Forums Migration
Please read this thread
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
108 registered members (4WD, 2015_PSD, 28oz, 2004tdigls, 77GrandPrix, A310, 13 invisible), 2,005 guests, and 54 spiders.
Topics307,640
Posts5,314,813
Members71,897
Weird idle issue with motor wanting to stall #5458672 06/20/20 05:27 PM
NavyVet88 Offline OP
2002 Ford Ranger Edge 3.0L 80k
I was idling at my local zaxbys drive through getting dinner for the wife and I earlier and the truck just started acting like it wanted to stall all of a sudden for about 15 seconds and then it recovered on its own. It then drove perfectly fine with multiple intersection stops and stops signs before I got home about eight miles down the road. My train of thought On this is fuel related. It still has the original fuel pump and all the parts listed below were replaced with OEM except the fuel filter which is duralast brand.
In the last year and a half, I have replaced the plugs, coil pack, plug wires, MAF, TPS and IAC and fuel filter as they were factory parts that were nearly 20 years old when I bought the truck last year. The original MAF and IAC were replaced most recently due to becoming faulty.
I suspect the fuel pump is about to surprise me at the most in opportune time that it can. Is there anything I can do to determine if it’s the fuel pump at this point?
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5458677 06/20/20 05:38 PM
J
JimPghPA Offline
J
Is the oil warning light working? If not, it could be low oil pressure because of a failing oil pump. When they go bad the first sign is poor idle because it is at low RPM that the can not supply enough pressure.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5458678 06/20/20 05:40 PM
O
oldhp Online Content
Online Content
O
Other than putting a fuel pressure gauge on it, nope. No codes? It takes about 3 hrs to replace. Pull the bed off, much, much easier to do. Have helped with 2 of them.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Weird idle issue with motor wanting to stall [Re: JimPghPA] #5458687 06/20/20 06:00 PM
No oil light. I forgot to mention also that I did replace the cam shaft synchronizer about a year ago too.
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5458725 06/20/20 06:56 PM
And no codes of course.
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5458808 06/20/20 09:46 PM
E
eljefino Offline
E
Look for gas in the vacuum line to the fuel pressure regulator.
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5458905 06/21/20 04:16 AM
L
Lubener Offline
L
Check the fuel pressure.
The "thinking" man's friend.
Re: Weird idle issue with motor wanting to stall [Re: eljefino] #5458987 06/21/20 08:20 AM
A
andyd Offline
A
X2
Thick oil is better grin2
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5459136 06/21/20 11:03 AM
F
Falkirk88 Offline
F
There are two things that can happen with the Fuel Pressure Regulator. One being that the diaphragm splits and allows fuel to be sucked into the intake creating a rich condition. Another issue is if the regulator does not open. This will cause a spike in fuel pressure and push more fuel through the injectors.
Hook a fuel pressure gauge to the engine and run through all of the tests, KOEO, Static Leak, KOER, and so forth. Go drive the truck with the fuel gauge available to read and see if you get spikes. I had one that did this on a Ford F250 with a 5.8L. Replaced the regulator and all was good again.
Re: Weird idle issue with motor wanting to stall [Re: NavyVet88] #5460466 06/23/20 06:32 AM
Thanks guys I appreciate it!
The issue hasn’t happened again to this point but I will monitor it.
