought the various fittings in a set so obviously they matched. Later, I had to replace a single fitting and ended up buying the wrong type (not even realizing there was a difference).
I Googled this stuff at the time and don't recall that one is "better" than the other. They're just different.
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459385 06/21/20 07:32 PM
B
BrownBox88 Offline
B
I'm an industrial supplier to some major trucking companies, Milton style fittings is so far the most popular with all of my customers. I have one account that absolutely DOES NOT like quick disconnects.
As far as weaknesses, I have not had any complaints. The only part that I've seen wear out more than anything is the male quick connect fitting, it gets worn out from repeated disconnects.
2014 Ford Fusion SE Ecoboost 60k
1999 Mitsu Galant ES-V6 359k
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459483 06/21/20 10:01 PM
clinebarger Offline
Milton "M" style are the longest lived, If you don't need high flow, That's what I would recommend. The Milton "V" style is pretty good but not as long lived. I've used "M" style on my Trans benches for over 25 years with great results. The only tool I use that really requires "V" style fitting is a Proto 3/4" Impact & don't use it all that often.
2001 Chevy Camaro L92/4L80E
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459517 06/21/20 11:40 PM
Chris142 Offline
The one on the left is common in auto repair shops. The middle with construction guys. I have never seen the one on the right
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459526 06/22/20 12:51 AM
Silk Offline
The one on the right is the 1/4'' ARO fitting which 99% of NZ shops use....except where I work, where we used the 3/8'' ARO.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459533 06/22/20 01:27 AM
sloinker Offline
I've been converting all my fittings to the high flow style. There is a real difference in performance and speed.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5459607 06/22/20 06:25 AM
L
Little_Lebowski Offline
L
The one on the left is a T type. It's what i use and works well.
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5460429 06/23/20 04:32 AM
dlundblad Offline
I’m using the Milton V style/ high flow. I think a box was 10 was around $12 on eBay. The quick release fitting was just under $10.
Somewhat annoying to have unique fittings to everyone else. I’ve had to swap fittings a few times so far. I need to especially make a normal to high flow adapter with 3’ or so of hose and vice versa.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5460481 06/23/20 06:54 AM
T
Trav Offline
T
I have my air system broken down into multiple parts, one uses M fittings 3/8 hose with filters and oiler for tools. The other is V, 3/8 hose all sorts of filters and cooler but no oiler for spraying, tire filling, blow gun use. There is also 1/2 line from both oil and clean sides for higher cfm 1/2 hose.
Re: Styles of compressed air fittings [Re: user52165] #5460930 06/23/20 04:20 PM
U
user52165 Offline
U
A good You tube video explaining the V types:
https://www.youtube.com/watch?v=nss-j0H0ADg
Read the Amazon reviews
Re: Styles of compressed air fittings [Re: 92saturnsl2] #5466267 06/30/20 10:55 AM
U
UncleDave Offline
U
I use Miltons mostly, but Im going to try Stedlins.
UD
https://www.youtube.com/watch?time_continue=4&v=P6QZI-_Ri9I&feature=emb_logo
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
