Originally Posted by Rand
Originally Posted by jeepman3071
The 22 HP vertical Predator engine will fit, as it should have the same bolt pattern, and has a 1" shaft. HF has them listed for $1000. That's way more than a replacement Briggs.
Check out Small Engine Warehouse and smallenginesurplus.com. You can find single cylinder Briggs from 13.5-18hp for less than $600. Sometimes they have a sale and you can get them for $450. Anything from that HP range should be fine for a 42" LA110. I repowered a neighbor's 42" Simplicity with a 13hp Briggs intek back in 2010 and it has been great.
Here's a 17HP for $440:
https://www.smallenginesurplus.com/briggs-stratton-31r9770054-p-3621.html
Cool didnt know they had a vertical v-twin now.
and that website is cheap but for apples to apples its $504 shipped(but out of stock) vs $599
I was considering putting the horizontal v-twin into the 3000 hour jd316 we trail mow with.. but did valve job instead.
Whoops, didn't realize it was out of stock. I do a lot of repowers for customers but haven't done a V-Twin Predator yet. The cost is just too much for most people. They would rather I throw in a used Briggs or Kohler V-Twin. There seems to be two schools of thought with my customers, either get it done cheap with a used engine, or the commercial mower guys buy a quality replacement like a Briggs Vanguard or Kawasaki. I've seen a few Honda V-Twin repowers on those Deeres, but not a Predator yet.
