Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
108 registered members (72te27, 2010Civic, 18LateModelFan, 14Accent, 4WD, 9 invisible), 1,805 guests, and 25 spiders.
Topics307,463
Posts5,311,619
Members71,852
Best grease to use in sealed ball joints? #5458193 06/20/20 01:02 AM
F
Framer Offline OP
F
I took out my bmw control arms to replace the bushings, and would like to add some grease to the ball joints. They are the sealed type but I can easily insert a grease needle next to the tapered shaft.
I'm thinking marine grease since it's less likely to leach out and be affected by water?
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458232 06/20/20 06:06 AM
E
eljefino Offline
E
You want the same "soap" chemistry that's already in there-- mixing is bad. I'd use moly grease.
Re: Best grease to use in sealed ball joints? [Re: eljefino] #5458314 06/20/20 08:21 AM
F
FabricGATOR Offline
F
Yeah, mixing grease may have killed 88 people in year 2000...
Re: Best grease to use in sealed ball joints? [Re: eljefino] #5458342 06/20/20 08:53 AM
F
Framer Offline OP
F
I agree. But how do i determine what is in there already?
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458350 06/20/20 09:03 AM
Chris142 Online Content
Online Content
Ask the manufacturer
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458372 06/20/20 09:42 AM
J
JohnG Offline
J
I think I read that Aluminum base complex grease will mix with either lithium or moly base grease. Most marine greases are aluminum base, so you're on the right track. I have mixed the blue marine grease with other kinds in the past without issue.
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458419 06/20/20 10:41 AM
R
ripcord Offline
R
I wouldn't use Aluminum base grease... it's not compatible with lithium soap grease which is still the most commonly used type. I think your best bet is a lithium complex type grease as it seems to be compatible with most other grease types.
Re: Best grease to use in sealed ball joints? [Re: FabricGATOR] #5458463 06/20/20 11:43 AM
K
kschachn Offline
K
Another goofy response from this... new user. Looks like that's your theme.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458511 06/20/20 01:20 PM
F
Framer Offline OP
F
Bought a tube of Green Grease. Their marketing got me. Lol
Re: Best grease to use in sealed ball joints? [Re: Framer] #5458611 06/20/20 03:54 PM
K
kschachn Offline
K
Do you think that's the same type grease already in the joint?
1994 BMW 530i, 253K
Re: Best grease to use in sealed ball joints? [Re: kschachn] #5458891 06/21/20 01:56 AM
F
Framer Offline OP
F
I have no idea. But the green grease is water resistant and says it can be mixed with many other greases.
Re: Best grease to use in sealed ball joints? [Re: Framer] #5459564 06/22/20 04:14 AM
L
Lubener Offline
L
I would leave the joints alone and not poke a hole in the boots. You then will have a small hole which will eventually get bigger and you destroyed any protection against the elements. I have had creeky joints and lubing through the boot didn't do a thing. Fittings are always on the bottom and you can't get any grease to the bottom of the joint where it is needed.
The "thinking" man's friend.
