Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Bazza32, Klink_II, williamshrader, 96JeepXJ, TxVet33
71826 Registered Users
63 registered members (alarmguy, anpconnors, Aredeeem, AlienBug, antone, 4WD, 4 invisible), 972 guests, and 34 spiders.
Topics307,389
Posts5,309,654
Members71,826
Accidentally bent my straight shaft trimmer #5459206 06/21/20 01:15 PM
dwcopple Offline OP
It still works okay? Should I fix or leave it? How would I straighten it back?
2017 Acura MDX SH-AWD
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5459224 06/21/20 01:40 PM
J
Jethro_Bob Offline
J
It depends. Homeowner grade or commercial? Spring shaft or solid shaft? Slight bend or tied up like a pretzel?
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5459234 06/21/20 02:03 PM
danez_yoda Offline
aggressive whacking to get the string out can cause the shaft to bend. I've done it when I had cheaper models (Boulins). Since them I bought a echo 225 from HD and never had a shaft bending issue.
When I had teh Boulins I would bend it back after it go too far. As long as it doesn't kink you are ok.
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5459258 06/21/20 02:48 PM
Cujet Offline
I've used my hydraulic press and V blocks to straighten tubing. It's a bit tedious, but generally comes out great. The hurricane bent my flagpole and it's near perfect now. I also straightened the heavy barrel of a target 22 Mossburg 144LSB. It purchased it used for $50 at the local store, not noticing the bend. The results have been spectacular! Very accurate!
The internals of a trimmer won't much care if there is a slight imperfection in the tubing.
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5459418 06/21/20 08:21 PM
dwcopple Offline OP
It's an Echo, 2 years old. I'll post pic tomorrow
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5462779 06/25/20 07:50 PM
dwcopple Offline OP
Here is a pic
[Linked Image from i.imgur.com]
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5462783 06/25/20 07:55 PM
J
JTK Offline
J
Got to watch that "aggressive whacking".
Like said above, if the shaft that runs from the engine to the string head is flexible, almost like a section of cable, this should be fine. If it's a solid rod, things are going to go south.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5462856 06/25/20 09:33 PM
G
GearJammer Offline
G
Trying to straighten it is certainly worth trying. New main pipe costs less than $40 which could be well worth it if the trimmer still runs good.
Re: Accidentally bent my straight shaft trimmer [Re: dwcopple] #5463183 06/26/20 09:52 AM
T
tundraotto Offline
T
All smaller Echos I have ever seen are flex-shaft - so just bend it back and go on about it.....solid shaft trimmers are very rare these days....even in small brushcutters
Re: Accidentally bent my straight shaft trimmer [Re: GearJammer] #5465195 06/28/20 08:57 PM
dwcopple Offline OP
It's only a year old.
I had it on the front of my zero turn while I was driving it hooked on one of my chainlink fence posts and bent. Runs fine right now.
