Forums Migration
Please read this thread
Time to Dump or Repair?
by GMFan - 07/09/20 12:46 PM
TIREREVIEW : Videos
by odie - 07/09/20 12:39 PM
HYUNDAI ; Manual tranny w/o a clutch pedal
by odie - 07/09/20 12:30 PM
Need Pressure Washer Recommendations
by qdeezie - 07/09/20 12:28 PM
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
115 registered members (77Se7en, 1911CHAMPION, Alex38, 2010Civic, Alfred_B, Ag76, 8 invisible), 1,950 guests, and 39 spiders.
Topics307,645
Posts5,314,888
Members71,897
Page 1 of 3 1 2 3
Mobil Delvac Extreme synthetic 15w-40 #5458709 06/20/20 06:30 PM
Capt Offline OP
Is this new? Just noticed at walmart today, any voa/uoa/experiences? [Linked Image]
[Linked Image]
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458727 06/20/20 06:57 PM
Cujet Offline
Ohhhh, HTHS of 4.1, very nice.
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458742 06/20/20 07:34 PM
SR5 Offline
Now that would be a shear stable oil, it comes in two grades 10W30 and 15W40 according to this Mobil web page
https://www.mobil.com/en-US/Commercial-Vehicle-Lube/pds/GL-XX-Mobil-Delvac-Extreme
Both are API CK-4, ACEA E7 & E9, plus many OEMs, both have a strong TBN of 10.3
10W30 HTHS = 3.6 cP, KV100 = 11.8 cSt,
15W40 HTHS = 4.1 cP, KV 100 = 14.3 cSt,
They don’t mention ZDDP levels, but the 15W40 is API SL/SM rated, while the 10W30 is not. Given that Phos levels (from ZDDP) are more restricted for 30 grades than 40 grades, I read this as these being higher ZDDP oils. ZDDP is an anti-wear agent that protects the metal, but also an antioxidant that protects the oil itself. A VOA would be interesting.
The CCS limit for both those winter grades (10W and 15W) is 7000 cP (at -25 C and -20 C respectively), and they test out to be 6600 and 6100 respectively. This is getting close to the upper limits, which suggest to me that thicker base oil was used for the viscosity, and less polymer VII. So I would expect high shear stability and low Noack volatility.
All this on a synthetic base, says a very strong oil with a long life. Which is what Mobil is selling
Quote
Mobil Delvac Extreme is formulated with synthetic basestocks and a boosted additive system tailored to deliver extended performance for up to two times beyond OEM recommended oil drain intervals. The proprietary formulation delivers excellent wear protection, exceptional oxidation stability, and outstanding TBN retention. Mobil Delvac Extreme FE also provides outstanding resistance to oil consumption, oxidation, corrosive and abrasive wear, and high temperature deposits.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458746 06/20/20 07:54 PM
L
LubricatusObsess Offline
L
Hmmm....wonder if this is an add-on to the 5W-40's, or an acknowledgement they ain't makin' it in shear stability and plan to move away from them??
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458748 06/20/20 07:58 PM
wemay Online Happy
Online Happy
Capt, what store did you find this in? That would look real nice filling the sump of my Santa Fe Turbo.
19 Passat Wolfsburg 2.0 TSi: Castrol Edge LL 0W-20
13 Santa Fe Sport 2.0T: Castrol GTX Magnatec 5W-30
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458753 06/20/20 08:04 PM
SR5 Offline
That 10W30 would have to be very close to a monograde
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458772 06/20/20 08:29 PM
Capt Offline OP
This jug was In Stuart, Fl. WM in FL seems to have trouble selling synthetic diesel oils, I bought some mobil 1 TDT 5w-40 cheap and noticed delo 5w-40 & t6 5w-40 heavily discounted. Seems diesel owners are just buying 15w-40 for $11 gallon vs $20 for 5w-40 syn's. Seeing t6 in 15w-40 & this delvac syn 15w-40 shows that they are trying to find a market. Most truck manuals call for 15w-40 above freezing anyway.. I did notice a boat that I work on specifically requires Mobil ESP 5w-40 for the MAN common rail diesels, Im guessing HTHS is excellent with the Mobil esp 5w-40..
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458781 06/20/20 08:44 PM
L
L
A large part of the world remains above 14 deg F (CCT), borderline pumpability temperature of 15W-40 mineral oil, and much of the population lives in these temperate climates. So, I suspect there will be a good market for a highly shear-stable synthetic 15W-40, instead of the niche market for 5W-40 for the weird guys like me that live in the American Siberia.
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458789 06/20/20 09:09 PM
wemay Online Happy
Online Happy
Thanks
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458810 06/20/20 09:53 PM
c502cid Offline
I tend to mix 5w-40 and 15w-40, I like a synthetic 15w-40 a lot!
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
77 E250 Quadravan 460/C6/NP205 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458813 06/20/20 09:57 PM
B
billpace1956 Offline
B
What was the price? Nice find!
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458826 06/20/20 10:42 PM
Capt Offline OP
$19.47
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458828 06/20/20 10:45 PM
4WD Offline
Nice sauce for under $20 !
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458882 06/21/20 01:19 AM
L
Lolvoguy Offline
L
only one gallon for 20 bucks?!
That's not even enough for an OCI
crzy
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Mobil Delvac Extreme synthetic 15w-40 [Re: Capt] #5458923 06/21/20 05:41 AM
L
LeoStrop Offline
L
I wish i could find 15W40 Synthetic around here, that looks like a great oil for old engines like mine.
Both VI infos are wrong, it should be 139 (10W30) and 136(15W40).
I like the ingredient description on the back. thumbsup
Chevrolet Kadett EFI '94 (Neat ethanol) - Shell Rimula RT4X 15W40
Honda Fit '09 (FlexFuel) - Shell Helix HX8 5W30 > Motul 6100 SYN-nergy 5W30
Page 1 of 3 1 2 3
