Forums Migration
Please read this thread
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
86 registered members (2strokeNorthstar, 2004tdigls, 2010Civic, Alaskanmont, Aichiguy, 53' Stude, 8 invisible), 2,063 guests, and 43 spiders.
Topics307,766
Posts5,317,416
Members71,914
Continue with 10w-30 or switch to Hydraulic Oil #5458922 06/21/20 05:36 AM
F
fozzdesy2001 Offline OP
F
I have a wood chipper that calls for a quality 10w-30 motor oil as hydraulic fluid. I have Rotella T5 in it now but will hydraulic oil work as good or better and last longer? I know hydraulic oils can be had for a lot less money and so can different 10-30's. My reason to try something different is the high heat this system generates and why I chose the T5. This system has only a small Vickers pump and a White motor with no clutches or gears so I only looked at hydraulic fluid skipping over tractor fluid because I don't need the formula for gears and clutches.
I have been looking at some hydraulic oils :
MAG 1 Hydraulic Fluid R&O AW ISO 68
Sinopec L-HV Low-Temperature Antiwear Hydraulic Oil ISO 46 or 68
Super Tech Heavy Duty Rust and Oxidation Anti Wear Hydraulic Oil
It's not broke but I'm afraid it will break because of 170 degrees + heat when it works more than a few hours straight. Any thoughts or suggestions will be appreciated.
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5458955 06/21/20 07:08 AM
salesrep Offline
ISO 100
High quality Specialized Lubricants pay for themselves!
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5459110 06/21/20 10:18 AM
CT8 Online Content
Online Content
Use a quality 10W-30. All your reasoning is misinformation.
2015 F150 2.7
2018 F350 6.2
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5459200 06/21/20 01:00 PM
L
Linctex Offline
L
This is an EXTREMELY "low-stress" environment.... no special or exotic fluids needed or required.
You'll never have to change that fluid. Just keep it topped off and fix any leaks when they happen.
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5459208 06/21/20 01:19 PM
L
Linctex Offline
L
If you are worried about 170 oil temps - you have a lot of education to receive.
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: salesrep] #5459275 06/21/20 03:45 PM
Scuder Offline
Originally Posted by salesrep
ISO 100
Agreed that this would be your best choice. It's equivalent to a SAE 30.
Finding a small package at a reasonable price could be challenging. That could be why the manufacturer specc'd available everywhere 10W-30.
2019 Jeep Compass
2009 Pontiac Vibe
1968 Barracuda Formula S 340
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5459284 06/21/20 03:55 PM
J
Jackson_Slugger Offline
J
LOL is it a "chuck-and-duck" old gas model?
In any case I'd use the 10W-30...
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: Linctex] #5459560 06/22/20 03:49 AM
F
F
You are right about getting educated on hydraulics. I had to take the super crash course because this thing was not working the way it should and after buying a pressure gauge and a few fittings I found out the variable flow control valve was bad. I had no idea what a normal "Hot" temp should be and still don't, so is 170 degrees in the normal operating range?
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: Jackson_Slugger] #5459569 06/22/20 04:30 AM
F
F
Without a working variable flow control valve it certainly was "chuck-and-duck" it was scary. It has a Kohler K58 opposed twin that runs like a top. When I bypassed the valve to confirm it was bad it went from barely pulling anything in, to sucking in whatever branch you chucked in so fast I couldn't duck fast enough and have the scratches to prove it. A new flow control valve tamed the beast! With the reduced flow I might be generating too much heat for the 10W-30 long term but I will leave it for now and just keep monitoring the oil condition.
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5459790 06/22/20 10:49 AM
I
ironman_gq Offline
I
170 is not a hot system by any means, if you were seeing 250+ I would say you're getting hot. At 170 you're still in range to have a moisture buildup problem if the system is vented to outside air.
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: fozzdesy2001] #5460594 06/23/20 09:48 AM
CT8 Online Content
Online Content
Motor oil protects better that hydraulic fluid.
2015 F150 2.7
2018 F350 6.2
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: ironman_gq] #5460630 06/23/20 10:32 AM
F
F
It is vented to outside with a cheapo cap but I am going to install a better cap and neck that is supposed to hold 3 to 5 psi air pressure in the tank before it vents to the outside. I don't know if it will make any difference but it is made a lot better than what's on it now. Good to know 170 is not considered too hot and will look at that temp as a normal working temp.
Re: Continue with 10w-30 or switch to Hydraulic Oil [Re: CT8] #5461522 06/24/20 02:07 PM
G
George Bynum Offline
G
Yes, motor oil protects ENGINES better than hydraulic fluid protect engines.
But hydraulic fluid ... good quality ... protects pumps, valves, and hydraulic motors better than engine oil. One particular weakness of engine oil is that they have emulsifiers to mix condensed water and keep it in solution. That's good in an engine, but bad in a hydraulic system. Soot is better kept in solution. Filters are USUALLY better for hydraulics.
We want our water to settle and get drained out from the bottom of the reservoir. We want EP additives that are not ideal in an engine.
Have I used engine oil, or automatic transmission oil in hydraulics? Yes, but it needs to be changes more frequently (time, day/night temperature swings) than hydraulic oil. For a VERY FEW applications, I actually prefer Dexron III to hydraulic oils that are commonly available (where a VI of over 200 is good).
But in general, not a good idea.
