Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
84 registered members (antonmnster, 4WD, andy2001, Alfred_B, Arrechera, Atrocious, 5 invisible), 2,079 guests, and 23 spiders.
Topics307,450
Posts5,311,404
Members71,850
Mobil 1300 OK in Ford 3.5 V6? #5458867 06/21/20 12:05 AM
N
neo3 Offline OP
N
I've been using 5W30 since owning a Taurus with the 3.5 V6, even though the manual and oil cap demand I use 5W20. This is a non-turbo, non-DI engine, it's very quiet and has been trouble-free, and is just now coming off the 6 year powertrain warranty. What I currently have in my "stash" is 2 gal. of Mobil Delvac 1300 Super 15W40, thinking of using this for the next oil change for the Taurus. Any reason not to use it? I'm in AZ, it's going to get up around 100F or more every day for the next couple months. Also, I have a bad habit of adding some Lubegard Biotech at every oil change.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5458895 06/21/20 02:35 AM
Char Baby Offline
I don't see why you couldn't use up your stash of 15W40 in that engine especially in that AZ heat. But I am curious as to what others will add.
Also, I have nothing against LubeGard BioTech(I like ILI products) however, I just dont think it's needed. But, if you already have some in your stash, use it up as well.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5458897 06/21/20 02:54 AM
U
userfriendly Offline
U
I used 15w40 and SAE 40 in both a 98 Taurus and 95 Windstar van. But then again, I'm both a thickie and Mr monograde.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5458935 06/21/20 06:29 AM
4WD Online Confused
Online Confused
Ran it in my last GMC 5.3L (non AFM) … what I have left is for the 19 HP Briggs …
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5458954 06/21/20 07:08 AM
K
ka9mnx Offline
K
High ambient temperature does not dictate using a thicker oil. Low ambient temperature does dictate using a lower Winter rated oil (0w-x or 5w-x)
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5459001 06/21/20 08:32 AM
T
Triple_Se7en Offline
T
Where is the word 'demand" written in either the Owners Manual or oil fill-cap? Does it say 'require"? Or does it say 'recommend"?
Your warranty time is over. Try the heavier oil and let us know how it works out. You could probably continue with it, during the Tuscon winters.
Wait..... does Tuscon even have a winter? I've never been Southwest. Wait again..... never Northwest either.
Stay Safe - Stay Healthy
Think things out - b/4 jumping on the wrong daily path.
Keep Your TGDI / GDI engines clean....4k OCI.
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: Triple_Se7en] #5459011 06/21/20 08:41 AM
K
ka9mnx Offline
K
Don't know about Tucson but Phoenix can get down to 20f to 30f in low lying areas in the Winter.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: Triple_Se7en] #5459016 06/21/20 08:45 AM
K
ka9mnx Offline
K
My Ranger manual doesn't say "demands" but says "only use 5w-20".
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: ka9mnx] #5459026 06/21/20 08:57 AM
T
T
That's close-enough to a demand - if it concludes by saying.... 'in any climate" or stops the sentence right there & then.
...... thanks for the quick check & see.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5459040 06/21/20 09:04 AM
G
Gene K Offline
G
I doubt it will hurt it. If 15W-40 would hurt it on a 70F cold start Ford wouldn't recommend using 5W-20 down to -22F.
Ford has been known to recommend heavy oil to quiet noisy cam phasers and chains so I think any speculation about heavier oil and potential cam phaser issues is a lot of worry over nothing.
I've never seen any evidence the 3.5L Ti-VCT needs anything other than the 5W-20 but if 5W-30 helps you sleep better no biggie.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: ka9mnx] #5459054 06/21/20 09:14 AM
Cujet Offline
In many cases, that is absolutely incorrect. There are times where ultra low viscosity oils and low HTHS oils are incapable of maintaining adequate film strength under high temperatures. Additionally, many vehicles do not have oil temperature management systems. This is particularly true with older designs.
Clearly, many modern engines are designed around a low viscosity oil. Even so, some engines require more viscosity in Saudi Arabia, for example. It's common for hot areas of the middle east to use synthetic 5W-30/40 where the very same vehicles the USA would use 0W-20.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: Cujet] #5459120 06/21/20 10:40 AM
K
ka9mnx Offline
K
If your cooling system is working the engine will not know, or care, what the ambient temperature is. I would agree with you if your coolant system couldn't keep up.
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: neo3] #5459195 06/21/20 12:54 PM
L
Linctex Offline
L
I'm in a similar situation.
You could do what I do and mix the 15W-40 with 0W-20.
My Kia Optima loves this blend!
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: ka9mnx] #5459334 06/21/20 05:13 PM
Cujet Offline
Oil temperature and coolant temperature are not directly proportional. Track day enthusiasts regularly see this [as do Middle East motorists] . The 278 degree oil temperature in the quote below shows just how out of control oil temperatures can get even with an OEM oil cooler. I understand the temptation to think that oil temperatures will be managed by the oil flowing over relatively cooler components. The reality is that oil temperatures can spiral out of control in high ambient temperatures, engine destruction can and does result.
It's good to remember that oil transfers heat much more slowly than water. Oil temperatures can and do continue to rise under some circumstances.
Quote: "To be fair, it was pretty hot at the track, about 28 C (84F) on the hottest session, and I was pushing the car pretty hard. Sessions are 20 mins, and I was near the end of it. I checked the performance pages display and my engine oil temp had got up to 137 C, or about 278 Fahrenheit At that point, I backed off and did a cooldown lap. The car had no warning lights or limp modes or anything like that, still had plenty of power, but that scared me a little. The coolant temp stayed pretty normal, I don't think it exceeded 105 C"
Re: Mobil 1300 OK in Ford 3.5 V6? [Re: Cujet] #5459340 06/21/20 05:22 PM
R
Rand Offline
R
Thats the reason the track mustang gets 5w50 instead of 5w30?
